Electric fuel pump recommendations anyone?
#3283498
01/18/25 07:55 PM
01/18/25 07:55 PM
Posts: 21,540 in a cattle trailer down by th...
Guitar Jones
A dependable low pressure street pump. I have a Holley red pump on it now and it has quit working twice. Once I could here the pump running but it wasn't pushing any fuel, I did nothing to it, but it worked fine the next day. It sounded like either the internal bypass was stuck open or something. I took it apart but found nothing.
Today it died on the highway, I pulled over and couldn't hear the pump running, it's pretty loud, I tapped on it with a pair of pliers and it started running again but doesn't sound healthy. Anyway, I don't trust it anymore so anybody got a recommendation for a dependable mild street pump? Thanks.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: Electric fuel pump recommendations anyone?
[Re: Guitar Jones]
#3283512
01/19/25 12:04 AM
01/19/25 12:04 AM
Posts: 13,806 md
mopars4ever
md
I have used the Carter P4070 In-Line Electric Fuel Pump with good luck.
Time just gets away from us I`m here until I`m not
[Re: mopars4ever]
#3283547
01/19/25 06:18 AM
01/19/25 06:18 AM
Posts: 6,720 ohio
ruderunner
ohio
I prefer a good old mechanical pump.
Angry white pureblood male
[Re: ruderunner]
#3283574
01/19/25 10:26 AM
01/19/25 10:26 AM
Guitar Jones
I prefer a good old mechanical pump. I would too, but I have the magnum timing cover and accessory drive on it. That isn't going to change.
[Re: Guitar Jones]
#3283577
01/19/25 10:30 AM
01/19/25 10:30 AM
Posts: 3,334 West Coast, USA
jbc426
West Coast, USA
If you want to plumb a like-sized return line from a bypass regulator mounted up front, you can drop a factory-reliable electric pump in your stock tank. I modified my own replacement fuel sending unit to allow me to do just that. Drops right in, is quiet and reliable.
1970 Plymouth 'Cuda #'s 440-6(Stock drivetrain in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's & EFI. 1968 Plymouth Barracuda Convertible Paxton Boosted 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 3.91's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#3283582
01/19/25 11:05 AM
01/19/25 11:05 AM
Guitar Jones
I have been thinking about doing that, where did you get the wiring connector?
[Re: mopars4ever]
#3283618
01/19/25 04:02 PM
01/19/25 04:02 PM
Guitar Jones
I have used the Carter P4070 In-Line Electric Fuel Pump with good luck. I've been looking at those Carter pumps, but can't find a 5/16 hose barb that fits those NPS threads. Trying to keep it simple in case I have to change it on the side of the road.
[Re: calrobb2000]
#3283647
01/19/25 06:41 PM
01/19/25 06:41 PM
Guitar Jones
hi the pump threads are n p t tapered not n p s straight !
plenty fittings on e bay !
That isn't what the specs say, and the pictured 3/8 hose barb fittings appear to be NPS. What am I missing?
[Re: Guitar Jones]
#3283664
01/19/25 08:55 PM
01/19/25 08:55 PM
Posts: 10,691 Rittman Ohio
fourgearsavoy
Rittman Ohio
That isn't what the specs say, and the pictured 3/8 hose barb fittings appear to be NPS. What am I missing? Did you look at the picture on the summit site? looks like the fittings are included. I would bet the NPS is a typo.
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: mopars4ever]
#3283671
01/19/25 09:37 PM
01/19/25 09:37 PM
Posts: 1,809 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
I have used the Carter P4070 In-Line Electric Fuel Pump with good luck. RockAuto shows this pump at $44.79...darn half price of Summit and Jegs...can't beat that!!!
[Re: fourgearsavoy]
#3283673
01/19/25 09:41 PM
01/19/25 09:41 PM
Guitar Jones
That isn't what the specs say, and the pictured 3/8 hose barb fittings appear to be NPS. What am I missing? Did you look at the picture on the summit site? looks like the fittings are included. I would bet the NPS is a typo. Fittings for a 3/8 hose. Truck has 5/16. Every Carter pump of that style is listed as having NPS threads, one even mentioned it in the Q&A.
[Re: Diplomat360]
#3283674
01/19/25 09:45 PM
01/19/25 09:45 PM
Guitar Jones
I have used the Carter P4070 In-Line Electric Fuel Pump with good luck. RockAuto shows this pump at $44.79...darn half price of Summit and Jegs...can't beat that!!! I have found it for $59 with free shipping. RA wants $12-$13 for shipping, USPS, we haven't gotten mail in almost 3 weeks now so I'm not thrilled with that. FedEx, UPS and the garbage truck has been here though.
[Re: Guitar Jones]
#3283680
01/19/25 10:19 PM
01/19/25 10:19 PM
Posts: 44,209 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3283694
01/20/25 12:33 AM
01/20/25 12:33 AM
Guitar Jones
I can't find anything on a Weldon 275 pump. Their lowest pressure carb pump says it isn't for continuous duty street use.
[Re: Guitar Jones]
#3283720
01/20/25 10:25 AM
01/20/25 10:25 AM
jbc426
West Coast, USA
I have been thinking about doing that, where did you get the wiring connector? I sourced the one shown from Radium Engineering, but there are other sources with lower prices these days. Just make sure to use the fully-submersible fuel line. https://www.radiumauto.com/Bulkhead-Fuel-Pump-Harnesses-and-Connectors-P682.aspx
[Re: jbc426]
#3283787
01/20/25 03:38 PM
01/20/25 03:38 PM
Guitar Jones
Thanks, the more I think about it though an in tank pump might not be a good idea since this is an in cab fuel tank. Pressurized fuel inside the cab probably isn't a good idea.
