Decent brand of engine cradle, dollys ? #3283303
01/17/25 08:32 PM
01/17/25 08:32 PM
Cab_Burge Offline OP
I need a engine storage stand for a 426 Hemi motor to use to take them to engine dyno for testing, who do you guys use and like as well as which ones to not buy help
Thanks in advance bow luck
Re: Decent brand of engine cradle, dollys ? [Re: Cab_Burge] #3283325
01/17/25 10:38 PM
01/17/25 10:38 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have always just fabricated my own. I also make them so the fold flat when not in use. Takes up less space to store them.
These guys are expensive.....
https://www.rcrmetalfab.com/chrysler-426-hemi-for-aluminum-and-iron-blocks
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Decent brand of engine cradle, dollys ? [Re: Cab_Burge] #3283344
01/18/25 03:20 AM
01/18/25 03:20 AM
Sticky South
Rodenteliminator Offline
Sticky South
I had some roll bar that I cut out of a car and I just hung the engine on my cherry picker and fab’d and welded up in about an hour, long bolts through the motor mounts and bell housing, tough as a tank.
Sorry honey I spent the rent
Re: Decent brand of engine cradle, dollys ? [Re: Rodenteliminator] #3283363
01/18/25 07:16 AM
01/18/25 07:16 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Would be cool to see some of these said home fab cradles sawzall weld primer
Re: Decent brand of engine cradle, dollys ? [Re: racerx] #3283369
01/18/25 08:46 AM
01/18/25 08:46 AM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
One of the Tillburg boys makes and sells them. Really nice pieces! I bought one at the US Nats.
Powder coated, folds flat and has heavy casters on it.
Check out Tillburg Racing Products on FB.
Thanks,
Casey FJ
Re: Decent brand of engine cradle, dollys ? [Re: Whompin_Wedge] #3283383
01/18/25 09:55 AM
01/18/25 09:55 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
Same here, I use thin wall square tube. I use them for bare blocks most of the time. If it was a fully built i would use heavier material. Weld up a rectangular frame and install caster wheels. Hang the block on a cherry picker then fab the mounts for the motor. Tack it in place then weld it up. Easy peasy! up
Re: Decent brand of engine cradle, dollys ? [Re: Moparite] #3283385
01/18/25 10:06 AM
01/18/25 10:06 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've made cradles using 2x8 wood that fit the perimeter of the oil pan (pan rail) - ft & rear being wider, like outriggers.
The 8" kept even bigger oil pans off the ground.
Either some good large-ish casters, or a good mover's dolly, makes them portable.
The flimsy ones for SB Chevys don't fit SB Mopars all that well, but can serve in a pinch.
Re: Decent brand of engine cradle, dollys ? [Re: topside] #3283387
01/18/25 10:14 AM
01/18/25 10:14 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I just used an extra engine stand and shortened it. Added large casters and turnbuckles to support the front. And the handle is off a reel mower laugh2 I used it to transfer my engines to the garage. Not building anything without heat.
Re: Decent brand of engine cradle, dollys ? [Re: Hot 340] #3283414
01/18/25 11:55 AM
01/18/25 11:55 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I also make my own out of square tuning.
Re: Decent brand of engine cradle, dollys ? [Re: Al_Alguire] #3283415
01/18/25 11:57 AM
01/18/25 11:57 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Here area couple
Re: Decent brand of engine cradle, dollys ? [Re: Al_Alguire] #3283484
01/18/25 06:26 PM
01/18/25 06:26 PM
Il earned a long time ago that I am NOT a good fabricator, welder or paint and body work guy shruggy
I'm jealous of those that are realcrazy grin
Measuring, cleaning, blueprinting and final assembling yes, wiring and plumbing also up grin None of the above though whiney
Re: Decent brand of engine cradle, dollys ? [Re: Cab_Burge] #3283501
01/18/25 09:01 PM
01/18/25 09:01 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I made mine out of 1" angle iron that I had laying around. Mine is extra tall to accommodate my Milodon SS oil pan. It bolts to bell housing holes and motor mounts in front. I just got a store bought one, but I haven't used it yet. It is made by All Star performance #10156.
Brian
Re: Decent brand of engine cradle, dollys ? [Re: Cab_Burge] #3283610
01/19/25 01:58 PM
01/19/25 01:58 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I seen a nice one that AndyF made. I've used it a few times to transport engines I have built. I don't know if he builds them for anyone else because this one was shipped with an engine my friend bought from him.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Decent brand of engine cradle, dollys ? [Re: fourgearsavoy] #3283922
01/21/25 11:00 AM
01/21/25 11:00 AM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Possible option shruggy
Screenshot 2025-01-21 at 08-53-42 JEGS 800644 Engine Cradle for Big Block Mopar Engine eBay.png
STOP POTATO HATE!
Re: Decent brand of engine cradle, dollys ? [Re: fourgearsavoy] #3283937
01/21/25 11:43 AM
01/21/25 11:43 AM
AndyF Offline
AndyF  Offline
I've made dollies for lots of Mopar engines. I used to sell them but got tired of people always bitching about how much they cost so I stopped making them. These days I just build dollies when I need them. I have the CAD files for most muscle car ear engines including Chevy, Ford, Mopar, BOP, etc.
Re: Decent brand of engine cradle, dollys ? [Re: AndyF] #3283952
01/21/25 12:22 PM
01/21/25 12:22 PM
CA
crackedback Offline
crackedback  Offline
CA
EXACTLY! I used to build them as well.
But summit has this one with free shipping. my response--- why are you bothering me wanting $40-50 off a $65 part to get it delivered for the same price as the summit one.. By the time the materials and all got into the mix and the price that they wanted it, It would have been about $1/hour or less on labor. Sorry, maybe a chinese kid might work for that, I had other stuff to do that pays a lot more than that back then. LOL
Re: Decent brand of engine cradle, dollys ? [Re: crackedback] #3284001
01/21/25 02:21 PM
01/21/25 02:21 PM
Chicago area
Magnum GT Offline
Magnum GT  Offline
Chicago area
Steve
1979 Magnum GT
Re: Decent brand of engine cradle, dollys ? [Re: Magnum GT] #3284009
01/21/25 02:44 PM
01/21/25 02:44 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Andy's design looks strong.
I've used the Jeg's style before, and they're not what I'd call strong, but adequate.
Cheap enough though, that adding some gussets & wheels would be fairly easy & inexpensive.
Re: Decent brand of engine cradle, dollys ? [Re: Magnum GT] #3284020
01/21/25 03:00 PM
01/21/25 03:00 PM
Stock and after market 426 Hemi and KB wedge blocks don't have the mounting ears cast on the block scope,
The hemi motor mounts bolt onto the side of the block directly above the oil pan rails with three 7/16 studs or bolts on each side. Hence the issue on the dolly's needing to be for the hemi blocks shruggy
Re: Decent brand of engine cradle, dollys ? [Re: Cab_Burge] #3284042
01/21/25 03:45 PM
01/21/25 03:45 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I have had two AllStar cradles from Summit for my small blocks and they work well , they fit pretty well on a Harbor Freight furniture dolly to move the motors around.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
