The feed wires in the engine wiring harness to the ignition are 14 gauge dark blue with a white tracer on it to the original ballast reisitor and the coil and a 14 gauge brown going to the coil. Splice those two together to the 12 V feed wire for the MSD box.
Actually you only need the two dark blue wires to the MSD box
Check those wires with a volt meter to make sure they turn on and off and work in both the start and run position from the key. The starter relay has four positions for wires on it, the big one is for the battery feed and the fuseable links, the big main battery wire from the battery should go to the starter and another 10 gauge wire from the starter should be run up to the starter relay to feed the car harness. The other three connectors are marked S,I and G. The G is the 18 gauge brown wire with the yellow tracer ground wire from the transmission nuetral switch(the center pin on the transmission switch) and the I is for the 18 gauge yellow wire for the igntion switch to activate the starter relay to make the starter work. The last position is marked S which is for the 12 gauge brown wire to the starter solinoid (the small wire on the starter) which makes the starter engage. This information is from my 1971 Plymouth service manual so I hope it is correct for the 1970 models also
I have a 1969 Dodge service manual also and most of the wires do match in the wiring diagrahms
