relatively stock 383 in a 4000lb charger-12's remotely possi
#3289643
02/15/25 12:17 PM
02/15/25 12:17 PM
Posts: 20,805 north of coder
moparx
Buying your homeless and unwanted bolt on battery terminals
400lb charger with relatively stock 383/727/3.91/29-12.50 tires combination. converter is old B&M high stall "hole shot" unit that stalls around 26-2800 with foot brake, and flashes to 2900+ from idle in first gear. intake is DP4B with 850 T-quad. cam is racer brown SSH-25 in straight up. ignition is factory points system, which i plan to upgrade at some point. the curve has been modified so i can run 16* initial and 33 total. i can re-do the curve to run 18* initial and 34* total. i have also played with the vacuum advance so cruising rpm [roughly 3000rpm @ 65mph] gets pretty reasonable mileage with non-alcohol 91 octane. car runs pretty good now, but i feel it could be better. as no tracks are closer than 2hours+ from here, i will be using a Dragy to track performance. could this combo even come close to the 12 second bracket ? thanks to those that are way more knowledgeable than me with this subject. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
Re: relatively stock 383 in a 4000lb charger-12's remotely possi
[Re: moparx]
#3289653
02/15/25 12:55 PM
02/15/25 12:55 PM
Posts: 3,610 Md.
carnut68
Md.
Nitrous will get it there.
America First!
[Re: moparx]
#3289662
02/15/25 01:48 PM
02/15/25 01:48 PM
Posts: 7,675 Minnesota
Hemi_Joel
Minnesota
With that combination, at that weight, 12s is highly unlikely. But it can still be a fun, fast streetcar as is. Or you can start chipping away at it, making changes, and get it into the 12s.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3289666
02/15/25 02:02 PM
02/15/25 02:02 PM
Posts: 12,982 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Gonna take ~330 HP or so, whatever it takes to get there. Heads/cam maybe. And a better converter at a minimum.
[Re: Stanton]
#3289668
02/15/25 02:09 PM
02/15/25 02:09 PM
Posts: 10,504 Someplace you aren't
SomeCarGuy
Not easily or inexpensively !!! 12's is so easy to say - not so easy to achieve !
My '69 'runner had a 12.5:1 383 with a .500 lift cam, tunnel ram with two 600 cfm carbs. Headers, etc, etc. 4-speed with 4:56 gears and 8x28 slicks.Tuned ignition and carbs.
Best we could do with that was low 13's. What sort of mph did you see? What density altitude?
I want my fair share
[Re: moparx]
#3289676
02/15/25 02:23 PM
02/15/25 02:23 PM
Posts: 1,815 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
400lb charger with relatively stock 383/727/3.91/29-12.50 tires combination. converter is old B&M high stall "hole shot" unit that stalls around 26-2800 with foot brake, and flashes to 2900+ from idle in first gear. intake is DP4B with 850 T-quad. cam is racer brown SSH-25 in straight up. What are the specs on that cam? Otherwise I'm thinking that getting into the 12's ET would require a hotter converter, which should be driven by a bigger cam.
[Re: moparx]
#3289678
02/15/25 02:30 PM
02/15/25 02:30 PM
Posts: 4,363 Prospect, PA
BSB67
Prospect, PA
400lb charger with relatively stock 383/727/3.91/29-12.50 tires combination. converter is old B&M high stall "hole shot" unit that stalls around 26-2800 with foot brake, and flashes to 2900+ from idle in first gear. intake is DP4B with 850 T-quad. cam is racer brown SSH-25 in straight up. ignition is factory points system, which i plan to upgrade at some point. the curve has been modified so i can run 16* initial and 33 total. i can re-do the curve to run 18* initial and 34* total. i have also played with the vacuum advance so cruising rpm [roughly 3000rpm @ 65mph] gets pretty reasonable mileage with non-alcohol 91 octane. car runs pretty good now, but i feel it could be better. as no tracks are closer than 2hours+ from here, i will be using a Dragy to track performance. could this combo even come close to the 12 second bracket ? thanks to those that are way more knowledgeable than me with this subject. Doable but depending what you are starting with for compression ratio/cylinder pressure and cylinder heads, and what you’re willing to spend/change to make a difference. If you are near sea level, in decent air, blow 175 psi, and have heads that flow 250+ cfm, I think you can do it. I think a 1.80 sixty ft and 104-105 mph gets you there. Do a cranking cylinder pressure test and report back. And, I like the TQ, and I like the DP4B. I just don’t like them together. I’d like a Holley 4779 better with that manifold. Play with open and closed spacers.
[Re: Hemi_Joel]
#3289679
02/15/25 02:35 PM
02/15/25 02:35 PM
Posts: 4,404 Morrow, OH
markz528
Morrow, OH
With that combination, at that weight, 12s is highly unlikely. But it can still be a fun, fast streetcar as is. Or you can start chipping away at it, making changes, and get it into the 12s. I agree. You have a few advantages over my daughter's 67 coronet, but I have yet to see 14's, but traction will get me there. Also weights around 4000 lbs - last time I weighed it was 4025 lbs. My combination was mismatched, but an intake and cam swap did wonders. I think I put a rpm intake on and a smaller cam. Had a street dominator intake before. It had no low end torque. Not it runs much better and much more fun to drive. The 440 I had in there for a while would have been 12s, but it had home ported 906 heads and headers.
[Re: markz528]
#3289681
02/15/25 02:44 PM
02/15/25 02:44 PM
Posts: 14,615 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’m going to go with……….”highly unlikely”.
Never say never, but I think some runs with the Dragy will be a reality check.
[Re: fast68plymouth]
#3289710
02/15/25 05:25 PM
02/15/25 05:25 PM
Posts: 8,280 Plymouth, MI
Blusmbl
Plymouth, MI
On the street, with no burnout, I don’t think it’s going to be close to happening. It either needs to dead hook with a looser converter than what you’ve got, or it needs to mph really well (like 110+) to make up for the lack of traction on unprepped roads. I’m guessing low 14’s, maybe high 13’s, but you’ll be having fun and that’s the whole point!
#3289715
02/15/25 05:29 PM
02/15/25 05:29 PM
Posts: 2,950 Pattison Texas
CSK
Pattison Texas
Not a Mopar but, way back when I had a 1972 SS Chevelle I put an LS 6 454 in, headers, 850 DP Holley 4000lb , 410 gear, slicks, open headers 12.70 @ 107 so about 385 HP
[Re: moparx]
#3289728
02/15/25 05:51 PM
02/15/25 05:51 PM
Posts: 44,287 Bend,OR USA
Cab_Burge
400lb charger with relatively stock 383/727/3.91/29-12.50 tires combination. converter is old B&M high stall "hole shot" unit that stalls around 26-2800 with foot brake, and flashes to 2900+ from idle in first gear. intake is DP4B with 850 T-quad. cam is racer brown SSH-25 in straight up. ignition is factory points system, which i plan to upgrade at some point. the curve has been modified so i can run 16* initial and 33 total. i can re-do the curve to run 18* initial and 34* total. i have also played with the vacuum advance so cruising rpm [roughly 3000rpm @ 65mph] gets pretty reasonable mileage with non-alcohol 91 octane. car runs pretty good now, but i feel it could be better. as no tracks are closer than 2hours+ from here, i will be using a Dragy to track performance. could this combo even come close to the 12 second bracket ? thanks to those that are way more knowledgeable than me with this subject. I'm thinking 5:13 or 5;38 rear gears would help a bunch as long as it is a "local only " car, not a long distance (+300 mile one way car) cross country type car ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) Dem cars are not lightweights ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) , I love them 1968 Chargers ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif)
[Re: moparx]
#3289749
02/15/25 06:57 PM
02/15/25 06:57 PM
Posts: 1,667 westerly, ri. usa
440lebaron
westerly, ri. usa
4330 lb Cordoba 383 stock short block, 484 purple shaft 9" t/a converter, cast iron intake T/Q 850 1 7/8 header 4:56 S60 30X9 slick 13.34 98 mph three seasons on slicks might try 29" this year
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: CMcAllister]
#3289826
02/16/25 09:35 AM
02/16/25 09:35 AM
Posts: 11,838 Portage,michigan
B3422W5
Portage,michigan
Gonna take ~330 HP or so, whatever it takes to get there. Heads/cam maybe. And a better converter at a minimum. Gonna take way more than that to get a 4000 pound car in the 12’s
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
1.41 best 60 foot 6.52 @ 105.20
[Re: B3422W5]
#3289834
02/16/25 10:03 AM
02/16/25 10:03 AM
BSB67
Prospect, PA
Gonna take ~330 HP or so, whatever it takes to get there. Heads/cam maybe. And a better converter at a minimum. Gonna take way more than that to get a 4000 pound car in the 12’s There in-lies the problem with unqualified statements. 330 net actual flywheel hp could get him there. That would probably equate to something like 400 engine dyno hp, or more depending on several variables.
[Re: BSB67]
#3289835
02/16/25 10:17 AM
02/16/25 10:17 AM
CSK
Pattison Texas
Gonna take ~330 HP or so, whatever it takes to get there. Heads/cam maybe. And a better converter at a minimum. Gonna take way more than that to get a 4000 pound car in the 12’s There in-lies the problem with unqualified statements. 330 net actual flywheel hp could get him there. That would probably equate to something like 400 engine dyno hp, or more depending on several variables. I agree, the 385 ish HP I said in my previous Chevelle post would be gross flywheel HP ,
