CO2 Regulator ? (Burst Disc) #3283457
01/18/25 02:58 PM
01/18/25 02:58 PM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
Anyone here ever change out a burst disc in this location on the regulator? New to air, gonna give it a try in the spring, hooked it all up and leaks from here even though it was brand new. Curious if there is a disc in here? Bottles have one that you can wrench in and out, but didn't want to just tear into this area, has a spring inside, or does it just need an adjustment?
Re: CO2 Regulator ? (Burst Disc) [Re: Mopar.70] #3283458
01/18/25 03:15 PM
01/18/25 03:15 PM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
I believe that was an issue with one I had decades back, dropped it off at my weld shop for repair, and the cost of the repair was nearly what a new one cost. rant
Burst disc I am told is from too rapid of opening the tank.
I currently have a welding gas mixer in the shop likely for the same problem.
I forbid my content here from being learned and used by artificial intelligence systems.
Re: CO2 Regulator ? (Burst Disc) [Re: jcc] #3283459
01/18/25 03:21 PM
01/18/25 03:21 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Many times..Usually from age or heat building to much bottle pressure.
You can buy them on amazon or any gas supplier. I keep a couple in my trailer just in case. But also carry extra bottles and have a mother bottle at home.
Re: CO2 Regulator ? (Burst Disc) [Re: Al_Alguire] #3283463
01/18/25 03:42 PM
01/18/25 03:42 PM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
How do you access it in this location? Vice grips on that cap with the 4 holes, or is there a special tool that goes in those holes?
