A-BODY inner fenders #3282479
01/13/25 02:55 PM
01/13/25 02:55 PM
old westchester
mcat4321 Offline OP
mcat4321  Offline OP
old westchester
does anybody make prebent aluminum inner fenders for a 69 dart
Re: A-BODY inner fenders [Re: mcat4321] #3282495
01/13/25 04:20 PM
01/13/25 04:20 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Never heard of aluminum inner fenders. shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: A-BODY inner fenders [Re: Rhinodart] #3282520
01/13/25 06:25 PM
01/13/25 06:25 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Inner fenders are a substantial part of the front clip. Need to think about snout bars or something to support that nose if you remove the OE stuff
Re: A-BODY inner fenders [Re: CMcAllister] #3282524
01/13/25 07:08 PM
01/13/25 07:08 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Is the OP asking about the inner fender which is part of the unibody structure or the inserts that are in and behind the wheel? I’m thinking here referring about the inserts.
Re: A-BODY inner fenders [Re: Dabee] #3282615
01/14/25 10:46 AM
01/14/25 10:46 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
You mean splash shields? The shields that keep debris out between the fender and door?
A-Body's RULE!
Re: A-BODY inner fenders [Re: Rhinodart] #3282644
01/14/25 01:27 PM
01/14/25 01:27 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yo, OP, kindly explain what you're looking for.
Aluminum aprons ? Shields ?
Mopars didn't use aluminum for either, but race car aprons for a tube-chassis car would be a fabrication job.
If the aprons were cut away, bolt-on aluminum ones would also be a fabricated deal.
Some chassis companies may have a universal apron available.
Re: A-BODY inner fenders [Re: Rhinodart] #3282688
01/14/25 05:28 PM
01/14/25 05:28 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Yes just couldn’t remember the proper nomenclature for them.
Re: A-BODY inner fenders [Re: Dabee] #3282692
01/14/25 06:02 PM
01/14/25 06:02 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
AMD has them - about $200/pair.
Re: A-BODY inner fenders [Re: topside] #3282711
01/14/25 07:13 PM
01/14/25 07:13 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Someone did those pieces in lightweight material for the AH '68 cars. Not sure who. Google maybe?
Re: A-BODY inner fenders [Re: Dabee] #3283543
01/19/25 04:11 AM
01/19/25 04:11 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
The original steel splash shields don't weigh very much, only 4 lbs 5 oz for the pair, not counting any fasteners.
Meanwhile, the six bumper bars together weigh a tad over 20 lbs, not counting any fasteners. Just sayin'.
Re: A-BODY inner fenders [Re: kentj340] #3283681
01/19/25 10:22 PM
01/19/25 10:22 PM
Cab_Burge Online work
Cab_Burge  Online Work
Originally Posted by kentj340
The original steel splash shields don't weigh very much, only 4 lbs 5 oz for the pair, not counting any fasteners..
The later plastic ones are lighter and fit well also scope up wrench
