OEM Valve Body and low band apply #3284063
01/21/25 05:10 PM
01/21/25 05:10 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Despite being 9 degrees outside, I decided to start on rebuilding the transmission for the Belvedere. It was suppose to have a manual valve body, when I opened it up, it had a OEM valve body. I haven't opened the valve body yet to see if it had been modified. I thought I read somewhere that all OEM valve bodies were low band applied, so if that is true if it has been been modified would it still retain the low band applied? Or when they are modified typically does it remove LBA?
'75 Plymouth Duster
‘65 Plymouth Belvedere
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: OEM Valve Body and low band apply [Re: clovis] #3284069
01/21/25 05:44 PM
01/21/25 05:44 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
How do you know it is an OEM valve body? Factory Valve bodies have LBA in the manual 1st gear selection. In drive they do not. However if something broke in the drivetrain the governer would force a 1/2 shift. They also require throttle pressure linkage or a aftermarket cable for proper line pressure. If it didn't slip under load and had no throttle pressure control? My bet is it's modified. There are mny different types of valve bodies by year. Some have parts that others don't. Different people modify them different ways. If you are taking it apart make sure you take pictures. Disassemble it very carefully and slowly. Could have hidden check balls where they don't normally go. Why are you taking it apart in the first place? Unless it's cleaning or adding a shift kit you are asking for trouble.
Doug
Re: OEM Valve Body and low band apply [Re: dvw] #3284075
01/21/25 06:00 PM
01/21/25 06:00 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
At first glance, it might look like the OE valve body. It's what is done inside that matters. Separator plate will be different. Valves missing. Machine work done internally.
Probably not the one you want to be the first one you take apart. Pictures would help.
Re: OEM Valve Body and low band apply [Re: CMcAllister] #3284118
01/21/25 08:00 PM
01/21/25 08:00 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
I got the transmission with an engine I bought. He said it was fresh and had a manual valve body. It had a 8” turbo action converter with it. I kinda considered it a free transmission as I would have paid what I did just for the engine. I knew I wanted an extra trans as my intent was to have an trans available when I finally bought a b body, which I have now. I just need to set it up for around 650-700 hp.
I was thinking it was OEM because it had the Mopar emblem on it and 2801295 seems to be a common plate for Chrysler.
I would like to have LBA as that is what I use in my Duster, so I was curious if I needed to start shopping for a new VB or there was a chance this one was already LBA.
'75 Plymouth Duster
Re: OEM Valve Body and low band apply [Re: clovis] #3284121
01/21/25 08:15 PM
01/21/25 08:15 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Check the separator plate, i believe turbo action engraves them. Should have a part# too.
Re: OEM Valve Body and low band apply [Re: rickraw] #3284128
01/21/25 09:15 PM
01/21/25 09:15 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
The “55” is the only non cast I see.
'75 Plymouth Duster
Re: OEM Valve Body and low band apply [Re: clovis] #3284141
01/21/25 10:09 PM
01/21/25 10:09 PM
A727Tflite Offline
A727Tflite  Offline
Looks like a manual shift in the second to last image.
Re: OEM Valve Body and low band apply [Re: clovis] #3284282
01/22/25 01:33 PM
01/22/25 01:33 PM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
The OEM steel separator plate (on the right below) will have five holes on the rear, the RMVB will have only four because one governor port is eliminated. It could still be a forward manual VB build from a kit.
Re: OEM Valve Body and low band apply [Re: John_Kunkel] #3285857
01/29/25 07:01 PM
01/29/25 07:01 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Finally got around to taking it apart.
It looks like there are only two check balls. It has been drilled to open up a channel near the center. It looks like there were four walls removed.
'75 Plymouth Duster
Re: OEM Valve Body and low band apply [Re: clovis] #3285911
01/30/25 08:33 AM
01/30/25 08:33 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I have seen a lot of manual valve bodies that were not marked with who made them. Transgo used to make a manual valve body kit and I have built several of those and they were LBA, no partitions were removed, been a while ago since I did one. From your pictures it is a manual valve body, I am not smart enough to just look at what partitions have been cut out to tell you if it applies the low band or not. LBA is safer of course but over the years they are a little slower. The low reverse servo was not designed to release fast, main reason a lot of valve bodies do not hold the low band. I would look at the low servo and see if it looks like it has been modified. All the LBA valve bodies I have seen also modify the servo.
Re: OEM Valve Body and low band apply [Re: jwb123] #3285916
01/30/25 10:12 AM
01/30/25 10:12 AM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
From the pictures it looks like a manual VB and most likely a reverse pattern. Was there a solid rod in the pressure port? Way back in the day Chrysler sold both those pieces over the counter (I bought them in 1973 for my trans) like said each year trans was a little different. TransGo makes a shift improver kit that keeps the trans in stock mode. Most all used the stock VB with changes inside, a few today are made from scratch.
Re: OEM Valve Body and low band apply [Re: clovis] #3285933
01/30/25 11:59 AM
01/30/25 11:59 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Compare the steel separator plate to the ones I posted...definitely a RMVB but the removed channel walls are out of the ordinary. That's necessary in the transfer plate but not in the valve body casting. shruggy
Only one of the balls in the VB is a "check" ball, the one with the spring under it is a pressure relief ball.
Re: OEM Valve Body and low band apply [Re: John_Kunkel] #3285964
01/30/25 01:55 PM
01/30/25 01:55 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Thanks so much for all the help.
John, I pulled up the post as soon as I got it apart, to see which one it was, so there was a small celebration there. Are there any other pictures I can provide to help? I will take pictures of everything I have out right now, maybe the pictures of the servos will help.
Thanks again, you guys have been extremely helpful and I really appreciate it.
'75 Plymouth Duster
