For Sale/ Wanted - Small Block Engine - 1st Quarter
#3279403
12/31/24 06:57 PM
12/31/24 06:57 PM
Posts: 15,682 Norwich CT USA
moparts
Norwich CT USA
2 W-9 Alum Heads
[Re: moparts]
#3279462
12/31/24 09:45 PM
12/31/24 09:45 PM
Posts: 24,188 Here
jcc
No soup for you!!!
No soup for you!!!
Here
Never run/mounted, almost new #P5007065, as pictured One port was deburred, port cleaned up, and valve job, reported to flow 350cfm Heads were pressure tested, tech states there is lot more left in the heads flow wise. $1550 pair, plus shipping, PM, delivery east of Mississippi possible for extra fee
I forbid my content here from being learned and used by artificial intelligence systems.
4.04" Cast Pistons New For sale
[Re: jcc]
#3279476
12/31/24 10:25 PM
12/31/24 10:25 PM
Posts: 24,188 Here
jcc
No soup for you!!!
No soup for you!!!
Here
No pins, new, CH approx 1.56" 8 .030 over, small dish as pictured $60 OBO plus shipping, PM
A8 9" Deck 340 mains
[Re: jcc]
#3279479
12/31/24 10:42 PM
12/31/24 10:42 PM
Posts: 24,188 Here
jcc
No soup for you!!!
No soup for you!!!
Here
New Not sure if a 48 or 59 Degree These are not for the faint of heart or light of Wallet You have been warned Jeg's has them in the $7K range This one $3500
Re: For Sale/ Wanted - Small Block Engine - 1st Quarter
[Re: 6PAX]
#3279584
01/01/25 11:13 AM
01/01/25 11:13 AM
Posts: 777 SE Wisconsin, USA
RP's R/T's
SE Wisconsin, USA
Heads were cleaned and magnifluxed. See pictures and contact me with any further questions. Heads were modified to add steel O-rings (a High-Perf mod from 'back-in-the-day). Some light porting on intake and exhaust- no break-through or welds. The only issue the Mag-ing identified was slight micro-cracks on the inside of the combustion side of the spark-plug threads (this is common from over-torquing spark plugs) Bronze guides in place. $1500 Would prefer not to ship. Located in SE Wisconsin
PRW 1.6 ratio roller rocker arm kit for Small Block
[Re: Rocket]
#3280693
01/05/25 01:23 PM
01/05/25 01:23 PM
Posts: 963 CT
Rocket
CT
New PRW 1.6 ratio roller rocker arm kit containing all parts needed to install these rocker arms including steel bushed rocker arms, rocker arm shafts, spacers, shims, adjusters, steel shaft hold downs and hold down hardware. This kit is new in the box and is PRW part # 3231812.
Price is $495 shipped
Email me at procketrichard@hotmail.com with any questions or for more pictures.
