The road to SICK WEEK 2025!!
#3260570
09/28/24 11:27 AM
09/28/24 11:27 AM
Posts: 7,574 Minnesota
Hemi_Joel
Minnesota
Who got in for Sick Week? The registration landrush was this morning. Racing 5 days at a Drag Week style event in Florida in late January has a lot of appeal for so many reasons! I'm in. I need to redeem myself from my day 4 DNF at Sick Week 2024. I wear the shame like a millstone around my neck, and there is only one way to free myself of this burden. That process would be: - Enter the event (done)
- re-assemble engine
- re-assemble car
- fix everything on the list
- dyno test
- track test to dial in the suspension, tires and clutch
- make it to the event on time
- finish the event
So I'm off to a good start, first item accomplished. With that out of the way, the rest should be a piece of cake! The event isn't until late January, so I have plenty of time to goof off and relax before I get started on the hot rod. Edit : apparently nobody else on Moparts got signed up, so I'll convert this over to a blog of getting ready for and attending the event.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: SICK WEEK 2025!!
[Re: Hemi_Joel]
#3260830
09/30/24 05:10 AM
09/30/24 05:10 AM
Posts: 10,125 MN
JERICOGTX
MN
Fixed your list for you. I'm in. I need to redeem myself from my day 4 DNF at Sick Week 2024. I wear the shame like a millstone around my neck, and there is only one way to free myself of this burden. That process would be: - Enter the event (done)
- Goof Off
- Say I need to clean my Pole Barn, because it's a mess.
- Goof Off
- Spend a couple weeks in Arizona
- Get sick/ throw out back
- Watch a squirrel run across the yard
- Ask Jeff if he can help with car, since I'm way behind
- Decide it's too late to take the Coop
- Take the 442, and enjoy the event, because I already paid.
- finish the event
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3260834
09/30/24 06:36 AM
09/30/24 06:36 AM
Posts: 4,183 Mo.
racerx
Mo.
- Goof Off
- Goof Off
- finish the event
[Re: JERICOGTX]
#3260975
09/30/24 04:50 PM
09/30/24 04:50 PM
Hemi_Joel
Minnesota
- Goof Off
- Goof Off
- finish the event
So I'm off to a good start, first item accomplished. With that out of the way, the rest should be a piece of cake! The event isn't until late January, so I have plenty of time to goof off and relax before I get started on the hot rod. You know me pretty well! But I seriously want to make sick weekend the HemiCoupe. I've got two other car projects that I will be working on simultaneously, plus the building project. And I am short of storage space so I was thinking about driving the 442 down to Arizona before winter and leave it in the garage there to free up space here. Then fly home. And I need to allow plenty of time for goofing off. But nevertheless, I think I can get the coupe done in time. Then get down south before the event and get some testing done. I made more progress today, I ordered new rod bearings, cam bearings, and an oil cooler. I already have new rings and the block is honed and ready to go. Since apparently nobody else from Moparts got entered, I'll just make this thread my get ready for sick week blog and then my event blog.
Re: The road to SICK WEEK 2025!!
[Re: Hemi_Joel]
#3261151
10/01/24 07:59 AM
10/01/24 07:59 AM
Posts: 75,353 A gulag near you.
JohnRR
A gulag near you.
- re-assemble car
- dyno test
- finish the event
So I'm off to a good start, first item accomplished. With that out of the way, the rest should be a piece of cake! The event isn't until late January, so I have plenty of time to goof off and relax before I get started on the hot rod. Edit : apparently nobody else on Moparts got signed up, so I'll convert this over to a blog of getting ready for and attending the event. This is a bucket list thing for me , I retire in 2 to 3 years maybe then I'll have the time to do it . Good Luck Joel , I'll be waiting to read about your adventure.
Mainstream Media is the new Pravda
[Re: JohnRR]
#3272305
11/25/24 10:58 AM
11/25/24 10:58 AM
Hemi_Joel
Minnesota
Okay so Jeff's list is pretty accurate. I spent a few weeks getting the pole barn cleaned up so I'd have a reasonably efficient work area. Then I drove the 442 down to Arizona to free up some space in my shop and flew back home. Now I'm finally getting started on getting the Hemi coupe ready for sick week. The reason the Hemi was torn apart was that the cap screws that hold the cam from moving forward had loosened up, the cam moved forward, the lobes and the journals rubbed on the adjacent lifters, some shavings from that got into the oil pump and seized it up , shearing off the oil pump drive shaft.
So step one was to take a honing stone and get all of the burrs cleaned up off of the camshaft.
[Re: Hemi_Joel]
#3272332
11/25/24 02:03 PM
11/25/24 02:03 PM
Posts: 10,125 MN
JERICOGTX
MN
I hope you skip over the Get Sick/ Throw out your back part this year, and get have plenty of time for squirrel watching.
69 GTX
68 Road Runner
