Re: 1969 Road Runner Electrical issue
[Re: bdgtfb]
#3283358
01/18/25 06:31 AM
01/18/25 06:31 AM
Posts: 6,713 ohio
ruderunner
ohio
Sounds ground related. Iirc, the rear lights have a single ground wire attached to the base of the trunk striker.
I'd check that for tightness and paint buildup.
Angry white pureblood male
[Re: Andrewh]
#3283423
01/18/25 12:19 PM
01/18/25 12:19 PM
Posts: 21,818 N.E. OHIO, USA
A12
N.E. OHIO, USA
did you change anything recently? or since the last time you drove it?
you can test if it is a ground issue by running a separate ground to each light bulb holder and see if they light up. Like had the driver's side sill plate or the driver's side kick panel off?
