Engine stamping
#3287457
02/05/25 05:31 PM
02/05/25 05:31 PM
Posts: 884 Avondale AZ
Prodart440
Avondale AZ
Can someone tell me what this engine is out of? 1972 440, stamped on the side is 2C(maybe G)223463.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
Re: Engine stamping
[Re: Prodart440]
#3287566
02/06/25 09:54 AM
02/06/25 09:54 AM
Posts: 75,429 A gulag near you.
JohnRR
A gulag near you.
Can someone tell me what this engine is out of? 1972 440, stamped on the side is 2C(maybe G)223463. Is it an HP ? If not it's out of a C body or a Pickup , depends on what was built at Plant C. If it's a G, and it's an HP, it's out of a B body most likely, depends on what was built at St. Louis (G) at that time. Not an HP it wasn't built at St.Louis at that timeframe.
Mainstream Media is the new Pravda
Re: Engine stamping
[Re: JohnRR]
#3287629
02/06/25 02:58 PM
02/06/25 02:58 PM
Prodart440
Avondale AZ
It is definitely a "C". It is also has H440 stamped on the pad by the distributor. Does that make it a 1971?
Aaron
Re: Engine stamping
[Re: srt]
#3287664
02/06/25 04:56 PM
02/06/25 04:56 PM
Prodart440
Avondale AZ
Are there mill marks going in two directions across both pads? Hard to tell from the pics. Generally it's expected to see concentric mill marks aligned parallel from a single axis. In the late 80's - 90's re-stamps were getting going. Not saying that is the case in your pics. No, the ones going from left to right are from me wiping it off with a wire brush.
Aaron
Re: Engine stamping
[Re: JohnRR]
#3287707
02/06/25 07:51 PM
02/06/25 07:51 PM
Posts: 1,924 Harriman NY
71GTX471
Harriman NY
If it's a G, and it's an HP, it's out of a B body most likely, depends on what was built at St. Louis (G) at that time. Not an HP it wasn't built at St.Louis at that timeframe. [/quote]
You can get an HP440 in a C body I have a 71 C HP440.
Re: Engine stamping
[Re: 71GTX471]
#3288779
02/11/25 12:04 PM
02/11/25 12:04 PM
JohnRR
A gulag near you.
If it's a G, and it's an HP, it's out of a B body most likely, depends on what was built at St. Louis (G) at that time. Not an HP it wasn't built at St. Louis at that timeframe.
You can get an HP440 in a C body I have a 71 C HP440. Yes you can get an 440HP in a C body, but the non HP 440 was not available in a B in 1972 ... or any other year ...
