Anyone have an early 1970s Crane catalog? #3286723
02/02/25 07:06 PM
02/02/25 07:06 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
---To look up specs on an obsolete set of lifters? The number is 69500. They have no plunger springs and valving. Just a puck under the pushrod plunger like a typical solid. But the pushrod plunger and puck prob has .050 to .080 clearance between when it's seated and even it slides up and tops out on the spring. Not even sure how lash would be set. Btw these were sealed and unopened so they weren't messed with.
Re: Anyone have an early 1970s Crane catalog? [Re: Hot 340] #3286755
02/02/25 09:37 PM
02/02/25 09:37 PM
oregon
greendart408 Offline
oregon
Doesn’t say a lot , I’ve showed you everything In the book about them. Not much
Re: Anyone have an early 1970s Crane catalog? [Re: greendart408] #3286949
02/03/25 06:08 PM
02/03/25 06:08 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Thank you! I think they are just plain solid lifters. Even though they didn't seem to refer to them as that. Looks like the "500" suffix meant solid and the "510" suffix meant hydraulic.
Re: Anyone have an early 1970s Crane catalog? [Re: greendart408] #3286952
02/03/25 06:12 PM
02/03/25 06:12 PM
A727Tflite Offline
A727Tflite  Offline
X
Re: Anyone have an early 1970s Crane catalog? [Re: greendart408] #3287019
02/03/25 09:50 PM
02/03/25 09:50 PM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
Is that a "mushroom" lifter pictured in that catalog?
I forbid my content here from being learned and used by artificial intelligence systems.
Re: Anyone have an early 1970s Crane catalog? [Re: jcc] #3287024
02/03/25 10:14 PM
02/03/25 10:14 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Looks like an old ford Y block type lifter and does go in from the bottom of course. Mushroom, but not like we view the newer performance ones.
STOP POTATO HATE!
