Page 1 of 3 1 2 3
The road to SICK WEEK 2025!! #3260570
09/28/24 11:27 AM
09/28/24 11:27 AM
Minnesota
Hemi_Joel Offline OP
Minnesota
Who got in for Sick Week? The registration landrush was this morning.
Racing 5 days at a Drag Week style event in Florida in late January has a lot of appeal for so many reasons!
I'm in. I need to redeem myself from my day 4 DNF at Sick Week 2024. I wear the shame like a millstone around my neck, and there is only one way to free myself of this burden. That process would be:
  • Enter the event (done)
  • re-assemble engine
  • re-assemble car
  • fix everything on the list
  • dyno test
  • track test to dial in the suspension, tires and clutch
  • make it to the event on time
  • finish the event
So I'm off to a good start, first item accomplished. With that out of the way, the rest should be a piece of cake! The event isn't until late January, so I have plenty of time to goof off and relax before I get started on the hot rod.
Edit : apparently nobody else on Moparts got signed up, so I'll convert this over to a blog of getting ready for and attending the event.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: SICK WEEK 2025!! [Re: Hemi_Joel] #3260767
09/29/24 02:02 PM
09/29/24 02:02 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Looking forward to all the updates up
Re: SICK WEEK 2025!! [Re: fast68plymouth] #3260773
09/29/24 02:47 PM
09/29/24 02:47 PM
BDW Offline
BDW  Offline
Go for it! Looking forward to hearing the action.
I'm local, so will definitely be there a few days.
Re: SICK WEEK 2025!! [Re: BDW] #3260779
09/29/24 03:38 PM
09/29/24 03:38 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Joel, START NOW!!!
Re: SICK WEEK 2025!! [Re: Hemi_Joel] #3260830
09/30/24 05:10 AM
09/30/24 05:10 AM
MN
JERICOGTX Online laugh2
MN
Fixed your list for you.
  • Goof Off
  • Say I need to clean my Pole Barn, because it's a mess.
  • Goof Off
  • Spend a couple weeks in Arizona
  • Get sick/ throw out back
  • Watch a squirrel run across the yard
  • Ask Jeff if he can help with car, since I'm way behind
  • Decide it's too late to take the Coop
  • Take the 442, and enjoy the event, because I already paid.
  • finish the event
69 GTX 68 Road Runner
Re: SICK WEEK 2025!! [Re: JERICOGTX] #3260834
09/30/24 06:36 AM
09/30/24 06:36 AM
Mo.
racerx Offline
racerx  Offline
Mo.
  • Goof Off
  • Goof Off
  • finish the event
laugh2
Re: SICK WEEK 2025!! [Re: JERICOGTX] #3260975
09/30/24 04:50 PM
09/30/24 04:50 PM
Minnesota
Minnesota
  • Goof Off
  • Goof Off
  • finish the event
You know me pretty well! But I seriously want to make sick weekend the HemiCoupe.
I've got two other car projects that I will be working on simultaneously, plus the building project. And I am short of storage space so I was thinking about driving the 442 down to Arizona before winter and leave it in the garage there to free up space here. Then fly home. And I need to allow plenty of time for goofing off.
But nevertheless, I think I can get the coupe done in time. Then get down south before the event and get some testing done.
I made more progress today, I ordered new rod bearings, cam bearings, and an oil cooler. I already have new rings and the block is honed and ready to go.
Since apparently nobody else from Moparts got entered, I'll just make this thread my get ready for sick week blog and then my event blog.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: SICK WEEK 2025!! [Re: Hemi_Joel] #3261125
10/01/24 04:48 AM
10/01/24 04:48 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Am afraid Jeff is spot on with his list.
Re: The road to SICK WEEK 2025!! [Re: Hemi_Joel] #3261151
10/01/24 07:59 AM
10/01/24 07:59 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
  • re-assemble car
  • dyno test
  • finish the event
This is a bucket list thing for me , I retire in 2 to 3 years maybe then I'll have the time to do it .
Good Luck Joel , I'll be waiting to read about your adventure.
Mainstream Media is the new Pravda
Re: The road to SICK WEEK 2025!! [Re: JohnRR] #3272305
11/25/24 10:58 AM
11/25/24 10:58 AM
Minnesota
Minnesota
Okay so Jeff's list is pretty accurate. I spent a few weeks getting the pole barn cleaned up so I'd have a reasonably efficient work area. Then I drove the 442 down to Arizona to free up some space in my shop and flew back home. Now I'm finally getting started on getting the Hemi coupe ready for sick week. The reason the Hemi was torn apart was that the cap screws that hold the cam from moving forward had loosened up, the cam moved forward, the lobes and the journals rubbed on the adjacent lifters, some shavings from that got into the oil pump and seized it up , shearing off the oil pump drive shaft.
So step one was to take a honing stone and get all of the burrs cleaned up off of the camshaft.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: The road to SICK WEEK 2025!! [Re: Hemi_Joel] #3272332
11/25/24 02:03 PM
11/25/24 02:03 PM
MN
MN
I hope you skip over the Get Sick/ Throw out your back part this year, and get have plenty of time for squirrel watching.
Re: The road to SICK WEEK 2025!! [Re: JERICOGTX] #3283892
01/21/25 02:00 AM
01/21/25 02:00 AM
Minnesota
Minnesota
Good news update: The Hemi coupe is all back together and ready to load into the trailer for sick week! I got registered for the two early test and tune sessions for the two days prior to the beginning of the event, so hopefully with that opportunity I can get the clutch and the suspension dialed in and get everything working right. Including the Nut behind the Wheel. realcrazy
Maybe even a new personal best? Maybe even a 9-second time slip!??? drive
It's 20° below zero, it'll be cold getting everything loaded into the trailer. nervous
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: The road to SICK WEEK 2025!! [Re: Hemi_Joel] #3283898
01/21/25 05:46 AM
01/21/25 05:46 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Good luck Joel, getem'!!
Re: The road to SICK WEEK 2025!! [Re: quickd100] #3283906
01/21/25 08:39 AM
01/21/25 08:39 AM
gregsdart Offline
gregsdart  Offline
Have fun! Love the coupe! And the early hemi is the icing on the cake!
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: The road to SICK WEEK 2025!! [Re: Hemi_Joel] #3283935
01/21/25 11:41 AM
01/21/25 11:41 AM
So. Burlington, Vt.
So. Burlington, Vt.
Good luck Joel!! up
Hoping you get some new bests and finish the week!!
Re: The road to SICK WEEK 2025!! [Re: fast68plymouth] #3283949
01/21/25 12:12 PM
01/21/25 12:12 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Have fun Joel!
Re: The road to SICK WEEK 2025!! [Re: Hemi_Joel] #3284007
01/21/25 02:34 PM
01/21/25 02:34 PM
MN
MN
I see a 10.01 in your future...
Re: The road to SICK WEEK 2025!! [Re: JERICOGTX] #3284027
01/21/25 03:16 PM
01/21/25 03:16 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
That's just cruel. haha
Re: The road to SICK WEEK 2025!! [Re: John Brown] #3284031
01/21/25 03:23 PM
01/21/25 03:23 PM
MN
MN
It was meant to be.
Re: The road to SICK WEEK 2025!! [Re: JERICOGTX] #3284070
01/21/25 05:44 PM
01/21/25 05:44 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Good luck, Joel!!!!
Page 1 of 3 1 2 3
