No idea, just going off the two videos posted. They said the car has been in the 6's with a different drivetrain and the current drivetrain was quicker in another car
Re: 4000hp 71 Hemicuda drag and drive car
[Re: Dart 500]
#3284780 01/24/2508:10 PM01/24/2508:10 PM
Broke a rod and tapped the wall. Matt is fine. Not sure how bad the damage is.
Car will need a new front end, door, and 1/4 panel. Hurts to see a good 71 Cuda grill get wiped out. Not as bad as I thought when I heard the news. Glad Matt is OK. He will be back, as this isn't going to stop him.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3285715 01/29/2506:08 AM01/29/2506:08 AM
Wow, hate seeing stuff like this. I understand all the fast cars seem to be running belt driven oil pumps. Never liked the idea of that. I know Steve Morris had an oil pump belt fall off and found it only after making a pass. No damage was found on the tear down. He has been using an oil additive RevX and now swears by it. On a side note pertaining to belt driven oil pumps, did you know that Ford uses a belt driven oil pump in the pan on their 2.7 Eco Boost. Sounds like another bad idea to me.
It's really sad to see that car get wrecked. But wonderful that Matt is okay. Hopefully it's not too hard to fix and doesn't knock the wind out of his sails for too long. The thing that popped into my head is that if the race, the race car, and the driver's own personal safety all depend upon that oil pump belt doing its job, maybe a guy could figure out a way to protect it. So that if the alternator belt flies off or some other peril, that it doesn't take the oil pump belt with it? This isn't the first time I've heard of this happening.
[img]http://i.imgur.com/boeexFms.jpg[/img] 31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3285785 01/29/2511:40 AM01/29/2511:40 AM
