Re: Electric water pump ??
[Re: Stanton]
#3289459
02/14/25 04:12 PM
02/14/25 04:12 PM
Posts: 31,350 Oregon
AndyF
I'm using a Meziere electric water pump on a 526 stroker big block (street car). The pump as well as the fan is triggered by the temp sensor.
The question is:can the thermostat be eliminated AND should I install a restrictor plate to slow down the flow through the system? You can eliminate the thermostat with an electric pump provided you pay attention to the temp gauge. Just don't turn the pump until the block water starts to get hot. Once the needle is up to 150 or so you can flip the pump on and start to circulate water. You have to be very careful about this since if you forget to turn the pump on you'll overheat the engine. Use warning lights to remind you. You never need a restrictor plate with a Meziere water pump. None of the Meziere pumps will flow enough water to justify a restrictor plate. The more water you can force thru the engine the better. With a Meziere pump, cooling increases as flow increases.
[Re: AndyF]
#3289510
02/14/25 07:33 PM
02/14/25 07:33 PM
Posts: 9,248 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The question is:can the thermostat be eliminated AND should I install a restrictor plate to slow down the flow through the system? You can eliminate the thermostat with an electric pump provided you pay attention to the temp gauge. Just don't turn the pump until the block water starts to get hot. Once the needle is up to 150 or so you can flip the pump on and start to circulate water. You have to be very careful about this since if you forget to turn the pump on you'll overheat the engine. Use warning lights to remind you. You never need a restrictor plate with a Meziere water pump. None of the Meziere pumps will flow enough water to justify a restrictor plate. The more water you can force thru the engine the better. With a Meziere pump, cooling increases as flow increases. Thanks for the input. The pump will be activated by the Terminator ECU - as will the fan - when the engine come ups to temp The beauty of the ECU is that these can be triggered seperately at different temps.
[Re: metallicareload]
#3289529
02/14/25 09:27 PM
02/14/25 09:27 PM
Posts: 24,312 Capital of Narcissism
jcc
No soup for you!!!
No soup for you!!!
Cavitation is very unlikely to occur in the pressurized side (downstream) of pump, and “excess” flow encountering restrictions would further increase the pressure, which would make cavitation even less likely….. Based on what exactly? Boats experience cavitation all the time with say 8' of head (11 psi?) and at low speeds. Not sure that is a fair comparison, but it is one. The main point I am making, we don't precisely know I suspect. Where does it occur? On the front of the propeller is most likely. Inside the cooling system of an engine, the inlet portion of the impeller is the most likely part to experience cavitation. I agree, and I suspect a lot of testing takes place to determine if a cavitation problem exists and how to reduce it. But restating my point, does that same effort get applied internally of a head for example, even if it's a less likely source?
[Re: Stanton]
#3289594
02/15/25 08:59 AM
02/15/25 08:59 AM
Posts: 3,035 A shed in England
Tig
A shed in England
The question is:can the thermostat be eliminated AND should I install a restrictor plate to slow down the flow through the system? I've used a Meziere pump WP 105 (it bolts into a stock housing) since 2007. I use a restrictor plate (basically the same size as a punched out thermostat) It's cooled the 528, 572 and 655 engine versions of my Challenger street and strip with no issues. I've had various fans and controllers on it (the breakages being due to heavy wheelstand landings). Using firmly mounted Davis twin fan digital controller (fitted recently) and Spal fans at the moment, they seem to be working well
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: jcc]
#3289761
02/15/25 07:39 PM
02/15/25 07:39 PM
Posts: 318 Anchorage, Alaska
metallicareload
Anchorage, Alaska
Cavitation is very unlikely to occur in the pressurized side (downstream) of pump, and “excess” flow encountering restrictions would further increase the pressure, which would make cavitation even less likely….. Based on what exactly? Boats experience cavitation all the time with say 8' of head (11 psi?) and at low speeds. Not sure that is a fair comparison, but it is one. The main point I am making, we don't precisely know I suspect. Where does it occur? On the front of the propeller is most likely. Inside the cooling system of an engine, the inlet portion of the impeller is the most likely part to experience cavitation. I agree, and I suspect a lot of testing takes place to determine if a cavitation problem exists and how to reduce it. But restating my point, does that same effort get applied internally of a head for example, even if it's a less likely source? With a restriction on the coolent exiting the engine (either thermostat, washer with a hole in it, or the fact that the upper hose diameter is usually smaller than the lower) I would expect the water jackets to be pressurized above what the whole sealed cooling system pressure is. Pressure helps prevent cavitation. Pressure also helps suppress boiling, so that's my theory on why a restrictor plate "might" be helpful  But a restrictor plate might just be making your water pump work harder for no reason. I would think the freest flowing cooling system is the best system
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: Stanton]
#3289797
02/16/25 12:29 AM
02/16/25 12:29 AM
Posts: 7,675 Minnesota
Hemi_Joel
Minnesota
The question is:can the thermostat be eliminated AND should I install a restrictor plate to slow down the flow through the system? Why are you considering changes? Is it running too hot or too cold? Regarding the "slow down the flow so the water has more time to cool in the radiator" nonsense, if that were true, then we should also put shutters on the radiator and close them down when the thing starts running hot "so the air has more time to absorb heat from the radiator". Cab, you are not the only one who has had that experience or running hotter with no thermostat. But it is not because of too much flow. It is because the thermostat provides a restriction for the water pump to build pressure against. The extra pressure in the heads prevents steam pockets from forming. Steam does not absorb heat like liquid does, and heat builds up. This has all been scientifically proven.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: SportF]
#3289819
02/16/25 08:55 AM
02/16/25 08:55 AM
Posts: 3,950 Richmond, Indiana
19swinger70
Richmond, Indiana
I run a Jegs brand electric water pump in my bigblock. I do not run a thermostat. Works fine. I control it with a toggle switch / relay combo. My electric fan assembly has a fan controller that kicks on and off at specific temps - it can also be over ridden by a switch if I want it to kick on full blast before the controller wants to.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: topside]
#3289830
02/16/25 09:51 AM
02/16/25 09:51 AM
Posts: 6,706 nowhere
Sniper
nowhere
I inherited the restrictor on the racecar, and appreciated the overall simplicity and "bullet-proof-ness". Yes, there are a lot of bulletproof thinking in a race car and some of that does not apply to a street car. Like vacuum advance. I guess I am the type of guy that likes to know why something is done and not the type to monkey see monkey do. All that said, if something works for you well you can't argue against that all you can do is sort out why, if that is your kind of thing
[Re: Stanton]
#3289863
02/16/25 12:07 PM
02/16/25 12:07 PM
Hemi_Joel
Minnesota
how does one pressurize the coolant system above the radiator cap's rating ? And why would you ?!?!? When you have a thermostat or a washer, there are 2 zones of pressure. The higher pressure zone is between the water pump outlet and the thermostat. The pump builds pressure against the restriction. This is in addition to the overall pressure caused by rising temperature. This high pressure zone also happens to be where the block and heads are, where the heat is generated. The higher pressure in the block and heads helps prevent steam pockets. Water boils at a higher temperature when it is under higher pressure. The low pressure zone is between the thermostat and the water pump inlet. That is where the radiator and the radiator cap is. This area is subject only to the pressure caused by the temperature increase. It is protected from the pressure of the pump by the restrictive thermostat or washer. If you remove the thermostat, the next area of restriction is the radiator core tubes. If you have a top tank radiator, or a side tank radiator where the radiator cap is on the same side as the upper radiator hose, now your radiator cap will be subjected to the pump pressure. The pump pressure can push past the radiator cap spring , and you lose coolant. But there's a whole lot of variables. Most radiators have a large enough tube cross section and enough tubes that it's not going to build a lot of pump pressure in the radiator tank. It's not going to build a lot of pump pressure at all, possibly resulting in steam pockets in the heads. Too much restriction at the thermostat reduces flow. Reduced flow reduces the ability of the system to cool. Ideally there should be some kind of a balance between flow and pressure in the high pressure zone. Think of a garden hose flowing at a low rate. It's just kind of droobling out because there's no pressure. Now put your thumb over The end of the hose and try and shut off the water flow. Pressure will build in the hose until you can't hold it back. A pump can't build pressure without a restriction to build against.
[Re: moparx]
#3289866
02/16/25 12:17 PM
02/16/25 12:17 PM
jcc
No soup for you!!!
No soup for you!!!
how does one pressurize the coolant system above the radiator cap's rating ? It would be easy to apply static air pressure to a cooling system by simple use of shop air with a safety cap of the needed rating. The problem is, can the plumbing system handle it, and is it worth the added risk/complexity, even if is a benefit. In a racing environment, the safety crews would be working in a explosive super-heated coolant situation, much like a boiler. I suspect this solution would be beneficial first at the top race levels like, if allowed, in F1 or WEC.
[Re: Stanton]
#3289907
02/16/25 04:00 PM
02/16/25 04:00 PM
AndyF
The question is:can the thermostat be eliminated AND should I install a restrictor plate to slow down the flow through the system? You can eliminate the thermostat with an electric pump provided you pay attention to the temp gauge. Just don't turn the pump until the block water starts to get hot. Once the needle is up to 150 or so you can flip the pump on and start to circulate water. You have to be very careful about this since if you forget to turn the pump on you'll overheat the engine. Use warning lights to remind you. You never need a restrictor plate with a Meziere water pump. None of the Meziere pumps will flow enough water to justify a restrictor plate. The more water you can force thru the engine the better. With a Meziere pump, cooling increases as flow increases. Thanks for the input. The pump will be activated by the Terminator ECU - as will the fan - when the engine come ups to temp The beauty of the ECU is that these can be triggered seperately at different temps. Sounds like a good plan. Using the Holly ECU to turn the water pump and the fan on as engine temp comes up is a good solution. If you have a Holley digital dash you can program indicator lights on the dash to show you red dots when the fan and pump are off and green dots to show you when they are on. That gives you a feed back loop so you know that things are working. You can also program warning lights to come on if the temp gets above a certain number and/or you can program the engine to shut down at extreme temps.
[Re: jcc]
#3289921
02/16/25 05:18 PM
02/16/25 05:18 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
how does one pressurize the coolant system above the radiator cap's rating ? It would be easy to apply static air pressure to a cooling system by simple use of shop air with a safety cap of the needed rating. The problem is, can the plumbing system handle it, and is it worth the added risk/complexity, even if is a benefit. In a racing environment, the safety crews would be working in a explosive super-heated coolant situation, much like a boiler. I suspect this solution would be beneficial first at the top race levels like, if allowed, in F1 or WEC. More useless drivel !!
[Re: Stanton]
#3289923
02/16/25 05:26 PM
02/16/25 05:26 PM
jcc
No soup for you!!!
No soup for you!!!
how does one pressurize the coolant system above the radiator cap's rating ? It would be easy to apply static air pressure to a cooling system by simple use of shop air with a safety cap of the needed rating. The problem is, can the plumbing system handle it, and is it worth the added risk/complexity, even if is a benefit. In a racing environment, the safety crews would be working in a explosive super-heated coolant situation, much like a boiler. I suspect this solution would be beneficial first at the top race levels like, if allowed, in F1 or WEC. More useless drivel !! Because of your superior intellect you feel the need to point this out with no other contribution to those lesser, or are you just a tad envious in some regard?
