Cracked stage 5 Hemi heads #3286479
02/01/25 06:01 PM
02/01/25 06:01 PM
MI, usa
dvw Online content OP
dvw  Online Content OP
MI, usa
My friend has runover way to many Hemi parts. So the latest it broke some rod bolts. We won't go there. Now the new build. Last year brand new Stage 5 Hemi heads cnc by FHO.. Both cylinders that lost a rod have cracks in the head. I haven't personally looked but he claims no witness marks from the pistons contacting the chamber. Both are cracked from the plug outward. Timing and fuel have been sufficient to stop detonation. I haven't had Hemi stiff. But the cracks are puzzling to me. ??
Doug
Re: Cracked stage 5 Hemi heads [Re: dvw] #3286561
02/02/25 01:11 AM
02/02/25 01:11 AM
How old are those heads? work
Re: Cracked stage 5 Hemi heads [Re: dvw] #3286626
02/02/25 11:23 AM
02/02/25 11:23 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
You can see the porosity in the casting - there has been issues with some of the last run of castings - prior to FHO taking over from what I have heard - but those heads definitely look to have issues with the casting. either way those heads are junk now
Re: Cracked stage 5 Hemi heads [Re: dvw] #3286677
02/02/25 03:42 PM
02/02/25 03:42 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Doug
Geesh thats horrible. Have you spoken with Tim at FHO yet? He was involved in the Stage V stuff for a long time and if I understand correctly, often had to bail them out financially with orders. Tim would know.
RIP Monte Smith
