1969 Roadrunner front bench seat center seat belt length #3289217
02/13/25 02:32 PM
02/13/25 02:32 PM
NZ
bdgtfb Offline OP
bdgtfb  Offline OP
NZ
Hi All
Can anyone give me the measurements for a 1969 Roadrunner front bench seat - center seat belts only - both male and female?
Thanks for any help you can offer
Re: 1969 Roadrunner front bench seat center seat belt length [Re: bdgtfb] #3289393
02/14/25 11:38 AM
02/14/25 11:38 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
OK, I can - let me get done moving some snow and I'll measure mine and post up.
Re: 1969 Roadrunner front bench seat center seat belt length [Re: topside] #3289411
02/14/25 12:54 PM
02/14/25 12:54 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
15" on the male (rt side, chrome tab) and 31" on the female (lt side, black buckle) - same on my '68.
Re: 1969 Roadrunner front bench seat center seat belt length [Re: topside] #3289470
02/14/25 04:32 PM
02/14/25 04:32 PM
NZ
bdgtfb Offline OP
bdgtfb  Offline OP
NZ
Hi Thanks alot for your help!
Re: 1969 Roadrunner front bench seat center seat belt length [Re: bdgtfb] #3289495
02/14/25 06:31 PM
02/14/25 06:31 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
You're welcome; I'm happy to help, that's why most of us are here, right ?
My '69 is an original, very-low-mileage car, stock except ignition & engine internals, and known history since new, so it's a great reference if you need more info.
Re: 1969 Roadrunner front bench seat center seat belt length [Re: topside] #3290672
02/20/25 06:42 PM
02/20/25 06:42 PM
NZ
bdgtfb Offline OP
bdgtfb  Offline OP
NZ
Further to my post, can anyone tell me if a 1969 roadrunner bench seat - seat belts are the same in all aspects ie length, latch and clasp style and paint finish as a 1969 GTX or Charger and if the back belts are the same length as the font bench seat center belts.The reason i'm asking is that the front center belts are missing from my car and they seem to hard to find so i am trying to broaden my options.
Re: 1969 Roadrunner front bench seat center seat belt length [Re: bdgtfb] #3290681
02/20/25 08:04 PM
02/20/25 08:04 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Latch & clasp style is the same '68-'69, and maybe '70 as well.
I think center front belts are the same length bench & bucket, but I haven't owned a bucket seat car in many years to confirm.
Ft belts differ in that the sides had the 2nd clasp for shoulder belts, centers didn't.
All rear belts are the same regardless of ft seat, as far as 2-door cars.
Center rear belt may work fine for center front as far as lengths.
Re: 1969 Roadrunner front bench seat center seat belt length [Re: topside] #3290706
02/21/25 12:22 AM
02/21/25 12:22 AM
NZ
bdgtfb Offline OP
bdgtfb  Offline OP
NZ
Thanks once again. When you measured your belts did you measure from the center of the bolt hole to end of actual belt? Also in saying all 2 door cars do you mean all b bodies?
Re: 1969 Roadrunner front bench seat center seat belt length [Re: bdgtfb] #3290735
02/21/25 09:34 AM
02/21/25 09:34 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Can't get an exact measurement without removing them & laying them flat, which ain't gonna happen right now.
Measured best I could from mounting eyelet to buckle/clasp entry.
Yes, I'm referring to '68-'69 B bodies - I don't have anything others to measure, but I wonder if A & C bodies would interchange ?
(A-bodies being smaller cars, Cs being larger, but ???)
