Re: Strange key fob issue
[Re: Wirenut]
#3205854
01/18/24 11:08 AM
01/18/24 11:08 AM
Posts: 4,717 Motor City
6PKRTSE
Motor City
My 2012 Challenger key fob acts up once in a while also. Mine pops my trunk as I slide my hand under the door handle as the car unlocks. I close the trunk and it will pop right open again. I smack the fob a few times and it may go away for a day or more or sometimes weeks, but comes back eventually. I think at times the fob get compressed in my pockets which is somehow keeping the trunk button pushed slightly.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3206113
01/19/24 08:04 AM
01/19/24 08:04 AM
Posts: 1,404 VA
dragon slayer
VA
So take it apart as if changing battery and look at the rubber assembly with the push buttons. There are thin concave disk that are glued in place under each button. They activate the circuits on the pcb when button pressed down. I have a 2012, that the glue broke free and the disk slide into different spot causing erratic operation of the fob. Including popping trunk and killing battery, even multi cycling as if trying remote start when key fob in range. You need a good 3M rubber cement to glue them back in place. Fixed my fob.
[Re: dragon slayer]
#3282614
01/14/25 10:43 AM
01/14/25 10:43 AM
Posts: 44,113 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
So take it apart as if changing battery and look at the rubber assembly with the push buttons. There are thin concave disk that are glued in place under each button. They activate the circuits on the pcb when button pressed down. I have a 2012, that the glue broke free and the disk slide into different spot causing erratic operation of the fob. Including popping trunk and killing battery, even multi cycling as if trying remote start when key fob in range. You need a good 3M rubber cement to glue them back in place. Fixed my fob. I believe those discs are held in with dielectric grease. It happens to my key fob all the time and I had to add a little more each time. So you glued the disc to the rubber pad push pad?
JB Rhinehart, Realist
A-Body's RULE!
