Distributor cap colors. #3282501
01/13/25 04:51 PM
01/13/25 04:51 PM
A727Tflite Offline OP
1970 aluminum housing distributor - 440 6 pack - what color.
Am I wrong that most cast iron distributors of all years had black and aluminum had beige or is that too simple and incorrect.
Re: Distributor cap colors. [Re: A727Tflite] #3282529
01/13/25 07:57 PM
01/13/25 07:57 PM
Enjoy life today, It has an ex...
gtx6970 Offline
gtx6970  Offline
Tan bakelight
Pt #2444507 single point
2585000 dual point
Enjoy life today, It has an expiration date
Re: Distributor cap colors. [Re: gtx6970] #3282537
01/13/25 09:33 PM
01/13/25 09:33 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
iagree
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Distributor cap colors. [Re: BloFish] #3282574
01/14/25 02:11 AM
01/14/25 02:11 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Original 2585000 dual point cap has Made In USA visible on top, IBK-1003 is cast inside near floating center carbon, has aluminum contacts.
Re: Distributor cap colors. [Re: John Brown] #3282700
01/14/25 06:41 PM
01/14/25 06:41 PM
gtx6970 Offline
gtx6970  Offline
I use these.my car doesn't need a $100 or more dist cap
Re: Distributor cap colors. [Re: A727Tflite] #3282794
01/15/25 08:50 AM
01/15/25 08:50 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Early dual point had Black caps , musclecar era had tan, the alum single/electronic had tan
Mainstream Media is the new Pravda
Re: Distributor cap colors. [Re: JohnRR] #3282867
01/15/25 02:03 PM
01/15/25 02:03 PM
gtx6970 Offline
gtx6970  Offline
Last year for black caps was 1965
Re: Distributor cap colors. [Re: gtx6970] #3282907
01/15/25 05:48 PM
01/15/25 05:48 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I just use Accel caps for the tan caps when needed and less than $30.00 also.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Distributor cap colors. [Re: John Brown] #3283337
01/18/25 01:11 AM
01/18/25 01:11 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
This DC one (bought 11-87) doesn't have the Made In USA molded on top of cap. But does have IBK-1016.
Spring Fling 37 May 3 & 4, 2025 at Woodley Park, Van Nuys CA
600+ Mopars, 200+ swap, midway, Friday Malibu cruise,
Re: Distributor cap colors. [Re: autoxcuda] #3283378
01/18/25 09:11 AM
01/18/25 09:11 AM
Back in the day when the OE supplied quality parts.
Re: Distributor cap colors. [Re: A727Tflite] #3283571
01/19/25 10:12 AM
01/19/25 10:12 AM
gtx6970 Offline
gtx6970  Offline
The black cap was identical ,,,except color
pt # 1658534
And are a lot easier to find, and usually quite a bit cheaper than the tan cap
Fit and function is the same
1965 is the latest this part number shows up in parts books I believe
https://www.ebay.com/sch/i.html?_nk...from=R40&_trksid=p2332490.m570.l1313
https://www.ebay.com/itm/256540086765
https://www.ebay.com/itm/295102235801
Re: Distributor cap colors. [Re: gtx6970] #3283581
01/19/25 11:04 AM
01/19/25 11:04 AM
So Cal
So Cal
pt # 1658534
Thanks !
I can definitely see the “Made in USA” on those examples.
