Re: '14 JKU M-380 - "Kilroy"
[Re: Fat_Mike]
#3277740
12/23/24 11:27 AM
12/23/24 11:27 AM
Posts: 305 Falcon, CO
Mad-Max
Falcon, CO
71 Demon (project): 318, A-833od, 8-3/4, 3.23's 14 Wrangler JKU M-380 "Kilroy" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s 52 Willys M-38 "Poncho"
[Re: BDW]
#3278833
12/29/24 01:28 PM
12/29/24 01:28 PM
Mad-Max
Falcon, CO
[Re: Mad-Max]
#3279073
12/30/24 01:13 PM
12/30/24 01:13 PM
Mad-Max
Falcon, CO
[Re: Mad-Max]
#3279311
12/31/24 12:03 PM
12/31/24 12:03 PM
Mad-Max
Falcon, CO
[Re: Mad-Max]
#3280208
01/03/25 12:34 PM
01/03/25 12:34 PM
Mad-Max
Falcon, CO
[Re: Mad-Max]
#3282441
01/13/25 10:22 AM
01/13/25 10:22 AM
Mad-Max
Falcon, CO
the inner fenders need some support along the inside edge, and I'll eventually have fender liners to protect the engine and such from splash and debris, so I made the center section of the fender liners which serve as support for the inner fenders - makes everything good n strong especially the p-side to support the 65lb battery - should work great. I'll complete the fender liners after it's running... bolts to the shock tower - and to the inner fenders - and sitting on a megaware battery guard (gel mat) the battery mounts are essentially done - like everything else ready for final welding and paint -
[Re: BDW]
#3282617
01/14/25 10:53 AM
01/14/25 10:53 AM
Mad-Max
Falcon, CO
I think they will have better 'retaining power' than the typical nutzerts, but potentially less 'counter-rotating' power - meaning they might spin if over-cranked etc., so I am planning to tack weld the sides of every one of them for good measure. The tool I have is just the typical nutzert tool, which I had to modify the chuck to let it thread deeper into the longer rivet nuts for more thread capture
