68-69 HEMI OWNERS help
#32868
12/24/06 12:55 PM
12/24/06 12:55 PM
i need some help finding out where the intake manifold vacuum tube fitting goes to and also there is another small stainleess tube going down behind the motor that sticks up in the back directly behind the motor even with the air cleaner, i think it goes to the air cleaner but not sure, any help greatly appeciated as the intake vacuum tube on my hemi engine is just plugged off.
Re: 68-69 HEMI OWNERS help
#32869
12/24/06 01:00 PM
12/24/06 01:00 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
The vacuum fitting will depend on the car it's going in.. Like, a Charger may have more nipples.. These are some pictures I have for reference for my '68 Hemi Charger...
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
#32870
12/24/06 01:01 PM
12/24/06 01:01 PM
hemi68charger
Houston, Tx
Another. From am unrestored '69 Hemi Charger R/T.
[Re: hemi68charger]
#32871
12/24/06 01:06 PM
12/24/06 01:06 PM
troy thanks, that works for my 69 hemi roadrunner but your 1st picture shows the back of your 68 motor and you have that intake manifold fitting not hooked up yet, where does that one go, the 69 hemi question is solved but now i need help with my 68 hemi roadrunner.
[Re: hemi68charger]
#32872
12/24/06 01:28 PM
12/24/06 01:28 PM
Posts: 6,570 San Francisco Ca
SCATPK
San Francisco Ca
Sorry to cut in but what is the green canister on the intake in your picture for? I have one in a box of old parts and always thought it was a california emmisions deal?
[Re: SCATPK]
#32873
12/24/06 01:33 PM
12/24/06 01:33 PM
69 hemi cars came with those, hooks up to your vacuum lines, i have one on my 69 hemi roadrunner, i am looking for info now on my 68 hemi roadrunner, where the vacuum fitting on back of the intake goes to.
#32876
12/24/06 02:24 PM
12/24/06 02:24 PM
Posts: 736 Virginia
rm23j8g
Virginia
That small steel tube behind the motor connects with a short vacuum type hose to the nipple on the bottom rear of the air cleaner base. It supplies clean air for the choke down to the exhaust manifold to get heated before it comes back up to the choke housing on the carb. If you have power brakes, the large vacuum fitting on the manifold fitting goes to the booster. There is a smaller vacuum nipple also that goes to that green cannister like the picture here in an earlier post on the '69. If, like most, the green cannnister has been removed, just be sure that small nipple on the manifold fitting is plugged and use the ported vacuum on the rear carb for distributor vacuum. My late '68 Roadrunner came with the green cannister, but it had been removed before I bought the car in '76. It has the large and small nipple manifold fitting and the original vacuum lines that used to connect the cannister were still in place. Oh, and I'd love to find an original cannister for my car! Quote:
[Re: rm23j8g]
#32877
12/24/06 02:35 PM
12/24/06 02:35 PM
THAT helps with the air cleaner issue for the 68 hemi car but still need info help on intake manifold nipple fitting on the back of the intake nanifold, where does that one go?
[Re: SCATPK]
#32878
12/24/06 03:04 PM
12/24/06 03:04 PM
Posts: 17,553 Las Vegas, NV
6bblgt
Las Vegas, NV
The 1969 Parts Catalog describes the "green canister" as:
8-27-335 VALVE and COVER, Distributor Vaccuum Control, w/Manual Transmission w/170 Eng. - # 2843 299 w/426 Eng. - # 2863 739
I thought they were '69 manual transmission only, as the listing in the parts catalog suggests; but the '69 Charger pic above is an automatic. What gives? I've heard the difference between the /6 and HEMI is the mounting bracket. Frank mitchell has them listed on ebay from time to time.
#32879
12/24/06 03:13 PM
12/24/06 03:13 PM
6bblgt
Las Vegas, NV
If you do not have power brakes, the only vacuum line on the engine of your '68 HEMI Road Runner should be the vacuum advance for the distributor.
[Re: 6bblgt]
#32880
12/24/06 03:28 PM
12/24/06 03:28 PM
vacuum line from the distributor i believe goes to the front port on the carburetor.
[Re: 6bblgt]
#32882
12/24/06 04:01 PM
12/24/06 04:01 PM
Posts: 26,977 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The green valve was also used on the '68 Hemi, both standard and automatic. It has three nipples, one goes to manifold vacuum, one to the rear carb timed port and the other to the distributor. In normal operation the valve lets the vacuum advance work as usual but under the high vacuum of deceleration it routes full manifold vacuum to the distributor. Full advance during deceleration helps clean up emissions. Here's one on my old '68 Hemi RR.
[Re: John_Kunkel]
#32883
12/24/06 04:21 PM
12/24/06 04:21 PM
does anyone know how late the green emissions cannister was used on 68 model hemis, i am prety sure the early 68 hemis did not have them
[Re: SCATPK]
#32884
12/24/06 04:28 PM
12/24/06 04:28 PM
Posts: 5,476 So Cal
Sinitro
So Cal
Back in the 60s'.. California had stricter smog requirements over the other 49 states.. And the green thing was in the vacuum line between the intake and the distributor. It would alter the advance under start and/or deceleration conditions. In 66 I bought a Belvedere II with a street hemi and had one on it for about a month..
I had a timing problem when I picked up the car from the dealer, and the lead mechanic had no idea how to time the hemi as the tune-up bulletins were not out yet.. He set the timing so it would at least start & run.. But not that good..
Got home pulled off and tossed the green thing, dropped in a Mallory distributor from J&S, set the timing like a traditional Mopar (36 total advance) and headed off to OCIR...
