Mopar Differential For Sale - 1st Quarter
#3279397
12/31/24 07:51 PM
12/31/24 07:51 PM
Posts: 15,686 Norwich CT USA
moparts
Norwich CT USA
742 Alum 8.75 NIB for sale
[Re: moparts]
#3279468
12/31/24 10:58 PM
12/31/24 10:58 PM
Posts: 24,455 Capital of Narcissism
jcc
No soup for you!!!
No soup for you!!!
Mopar Alum 8.75 Carrier NIB Catalog stated when released new design is 10% stronger than original design Likely last new one available in the country As Is $2125 plus shipping, delivery possible east of Mississippi with agreed upon reasonable extra fee
I have 4, decided to use my Mag Dana 60 instead
"We found that, in general, people don't stop to think whether there might be more information that would help them make a more informed decision," said study co-author Angus Fletcher,
8.75" 742 4.30 w/spool for sale
[Re: moparts]
#3279470
12/31/24 11:01 PM
12/31/24 11:01 PM
jcc
No soup for you!!!
No soup for you!!!
8.75" 742 with 10 spline MW billet1350 Yoke with 2 MW Billet caps, ARP ring bolts. MW spool, will have to verify spool spline count and 4.30 ratio, it's been years. All new bearings/parts brand new except housing, never run nor installed, professionally built Not sure if a stronger 742 can be built Over $1500 in parts new w/o labor $1350 + shipping, delivery east of Mississippi possible at additional fee, from SW Fla PM
8,75" steel MW caps pair New for sale
[Re: jcc]
#3279471
12/31/24 11:03 PM
12/31/24 11:03 PM
jcc
No soup for you!!!
No soup for you!!!
These caps are new never been installed. they require minor fitting by installer, as all aftermarket upgrade caps do. The blue paint marking means they have been Cyro treated. It's common thinking only the driver's side cap fails first, therefore it's the only one thought to need an upgrade. There is no known downsides to doing both caps other than cost. Meaning two 8.75's can be upgraded here, I am not willing to separate. $250 + Shipping SW Fla PM
Re: Mopar Differential For Sale - 1st Quarter
[Re: moparts]
#3280041
01/02/25 07:07 PM
01/02/25 07:07 PM
Posts: 2,897 Bowling Green KY / Nashville, ...
300by500
A-Body 8-3/4, standard width, perches moved in to the frame rails (for mini-tub car), 3:91 Suregrip, Moser axles, bigger B-body drum brakes, 741 case, very good condition, ready to go complete with parking brake cables and pinion snubber. Located in Franklin, KY, 5 miles from Interstate 65 at the TN/KY state line. Can mount on a pallet for pickup, zip is 42134. Asking $1800 - make offer. Click below for pics, PM me here on Moparts if interested. Thanks, Moparts! [img] https://imgur.com/a/k5vq5Jb[/img] https://imgur.com/a/k5vq5Jb
Rear Axle Tie Down Brackets
[Re: moparts]
#3282284
01/12/25 06:21 PM
01/12/25 06:21 PM
jcc
No soup for you!!!
No soup for you!!!
A matching pair of new never used long offered well accepted STD Mopar rear axle steel tie downs, only one pictured. User determines suitability and supplies own nuts, etc to attach to existing leaf/axle U-bolts. $40 plus shipping PM
SOLD
8-3/4 parts and pieces
[Re: moparts]
#3283587
01/19/25 01:11 PM
01/19/25 01:11 PM
Posts: 1,408 Out of the State of Confusion
blue_stocker
66/7 B-body 55-1/2" housing, Moser brace, drain, 2-1/4" inspection/fill bung with blue anodized cap, sand blasted, self-etch primed, ready for paint and installation...$250. New: Richmond 4.30 gearset, Timken bearings, 1350 companion/pinion yoke, clean/used Yukon nodular 489 case, Moser 35 spline spool, ready to install...$800. Lightly used 5.12 Richmond gearset in OEM 489 case, Moser 35 spline spool, new: Timken bearings, 1350 companion/pinion yoke, fresh & ready to install...$700. New Yukon 489 case, 5.38, Moser 35 spline spool, 7260 companion/pinion yoke, clean & ready to install...$750. New 5.57 gearset for 489 case...$300. 2 used sets of 5.38 742 gearsets...$180 each. New Moser 35 spline spool with bearings...$200. All parts priced less shipping, located in the Savannah, Tn area. For information or pictures PM me here. Thanks for viewing and thank you Tom for the add space, much appreciate...wb
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
Freedom must be repurchased by every new generation General Daniel Jones, WW2 Tuskegee Airmen
8-3/4 Bench Fixture
[Re: blue_stocker]
#3284564
01/23/25 07:40 PM
01/23/25 07:40 PM
Posts: 3,703 MO
cdp
MO
I have 1 extra custom fixture I had made to rebuild a couple of 8-3/4 center sections.
Steel, powder coated, ambidextrous plate (bolt patter allows for 180 degree up/down) can be setup in a vice or mounted on your bench. Includes a custom yoke tool, and custom powder coated spanner wrench.
I put 240ft per spec without any problems.
SOLD, Paid as gift, PayPal.
816-726-fourfive_one2
chrispy1971gtx@yahoo.com
Re: Strange Axles - E-body 8-3/4
[Re: moparts]
#3285209
01/26/25 10:32 PM
01/26/25 10:32 PM
Posts: 90 IL
83hurstguy
IL
These are nearly new street/strip alloy Strange axles for Mopar 8-3/4 rear in a 70-74 E-body (cuda or challenger). I installed them, used for 50 miles, but ended up changing the entire rear end setup. Has green bearings installed so you don’t need to set tapered bearing end play, 30 spline, stock width, made for 1/2” thread in lug studs. These cost over $600 new. Asking $400 plus shipping. EDIT: SOLD.
[Re: moparts]
#3289776
02/15/25 10:16 PM
02/15/25 10:16 PM
Posts: 167 Albert Lea, MN
GTX5877
Albert Lea, MN
Dana 60 posi side gears - 23 spline
Dana 60 side gears for Spicer posi-traction. These are the 23 spline (others are 35 spline). Part # stamped on the is 34168.
$40 + shipping from 56007 ***************SOLD*************
1967 Dart GTS 426 Gen III Hemi 1968 Hemi Cuda 572 SS/AH Clone 1988 Chrysler LeBaron Coupe S/S 2003 Dodge Ram 1500 4dr SLT lowered 2012 Ram 1500 2wd Lowered 1970-1/2 Camaro Z-28 1974 VW Karman-Ghia
Gear Sets
[Re: ValiantRich]
#3295784
03/19/25 01:43 PM
03/19/25 01:43 PM
Posts: 314 Long Island, NY
ValiantRich
Long Island, NY
New in the box, US Gear Ring & Pinion 9310 Pro Gear, 4.44 Ratio for 742 Case. $700 including shipping. New in the box, Toms 4.86 Ring & Pinion Pro Gears for 742 Case. $600 including shipping. New in the box, Richmond 8620 Street Gears 4.57 Ratio for 742 Case. $325 including shipping. rich1981@optonline.net
