Mopar Differential For Sale - 1st Quarter
#3279397
12/31/24 06:51 PM
12/31/24 06:51 PM
Posts: 15,676 Norwich CT USA
moparts
Norwich CT USA
742 Alum 8.75 NIB for sale
[Re: moparts]
#3279468
12/31/24 09:58 PM
12/31/24 09:58 PM
Posts: 24,084 Here
jcc
No soup for you!!!
No soup for you!!!
Here
Mopar Alum 8.75 Carrier NIB Catalog stated when released new design is 10% stronger than original design Likely last new one available in the country As Is $2125 plus shipping, delivery possible east of Mississippi with agreed upon reasonable extra fee
I have 4, decided to use my Mag Dana 60 instead
I forbid my content here from being learned and used by artificial intelligence systems.
8.75" 742 4.30 w/spool for sale
[Re: moparts]
#3279470
12/31/24 10:01 PM
12/31/24 10:01 PM
Posts: 24,084 Here
jcc
No soup for you!!!
No soup for you!!!
Here
8.75" 742 with 10 spline MW billet1350 Yoke with 2 MW Billet caps, ARP ring bolts. MW spool, will have to verify spool spline count and 4.30 ratio, it's been years. All new bearings/parts brand new except housing, never run nor installed, professionally built Not sure if a stronger 742 can be built Over $1500 in parts new w/o labor $1350 + shipping, delivery east of Mississippi possible at additional fee, from SW Fla PM
8,75" steel MW caps pair New for sale
[Re: jcc]
#3279471
12/31/24 10:03 PM
12/31/24 10:03 PM
Posts: 24,084 Here
jcc
No soup for you!!!
No soup for you!!!
Here
These caps are new never been installed. they require minor fitting by installer, as all aftermarket upgrade caps do. The blue paint marking means they have been Cyro treated. It's common thinking only the driver's side cap fails first, therefore it's the only one thought to need an upgrade. There is no known downsides to doing both caps other than cost. Meaning two 8.75's can be upgraded here, I am not willing to separate. $250 + Shipping SW Fla PM
Re: Mopar Differential For Sale - 1st Quarter
[Re: moparts]
#3280041
01/02/25 06:07 PM
01/02/25 06:07 PM
Posts: 2,892 Bowling Green KY / Nashville, ...
300by500
A-Body 8-3/4, standard width, perches moved in to the frame rails (for mini-tub car), 3:91 Suregrip, Moser axles, bigger B-body drum brakes, 741 case, very good condition, ready to go complete with parking brake cables and pinion snubber. Located in Franklin, KY, 5 miles from Interstate 65 at the TN/KY state line. Can mount on a pallet for pickup, zip is 42134. Asking $1800 - make offer. Click below for pics, PM me here on Moparts if interested. Thanks, Moparts! [img] https://imgur.com/a/k5vq5Jb[/img] https://imgur.com/a/k5vq5Jb
Rear Axle Tie Down Brackets
[Re: moparts]
#3282284
01/12/25 05:21 PM
01/12/25 05:21 PM
Posts: 24,084 Here
jcc
No soup for you!!!
No soup for you!!!
Here
A matching pair of new never used long offered well accepted STD Mopar rear axle steel tie downs, only one pictured. User determines suitability and supplies own nuts, etc to attach to existing leaf/axle U-bolts. $40 plus shipping PM
8-3/4 parts and pieces
[Re: moparts]
#3283587
01/19/25 12:11 PM
01/19/25 12:11 PM
Posts: 1,407 Out of the State of Confusion
blue_stocker
66/7 B-body 55-1/2" housing, Moser brace, drain, 2-1/4" inspection/fill bung with blue anodized cap, sand blasted, self-etch primed, ready for paint and installation...$250. New: Richmond 4.30 gearset, Timken bearings, 1350 companion/pinion yoke, clean/used Yukon nodular 489 case, Moser 35 spline spool, ready to install...$800. Lightly used 5.12 Richmond gearset in OEM 489 case, Moser 35 spline spool, new: Timken bearings, 1350 companion/pinion yoke, fresh & ready to install...$700. New Yukon 489 case, 5.38, Moser 35 spline spool, 7260 companion/pinion yoke, clean & ready to install...$750. New 5.57 gearset for 489 case...$300. 2 used sets of 5.38 742 gearsets...$180 each. New Moser 35 spline spool with bearings...$200. All parts priced less shipping, located in the Savannah, Tn area. For information or pictures PM me here. Thanks for viewing and thank you Tom for the add space, much appreciate...wb
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
Freedom must be repurchased by every new generation General Daniel Jones, WW2 Tuskegee Airmen
