To Delete or not Delete, that is the question #3284471
01/23/25 01:22 PM
01/23/25 01:22 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
So I took my truck in for it going into limp mode and saying the dpf is plugged...They called and told me its time to delete it. Probably has a leaky injector. I have a Smarty S67 programmer already, but none of the kits are offered to use with one....What say you guys?
Re: To Delete or not Delete, that is the question [Re: Dragula] #3284567
01/23/25 07:05 PM
01/23/25 07:05 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
who is "they" who told you to delete it? Dealer? I know this is a little like apples and oranges the guy I know of that works at International (yeah I know, bigger trucks) who tells me all the time of deleted trucks that come in, and pulled right back out after telling the owner that they refuse to work on their truck further until the owner either 1. takes said truck back and reinstalls everything "as built" and then brings it back for desired service, or (2) pays the International dealer to do so before/ or in conjunction with whatever else the truck was brought in for....
Someone I know has a 17 Ram 2500 that is deleted and keeps getting bugged by Chrysler to bring that truck in for 2 recalls.... one has something to do with emissions and the other is the ABS HCU controller and doesn't know what will happen if he takes it in (hopefully) just for the brake system recall.... once in their hands I don't think they can release it back to him without having done both recalls.... this isn't like (pre OBD II) where people took their "cats" off and put a straight pipe in... because of the "rolling coal" idiots, they are taking a harder stance on diesels.....
I dunno that I would in these days..... I've considered buying a Cummins truck off n on, but if I do it will be a pre DEF model.
Re: To Delete or not Delete, that is the question [Re: Dragula] #3284634
01/24/25 07:57 AM
01/24/25 07:57 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
If it's your personal truck I say go for it. If it's got a DOT number I wouldn't. I haven't had our company pickup tested the few times I went thru a DOT stop yet.
Re: To Delete or not Delete, that is the question [Re: volaredon] #3284661
01/24/25 10:14 AM
01/24/25 10:14 AM
Dragula Offline OP
Dragula  Offline OP
Its +$8k to replace the "filter" and stuff that isn't actually a filter, but a plugged exhaust according to the shop....A filter by definition you are able to take the lid off and replace it...An entire exhaust system replacement is not a "filter" so I am not about to pay $8k for a filter replacement & injectors. I would rather light it on fire and bring marsh mellows. I have owned Cummins diesels since '98, and this is my first emissions one, and my last one for sure. They screwed this all up, and I am stuck with it. This system does not work, and it is not feasibly serviceable. The engine light came on the day I drove it home, and its been on over 50% of the time I have owned it. My last trucks you only saw the engine light when somthing went really wrong, and that was rare.
Personally I could poke them in the eye leaving us out to dry without a solution like this...At this point, I don't see any other solution available and I am not happy about it.
I get that the gubment took the sulfur out of the fuel and then required the companies to meet emissions, but jumpen geewhosafit, this Cummins emission reduction plan does not work. Its probably a worn injector that is plugging up my exhaust, but if you make the injectors $1000/inj and impossible to change out, or figure out which one it is, this is where you go round and round spending money for nothing. V8 engines will be insured a long life thanks to these kinds of diesel emissions solutions.
Re: To Delete or not Delete, that is the question [Re: Dragula] #3284687
01/24/25 12:21 PM
01/24/25 12:21 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I'd delete it... but your done taking it to a dealer there after. You would then need to find an empathetic shop ( they are out there) for future work twocents
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: To Delete or not Delete, that is the question [Re: volaredon] #3284690
01/24/25 12:28 PM
01/24/25 12:28 PM
Enjoy life today, It has an ex...
gtx6970 Offline
gtx6970  Offline
Once in dealers hands ALL recalls will be done. No exception
Enjoy life today, It has an expiration date
Re: To Delete or not Delete, that is the question [Re: W.I.N. Racing] #3284702
01/24/25 01:03 PM
01/24/25 01:03 PM
Dragula Offline OP
Dragula  Offline OP
Ooh I found a shop..They are the ones that said they would delete it as long as I order the parts. I am just surprised this is what it has turned into. I do not have the time to do this at the moment. Timing could not be worse.
Re: To Delete or not Delete, that is the question [Re: Dragula] #3284838
01/25/25 10:20 AM
01/25/25 10:20 AM
Dragula Offline OP
Dragula  Offline OP
I ordered the parts....its getting deleted.
Re: To Delete or not Delete, that is the question [Re: Dragula] #3285046
01/26/25 10:20 AM
01/26/25 10:20 AM
Chesterfield Twp. Mi.
John Burdine Offline
What year is your truck? Let us know how it runs/works out after the delete.
Re: To Delete or not Delete, that is the question [Re: John Burdine] #3285204
01/26/25 09:14 PM
01/26/25 09:14 PM
Dragula Offline OP
Dragula  Offline OP
2011
Re: To Delete or not Delete, that is the question [Re: Dragula] #3285296
01/27/25 10:31 AM
01/27/25 10:31 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I didn't think they had all that crap on diesel then... I know a guy who had a 12 and as I remember that was supposed to be the last year "without".
Re: To Delete or not Delete, that is the question [Re: Dragula] #3285324
01/27/25 12:15 PM
01/27/25 12:15 PM
Byron, NY
Byron, NY
'60 Willys CJ5
Re: To Delete or not Delete, that is the question [Re: volaredon] #3285520
01/28/25 10:09 AM
01/28/25 10:09 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
i think 09 was the last year without , I have a 2000 parts truck and my daily is a 98 , I won't ever by anything newer and starting I believe with 2026 all new cars will have a camera pointing at the driver so at that point it's all used cars for me .
Mainstream Media is the new Pravda
Re: To Delete or not Delete, that is the question [Re: Dragula] #3285889
01/29/25 10:21 PM
01/29/25 10:21 PM
Alberta
440_Offroader Offline
Alberta
I had a 2011 work truck which we deleted the DPF, the EGR and had an H&S tuner installed. Way better truck after that. It had way quicker spool up/acceleration and fuel mileage went from 9mpg to 17mpg. You'll be glad you deleted it and be wondering why you didn't sooner.
Re: To Delete or not Delete, that is the question [Re: Dragula] #3286033
01/30/25 07:39 PM
01/30/25 07:39 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
2011
The only 08-12 CTDs that were happy were the ones that got worked HARD and OFTEN. I sent many of that era to “a guy” to perform lightening duties.
That said I have NO intentions of deleting my 17. I rather enjoy starting it up in the garage and not stinking up the whole place. Of course I do have the advantage of having all the tech available to work on these units, and the fore mentioned “guy” has supplied me with plenty of spare parts to keep my rig running for many years. To date I’ve had ZERO issues with my 17, but it just rolled 40k miles and rarely leaves the yard without a trailer.
Re: To Delete or not Delete, that is the question [Re: J_BODY] #3286420
02/01/25 12:59 PM
02/01/25 12:59 PM
Dragula Offline OP
Dragula  Offline OP
Drove it home last night in a small snow storm, and it runs much better...Seems like it has more get up and go. Even sounds different.. The entire exhaust system was removed and replace right up to the down pipe...If anyone wants the old one.... Along with the Smarty tuner if interested.
It now has some kind of little LCD screen and a whole bunch of info on it. I think its the new tuner for it. Not used to that.
Also, since I am stuck with it since putting in $5k last year, and $3400 this go around, where can I get a factory Nav radio or a fair priced replacement? Mine has been giving me issues.
Re: To Delete or not Delete, that is the question [Re: Dragula] #3286796
02/03/25 08:31 AM
02/03/25 08:31 AM
Dragula Offline OP
Dragula  Offline OP
Drove it to work today, and its snappy for such a big truck...I noticed the new tuner is plugged into the OBDII port all the time. Didn't know that when I bought it...So I am thinking they did not back the program out from the Smarty, and now its stacked on top of it. Going to give them a call on it today if I have time. I had the Smarty set at the +90hp tune up, and its definitely making more than that now. Not sure I want to leave it that way when towing. Engine is rated at 350hp & 660 torque in stock form. With the Smarty its at +90/180 and that has been great. But its making more than that now.
Also, my fuel mileage went thru the roof. Dash readout says I am getting 23.7mpg now. Never seen anywhere near that before. It was telling me before all this happened 13-14mpg which is really low as its usually right around 17.8-18mpg super consistently, which when I checked it was really a solid 15mpg actual average per tank. So it looks like its definitely worth the fuel savings and hopefully gets rid of all the damn codes I was getting from the stock system. I can't take anymore codes that make it go into limp mode.
So if you have one of these time bombs.....Delete away!
Re: To Delete or not Delete, that is the question [Re: Dragula] #3286820
02/03/25 10:23 AM
02/03/25 10:23 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
................where can I get a factory Nav radio or a fair priced replacement? Mine has been giving me issues.
If you have a Best Buy near you, try them. EDIT: (my link didn't work) Go to their website to car audio and there's a place to input your make/model/year. You'll have multiple choices...
Glad your delete dilemma worked out well for you. up
Re: To Delete or not Delete, that is the question [Re: Dragula] #3287059
02/04/25 08:30 AM
02/04/25 08:30 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
You’ve changed the parameters that the factory calculates those numbers. While I’d expect that you’ll see an mpg improvement, do it on paper. My old 01 would often say 22-24, but paper said otherwise.
Re: To Delete or not Delete, that is the question [Re: J_BODY] #3287064
02/04/25 08:48 AM
02/04/25 08:48 AM
Dragula Offline OP
Dragula  Offline OP
I will be doing the math when I fill it up.....Its still saying I am getting 22mpg, which if I apply that the way it was before, It would read 18 and give me 15, I should see an actual 19mpg on fill up...
Re: To Delete or not Delete, that is the question [Re: JohnRR] #3287149
02/04/25 02:07 PM
02/04/25 02:07 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I have an '09 and it had DPF but was deleted before I bought it with 100k miles. It now has 443,000 and runs like a new truck. Only replacement parts have been normal wear items like alternator, a/c compressor and water pump. They all lasted until high 300,000's.
I did put a flexplate on it last year after it cracked but it runs so good it's hard to sell it and have a payment at this point!
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: To Delete or not Delete, that is the question [Re: GY3] #3287327
02/05/25 08:38 AM
02/05/25 08:38 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Having been deleted that long i best the oil is clean….. pretty cool after the process has been done how they clean themselves out.
Re: To Delete or not Delete, that is the question [Re: J_BODY] #3287367
02/05/25 10:35 AM
02/05/25 10:35 AM
Dragula Offline OP
Dragula  Offline OP
I will tell you one thing, I am never buying another, unless its deleted or deletable. No way, no how.....
Re: To Delete or not Delete, that is the question [Re: Dragula] #3287386
02/05/25 11:57 AM
02/05/25 11:57 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
No DPF on a Dodge/Ram until 2013, I went from a 2015 with a crap DPF system to a 2010 because if did not have DPF. I had a 2007 with the EGR system that was crap, had to regen often. I still may delete the EGR on the 2010 my diesel mechanic recommended it.
JB Rhinehart, Realist
A-Body's RULE!
Re: To Delete or not Delete, that is the question [Re: Rhinodart] #3287714
02/06/25 08:07 PM
02/06/25 08:07 PM
Dragula Offline OP
Dragula  Offline OP
Got below 1/2 tank today and filled it up...Did the math, and its actually getting 14.5mpg....To be fair, its been a nasty cold winter, and I am letting it idle some, but this shows me the computer is not calculating DTE or mileage correctly....Not even close.
Re: To Delete or not Delete, that is the question [Re: Dragula] #3287994
02/07/25 08:35 PM
02/07/25 08:35 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
You’ve manipulated the data….. throw those display numbers out the window. You’re on your own now!
