Re: rear shocks
[Re: dragon]
#3288924
02/12/25 12:21 AM
02/12/25 12:21 AM
Posts: 12,982 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Depends. How quick is it? Stick or auto? How aggressive is the 4 link? Pro tree? Radials?
Strange and QA1 shelf shocks are adequate for most 10 and mild, light, 9 second cars. Get aggressive, add a power adder, manual, big motor, get into the 8s, low 1.30s and quicker in 60, and you can outgrow them pretty quick.
Then you get into custom stuff or something like a Big Gun Afco.
Cheap out on shocks with a car that needs something better and you usually end up chasing your tail with it. Shocks and finding the sweet spot with SLR are two things at the top of the list of important decisions. You may not need a $1800 set of shocks. But if you do and try to run it with a $700 set of shocks, you will be fighting it.
Re: rear shocks
[Re: DusterKid]
#3288944
02/12/25 08:19 AM
02/12/25 08:19 AM
Posts: 10,210 MI, usa
dvw
MI, usa
For a mid level priced shock The Afco doubles work very well. We run them on the front as well. The BG doubles have plenty of adjustment range. They are available in 5, 6, 7," travel. My car hooks anywhere on 10.5's and ladder bars. Mid to high 1.2 60ft depending on ballast. We put some Strange doubles on the front of my friends B body. They are to short to allow full suspension travel. Doug
Re: rear shocks
[Re: CMcAllister]
#3288947
02/12/25 08:44 AM
02/12/25 08:44 AM
Posts: 3,035 A shed in England
Tig
A shed in England
Cheap out on shocks with a car that needs something better and you usually end up chasing your tail with it. Shocks and finding the sweet spot with SLR are two things at the top of the list of important decisions. You may not need a $1800 set of shocks. But if you do and try to run it with a $700 set of shocks, you will be fighting it. Menscer Afco's on the rear of ours (the stock afco's ran out of ext damping), we use radials btw and it dead hooks. We have another engine that is over 300hp more than the one in now and I'm confident they'll still be good. We've been through a few different brands now, both front and rear.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: rear shocks
[Re: Tig]
#3289005
02/12/25 12:56 PM
02/12/25 12:56 PM
Posts: 19,713 Las Vegas
Al_Alguire
Las Vegas
My truck has off the shelf Strange DA shocks. Its been 1.20 60' 5 teens and 8.0's here in Vegas not really running it hard. It weighs 3100 sand change. Woudl it quicker with a better shock, probably. Are they adequate for me for now, absolutely. I rarely run the car all out and for what I spend 90% of my racing time doing they work just fine...FWIW my 64 has the same shcoks front and rear. Its been 1.25 60' and 8.80's here in Vegas at 3600
Re: rear shocks
[Re: Al_Alguire]
#3289012
02/12/25 01:12 PM
02/12/25 01:12 PM
Posts: 4,802 On the parachute mount
n20mstr
I’d rather have strange over the QA1 , but they are both good . Remember though , buying great shocks is one part , learning how to adjust/use them is almost more important !
....BAD A$$ STREET CAR.....
Re: rear shocks
[Re: n20mstr]
#3289015
02/12/25 01:35 PM
02/12/25 01:35 PM
Al_Alguire
Las Vegas
IMO it depends on the intended use. I run the Strange stuff on my bracket cars, also Afco depends on what I am after. For the heads up car we run Penskes and the price is usually enough to scare most away. But we need every last .01 we can find
Re: rear shocks
[Re: Al_Alguire]
#3289686
02/15/25 02:57 PM
02/15/25 02:57 PM
Posts: 10,213 Frostbitefalls MN (Rocky&Bullw...
gregsdart
30 inch ladderbars, 106 wb, 2900 lbs, 2.45 low, 4.56 rear, needed Afco big guns, bigblock, 1.22 60 ft, 725 torque at stall, 8.50s for ets
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: rear shocks
[Re: gregsdart]
#3289874
02/16/25 12:43 PM
02/16/25 12:43 PM
Al_Alguire
Las Vegas
FWIW I made 9 runs yesterday and my 60' varied .003 all day.....On strange DA shocks....
