trailer weight #3283216
01/17/25 12:41 PM
01/17/25 12:41 PM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
hello,
have 28ft 3 axle enclosed trailer, would like to get it weighed with car in it, local landfill/transfer station has scale, do I need to unhook it or can I just drive truck off scale, or weight truck/trailer then just truck?
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: trailer weight [Re: 440lebaron] #3283227
01/17/25 01:14 PM
01/17/25 01:14 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
IMO most scales are somewhat busy , I pickup material for my boss and am scaled quite a lot , I drive on empty then with the load so they get a weight to charge for the ... opposite when I drop a load of scrap at the junk yard. I doubt they will let you disconnect the trailer on the scale as it will take to much time thus tying the scale up for to long . They should if there is room allow you to disconnect the trailer and weigh the truck separately then just subtract the truck weight from the total of the truck and trailer combination for your loaded trailer weight.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: trailer weight [Re: 11secdart] #3283230
01/17/25 01:24 PM
01/17/25 01:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Seems to me that the most accurate weight would be found disconnected.
Tongue weight is supported by hitch & truck; that could be calculated by weighing separately, but would only be approximate, I think.
Reason I say that is that it seems that trailer weight forward of the axles contributes to tongue weight.
Re: trailer weight [Re: topside] #3283237
01/17/25 01:46 PM
01/17/25 01:46 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I would say disconnected. If you are using weight distribution bars I am sure they would also throw the weight off.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: trailer weight [Re: 6PKRTSE] #3283243
01/17/25 02:18 PM
01/17/25 02:18 PM
westerly, ri. usa
westerly, ri. usa
thanks, scale is just a couple of miles from home, will just weight truck/trailer then go back and weight truck
Re: trailer weight [Re: 440lebaron] #3283267
01/17/25 04:02 PM
01/17/25 04:02 PM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
Our local scrap yards have drive on scales with digital readouts, Just drive on, jot down your weight, drop your trailer where convenient and safe, drive back on, do the subtraction, no cost, no hassle. no wait. But our vehicle scales are only accurate to 20lbs?
I forbid my content here from being learned and used by artificial intelligence systems.
Re: trailer weight [Re: jcc] #3283281
01/17/25 06:14 PM
01/17/25 06:14 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The only diiference being hooked to the truck will be tounge weight. Make sure it doesnt have distribution bars connected when weighing. Tounge weight for that trailer should be around 600lbs. So scale weight plus 600 should be very close.
Doug
Re: trailer weight [Re: 440lebaron] #3283301
01/17/25 08:20 PM
01/17/25 08:20 PM
If you can see an outside display board drive the truck on with the front axle only first and write that down, then both axles and then with the front axle of the trailer on, if those scales are long enough, and finally with both trailer axles on the scale only.
If no visible out side display ask the operator before driving it on to see if they will do that for you luck
BTW, every car trailer sales folks I have ask about the unladen (empty) weight lied about their brands being way lighter than they actually were by a bunch, 2980 lbs. unladen advertised versus 4350 actual whiney rant down shruggy
Oregon has a bunch of commercial truck scale stops all over the state hat they don't keep open 24/7, they are mainly single axles or dual axles at the most. Very short scales but they all have outside displays so you can use them any time you want when they are closed by driving on them slowly boogie up wrench
Our local garbage dumps do have long scales.
They charge by the ton to dump garbage at the dumps, you have to use them before and after dumping your loads there whiney
Re: trailer weight [Re: 440lebaron] #3283312
01/17/25 09:20 PM
01/17/25 09:20 PM
Memphis TN
B1HEAD_USER Offline
B1HEAD_USER  Offline
Memphis TN
Use the CAT scales app and go to a truck stop. Weigh the whole thing then just the truck. Don't even have to go inside.
Re: trailer weight [Re: B1HEAD_USER] #3283488
01/18/25 06:45 PM
01/18/25 06:45 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
For work my truck has increased GVWR stickers for the trailer, which is weighed attached to the truck. I have to weigh front axle then truck rear, then trailer axles and add it all together to get the GVWR for the trucks registered weight. You can move weight around on the trailer though to change what shows up on the trailer axles and what will show up on the truck's axle in case one is too heavy.
