Electric fuel pump recommendations anyone? #3283498
01/18/25 07:55 PM
01/18/25 07:55 PM
Guitar Jones Offline OP
A dependable low pressure street pump. I have a Holley red pump on it now and it has quit working twice. Once I could here the pump running but it wasn't pushing any fuel, I did nothing to it, but it worked fine the next day. It sounded like either the internal bypass was stuck open or something. I took it apart but found nothing.
Today it died on the highway, I pulled over and couldn't hear the pump running, it's pretty loud, I tapped on it with a pair of pliers and it started running again but doesn't sound healthy. Anyway, I don't trust it anymore so anybody got a recommendation for a dependable mild street pump? Thanks.
"Come get your wife"
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion.
Re: Electric fuel pump recommendations anyone? [Re: Guitar Jones] #3283512
01/19/25 12:04 AM
01/19/25 12:04 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I have used the Carter P4070 In-Line Electric Fuel Pump with good luck.
Time just gets away from us
I`m here until I`m not
Re: Electric fuel pump recommendations anyone? [Re: mopars4ever] #3283547
01/19/25 06:18 AM
01/19/25 06:18 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I prefer a good old mechanical pump.
Angry white pureblood male
Re: Electric fuel pump recommendations anyone? [Re: ruderunner] #3283574
01/19/25 10:26 AM
01/19/25 10:26 AM
I would too, but I have the magnum timing cover and accessory drive on it. That isn't going to change.
Re: Electric fuel pump recommendations anyone? [Re: ruderunner] #3283575
01/19/25 10:29 AM
01/19/25 10:29 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've used the old Carter, and the old Holley 110, and the later Holley "black" (130 gph?) and never had an issue.
A few years ago I bought a cheap Summit inline pump - actually bought 2, because the 1st one leaked - but they're a cheaply-made plastic deal.
I later removed it - it was only for pre-filling the carb bowls, and I quit worrying about that.
Re: Electric fuel pump recommendations anyone? [Re: Guitar Jones] #3283577
01/19/25 10:30 AM
01/19/25 10:30 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
If you want to plumb a like-sized return line from a bypass regulator mounted up front, you can drop a factory-reliable electric pump in your stock tank. I modified my own replacement fuel sending unit to allow me to do just that. Drops right in, is quiet and reliable.
1970 Plymouth 'Cuda #'s 440-6(Stock drivetrain in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's & EFI.
1968 Plymouth Barracuda Convertible Paxton Boosted 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 3.91's (closest thing to an automatic 5 speed going)
Re: Electric fuel pump recommendations anyone? [Re: jbc426] #3283582
01/19/25 11:05 AM
01/19/25 11:05 AM
I have been thinking about doing that, where did you get the wiring connector?
Re: Electric fuel pump recommendations anyone? [Re: Guitar Jones] #3283611
01/19/25 02:20 PM
01/19/25 02:20 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I've been running a Holley Sniper series (chinese copy) for about 3years and 1600 miles with no issues. I just have it deadhead to a Quickfuel regulator. https://www.summitracing.com/parts/sne-80000102
Gus beer
64 Plymouth Savoy
Dana 60
Re: Electric fuel pump recommendations anyone? [Re: mopars4ever] #3283618
01/19/25 04:02 PM
01/19/25 04:02 PM
I've been looking at those Carter pumps, but can't find a 5/16 hose barb that fits those NPS threads. Trying to keep it simple in case I have to change it on the side of the road.
Re: Electric fuel pump recommendations anyone? [Re: Guitar Jones] #3283638
01/19/25 05:48 PM
01/19/25 05:48 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
the pump threads are n p t tapered not n p s straight !
plenty fittings on e bay !
Re: Electric fuel pump recommendations anyone? [Re: calrobb2000] #3283647
01/19/25 06:41 PM
01/19/25 06:41 PM
Originally Posted by calrobb2000
hi
That isn't what the specs say, and the pictured 3/8 hose barb fittings appear to be NPS. What am I missing?
Re: Electric fuel pump recommendations anyone? [Re: Guitar Jones] #3283664
01/19/25 08:55 PM
01/19/25 08:55 PM
Rittman Ohio
Rittman Ohio
hi
Did you look at the picture on the summit site? looks like the fittings are included. I would bet the NPS is a typo.
64 Plymouth Savoy
Dana 60
Re: Electric fuel pump recommendations anyone? [Re: mopars4ever] #3283671
01/19/25 09:37 PM
01/19/25 09:37 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
RockAuto shows this pump at $44.79...darn half price of Summit and Jegs...can't beat that!!!
Re: Electric fuel pump recommendations anyone? [Re: fourgearsavoy] #3283673
01/19/25 09:41 PM
01/19/25 09:41 PM
hi
Fittings for a 3/8 hose. Truck has 5/16. Every Carter pump of that style is listed as having NPS threads, one even mentioned it in the Q&A.
Re: Electric fuel pump recommendations anyone? [Re: Diplomat360] #3283674
01/19/25 09:45 PM
01/19/25 09:45 PM
I have found it for $59 with free shipping. RA wants $12-$13 for shipping, USPS, we haven't gotten mail in almost 3 weeks now so I'm not thrilled with that. FedEx, UPS and the garbage truck has been here though.
Re: Electric fuel pump recommendations anyone? [Re: Guitar Jones] #3283680
01/19/25 10:19 PM
01/19/25 10:19 PM
Cab_Burge Online work
Cab_Burge  Online Work
Magna fuel 275 pump up scope twocents
Re: Electric fuel pump recommendations anyone? [Re: Cab_Burge] #3283694
01/20/25 12:33 AM
01/20/25 12:33 AM
Originally Posted by Cab_Burge
Weldon 275 pump up scope twocents
I can't find anything on a Weldon 275 pump. Their lowest pressure carb pump says it isn't for continuous duty street use.
Re: Electric fuel pump recommendations anyone? [Re: Guitar Jones] #3283701
01/20/25 07:30 AM
01/20/25 07:30 AM
Your absolutely correct, it wasn't a Weldon pump, I'm sorry blush realcrazy My airplane had a Weldon pump on it blush realcrazy
It was a Magna Fuel 275 up
I ran that Magna Fuel 275 pump for years starting in 2005 until I sold that car in 2013. It was on my last pump gas street Duster shruggy
Re: Electric fuel pump recommendations anyone? [Re: Guitar Jones] #3283720
01/20/25 10:25 AM
01/20/25 10:25 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I sourced the one shown from Radium Engineering, but there are other sources with lower prices these days. Just make sure to use the fully-submersible fuel line.
https://www.radiumauto.com/Bulkhead-Fuel-Pump-Harnesses-and-Connectors-P682.aspx
Re: Electric fuel pump recommendations anyone? [Re: jbc426] #3283787
01/20/25 03:38 PM
01/20/25 03:38 PM
Thanks, the more I think about it though an in tank pump might not be a good idea since this is an in cab fuel tank. Pressurized fuel inside the cab probably isn't a good idea.
