4000hp 71 Hemicuda drag and drive car #3284599
01/23/25 09:54 PM
01/23/25 09:54 PM
Nor here, Nor there
Dart 500 Offline OP
Dart 500  Offline OP
Nor here, Nor there
Just popped up in my feed, looks pretty serious. Tuned by the guy that ran the primered 71 Dart that ran 7's years ago. Its 652 inch with twin 102's
Re: 4000hp 71 Hemicuda drag and drive car [Re: Dart 500] #3284756
01/24/25 03:56 PM
01/24/25 03:56 PM
Quakertown PA
Tay Offline
Tay  Offline
Quakertown PA
Awesome looking car, Hemi 99 ? correct ?
Re: 4000hp 71 Hemicuda drag and drive car [Re: Tay] #3284779
01/24/25 07:58 PM
01/24/25 07:58 PM
Nor here, Nor there
Dart 500 Offline OP
Dart 500  Offline OP
Nor here, Nor there
No idea, just going off the two videos posted. They said the car has been in the 6's with a different drivetrain and the current drivetrain was quicker in another car
Re: 4000hp 71 Hemicuda drag and drive car [Re: Dart 500] #3284780
01/24/25 08:10 PM
01/24/25 08:10 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
No doubt it’s a great looking 71 Cuda,shame it’s not a Mopar Hemi
Re: 4000hp 71 Hemicuda drag and drive car [Re: Tay] #3284834
01/25/25 10:06 AM
01/25/25 10:06 AM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
That is a Goodwin hemi.
Re: 4000hp 71 Hemicuda drag and drive car [Re: OUTLAWSSAA] #3284860
01/25/25 11:34 AM
01/25/25 11:34 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
It is a 5" Borespace 99/06, and yes a Goodwin staple for his truckpull stuff
Re: 4000hp 71 Hemicuda drag and drive car [Re: Al_Alguire] #3284875
01/25/25 12:37 PM
01/25/25 12:37 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
Rick Mcleod jr's old car. it was run with a procharged big block before it sold. went 200+
Re: 4000hp 71 Hemicuda drag and drive car [Re: chrisf] #3285075
01/26/25 12:13 PM
01/26/25 12:13 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Re: 4000hp 71 Hemicuda drag and drive car [Re: OUTLAWSSAA] #3285122
01/26/25 03:27 PM
01/26/25 03:27 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Super cool Cuda, and Matt is a great tuner.
Re: 4000hp 71 Hemicuda drag and drive car [Re: ProSport] #3285230
01/26/25 10:30 PM
01/26/25 10:30 PM
Nor here, Nor there
Dart 500 Offline OP
Dart 500  Offline OP
Nor here, Nor there
Re: 4000hp 71 Hemicuda drag and drive car [Re: ProSport] #3285601
01/28/25 03:49 PM
01/28/25 03:49 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Broke a rod and tapped the wall. Matt is fine. Not sure how bad the damage is.
Re: 4000hp 71 Hemicuda drag and drive car [Re: ksj] #3285714
01/29/25 06:00 AM
01/29/25 06:00 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Car will need a new front end, door, and 1/4 panel. Hurts to see a good 71 Cuda grill get wiped out. Not as bad as I thought when I heard the news. Glad Matt is OK. He will be back, as this isn't going to stop him.
69 GTX 68 Road Runner
Re: 4000hp 71 Hemicuda drag and drive car [Re: JERICOGTX] #3285715
01/29/25 06:08 AM
01/29/25 06:08 AM
Mo.
racerx Offline
racerx  Offline
Mo.
https://youtu.be/pd7dxlX9wB0?si=Zbz32gpYCL4VXN14
For those that have not seen it .
Re: 4000hp 71 Hemicuda drag and drive car [Re: racerx] #3285720
01/29/25 07:34 AM
01/29/25 07:34 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Wonder what caused it to kick a rod? Curious to see if it was just one, or more...
Re: 4000hp 71 Hemicuda drag and drive car [Re: Dragula] #3285724
01/29/25 08:01 AM
01/29/25 08:01 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Alternator belt flew off, taking out the Dry Sump belt, which means zero oil pressure.
Re: 4000hp 71 Hemicuda drag and drive car [Re: JERICOGTX] #3285741
01/29/25 09:23 AM
01/29/25 09:23 AM
Dragula Offline
Dragula  Offline
Aaaw man, that is a crazy way to go thru a small fortune for a stupid $40/belt!
Re: 4000hp 71 Hemicuda drag and drive car [Re: Dragula] #3285771
01/29/25 11:15 AM
01/29/25 11:15 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Wow, hate seeing stuff like this. I understand all the fast cars seem to be running belt driven oil pumps. Never liked the idea of that. I know Steve Morris had an oil pump belt fall off and found it only after making a pass. No damage was found on the tear down. He has been using an oil additive RevX and now swears by it.
On a side note pertaining to belt driven oil pumps, did you know that Ford uses a belt driven oil pump in the pan on their 2.7 Eco Boost. Sounds like another bad idea to me.
Re: 4000hp 71 Hemicuda drag and drive car [Re: mopar dave] #3285775
01/29/25 11:22 AM
01/29/25 11:22 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
It's really sad to see that car get wrecked. But wonderful that Matt is okay. Hopefully it's not too hard to fix and doesn't knock the wind out of his sails for too long.
The thing that popped into my head is that if the race, the race car, and the driver's own personal safety all depend upon that oil pump belt doing its job, maybe a guy could figure out a way to protect it. So that if the alternator belt flies off or some other peril, that it doesn't take the oil pump belt with it? This isn't the first time I've heard of this happening.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 4000hp 71 Hemicuda drag and drive car [Re: Hemi_Joel] #3285785
01/29/25 11:40 AM
01/29/25 11:40 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I agree. Seems like someone would make a deep pulley for that.
Re: 4000hp 71 Hemicuda drag and drive car [Re: mopar dave] #3285795
01/29/25 12:14 PM
01/29/25 12:14 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
maybe kicked a rod and threw the belts....
