Re: Comp roller rockers
[Re: fastmark]
#3282656
01/14/25 02:50 PM
01/14/25 02:50 PM
Posts: 1,479 Loudoun County, VA
Brad_Haak
Loudoun County, VA
First generation Comp Magnum BB rockers - no bushings - no roller bearing in tip, just a pin w/ a roller - issues I recall people having were them galling the shafts with maybe 400+ PSI open spring loads - additional grooves for the shafts is a good idea - IIRC, some people had the fulcrums honed to add a bit of clearance, too
I don't know if Comp upgraded the shafts when they revised them for bronze bushings later on.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3282680
01/14/25 05:04 PM
01/14/25 05:04 PM
Posts: 9,207 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
They are steel and not bushed. Steel on steel is just asking for trouble. The old Isky and Crane "nodular iron" are about as risky as I'd ever get. I think if you're determined to use them I'd want good oiling AND definately a "hard chromed" shaft.
