1971 Charger R/T Exhaust Size
#3283497
01/18/25 07:46 PM
01/18/25 07:46 PM
Posts: 1,230 Rochester, New York
GregY
Rochester, New York
So I went to put mufflers on my 1971 Charger R/T (it's a beater, not a show car). I knew it didn't have a 3-inch exhaust, so I assumed it must 2.5-inch. Well, much to my surprise, I discovered it has 2.25-inch exhaust (dual).
The weird thing is that it is a former drag car, you can see the remnants of the roll cage floor mounts behind the front seats, and it has long tube headers. Maybe the second guy (non-racer) who owned it put a smaller exhaust on it or something
It runs okay at the track (mid-13's at 100 mph; 440 ci/400 hp/automatic/3.91s), but now I wonder how much the exhaust is holding it back.
I went ahead and bought some 2.25-inch mufflers just to get it back together, but there will probably be an upgrade in the future (probably next year assuming I don't have any big issues with it this year).
Greg
Re: 1971 Charger R/T Exhaust Size
[Re: gch]
#3283591
01/19/25 12:27 PM
01/19/25 12:27 PM
Posts: 8,602 Highland, MI.
Sunroofcuda
Highland, MI.
OE was dual 2.25" all the way. Here's a diagram from my old Walker book. I also have a 440 Mag 71 Charger R/T that I picked up late Aug. It has dual 2.25" exhaust off the stock manifolds & some ??? mufflers that are very restrictive. In spring, I'm going to have a 2.5" dual exhaust custom-bent with H-pipe, I already bought a pair of Dynomax Ultra Flo 17289's.
[Re: Cab_Burge]
#3283737
01/20/25 12:01 PM
01/20/25 12:01 PM
Posts: 2,827 Sobieski Wi
bee1971
Sobieski Wi
1971 B 440
Accurate Exhaust
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: bee1971]
#3283876
01/20/25 11:18 PM
01/20/25 11:18 PM
Posts: 10,462 Someplace you aren't
SomeCarGuy
You’ll definitely want to open it up to 2.5 at least to the mufflers. I’ve had at least two cars I can think of, one of which I just redid, that had 2.25 pipes coming right off the hp manifolds. Just a penny pinch corner cut. With headers there’s simply no way I’d leave 2.25 or put it back. My current car felt held back just a tad, I went under and measured the pipes at 2.25, I needed new mufflers anyway so it was no question in going back to factory size at least to the muffs, and my exhaust guy is a wizard so I knew he’d bend up some good 2.5s over the axle, just like always on my cars. I could feel it running better in the way home.
I stuck with the manifolds on my 69 GTX last summer. Car is all stock. It has more power with a 2.5 system going all the way to the 2.5 tips. The super turbos did the best of any of the quieter mufflers on some flow test chart an exhaust guy did. Chart is floating around mopar boards. I think ultra flows were among the best or were the best if you just went on flow and not sound. I added resonators and it’s as quiet as a new car, which is what I wanted. Don’t overlook hangers. I got the 2.5 factory style ones from accurate when I ordered the tips. I no longer have the buzz from some interior parts at certain rpms. That’s all gone now. The cost was eye popping outrageous and worth every penny.
I want my fair share
