Page 1 of 3 1 2 3
For Sale/ Wanted - Small Block Engine - 1st Quarter #3279403
12/31/24 07:57 PM
12/31/24 07:57 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
2 W-9 Alum Heads [Re: moparts] #3279462
12/31/24 10:45 PM
12/31/24 10:45 PM
Capital of Narcissism
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Never run/mounted, almost new #P5007065, as pictured
One port was deburred, port cleaned up, and valve job, reported to flow 350cfm
Heads were pressure tested, tech states there is lot more left in the heads flow wise.
$1550 pair, plus shipping, PM, delivery east of Mississippi possible for extra fee
"We found that, in general, people don't stop to think whether there might be more information that would help them make a more informed decision," said study co-author Angus Fletcher,
4.04" Cast Pistons New For sale [Re: jcc] #3279476
12/31/24 11:25 PM
12/31/24 11:25 PM
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
No pins, new, CH approx 1.56"
8 .030 over, small dish as pictured
$60 OBO plus shipping, PM
A8 9" Deck 340 mains [Re: jcc] #3279479
12/31/24 11:42 PM
12/31/24 11:42 PM
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
New Not sure if a 48 or 59 Degree These are not for the faint of heart or light of Wallet
You have been warned grin
Jeg's has them in the $7K range
This one $3500
Re: For Sale/ Wanted - Small Block Engine - 1st Quarter [Re: moparts] #3279571
01/01/25 11:40 AM
01/01/25 11:40 AM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
70 B-body voltage regulator mounting bracket. $15
New chrome coil cover & coil mounting bracket. $20
NOS Cal Custom chrome radiator cap. $20
NOS Cal Custom chrome battery hold down. $25
Four new extra wide chrome valve cover hold down clamps. $10 for the set
New exhaust manifold heat stove to air cleaner flexible hose. $20
NOS fan clutch 3769614 for 1974 all V-8 engines. $100
Factory warning light type oil pressure sending unit. $10
Gauge type oil pressure sending unit. $20
Vintage Cal Custom 14" finned aluminum air cleaner with filter. $100
New Mopar Performance chrome water neck. Was bolted on an engine but then taken back off before the engine was ran. $10
AC alternator bracket from a mid 70s 360. $10
New Mr. Gasket chrome oil filter cover. $15
9 Chrome t-handle valve cover bolts. $10
Factory starter, part/casting #3755259. This came off of my Dart about 10 years ago. Worked fine then, been sitting on a shelf ever since. $40
Two 318 driver side spool motor mounts pt#3642811. One is used and one is NOS. $20 for the used. $35 for the NOS.
Edelbrock Elite small block valve covers EDL-4295 with bolts, breather & PCV valve. Very nice condition. $200
NOS Cal Custom chrome dagger dipstick handle. $25
Mopar Performance 5 blade radiator fan and clutch. $100
Pioneer Automotive cylinder head dowel pins. 21 pieces 1/4" x 5/8". $10
New set of COMP Cams 973-16 - Inner Valve Springs. $45
Chrome single groove alternator pulley. $15
1975 Date coded alternator. Part #3874271. $25
Rev-n-nator Coil and programmable ICU. $200
Vintage Cal Custom scoop style air cleaner. Includes often missing matching wingnut. $300
New in boxes QTP 2 1/2" electric exhaust cutouts #QTEC50, stainless y-pipes #10250 and remote controller #10900. $654 total price at Summit. $550
Prices do not include shipping.
Email: gt340 @ yahoo.com
Re: For Sale/ Wanted - Small Block Engine - 1st Quarter [Re: 6PAX] #3279584
01/01/25 12:13 PM
01/01/25 12:13 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
Heads were cleaned and magnifluxed.
See pictures and contact me with any further questions.
Heads were modified to add steel O-rings (a High-Perf mod from 'back-in-the-day).
Some light porting on intake and exhaust- no break-through or welds.
The only issue the Mag-ing identified was slight micro-cracks on the inside of the combustion side of the spark-plug threads (this is common from over-torquing spark plugs)
Bronze guides in place.
$1500
Would prefer not to ship.
Located in SE Wisconsin
Re: For Sale/ Wanted - Small Block Engine - 1st Quarter [Re: moparts] #3279618
01/01/25 01:01 PM
01/01/25 01:01 PM
East Brunswick, NJ
budman1965 Offline
budman1965  Offline
East Brunswick, NJ
Power steering pumps for small block engines. Think these are 70's era. Complete with mounting brackets. Have 2 or 3. $25 each. Also have a Saginaw type pump with no brackets. $15. Contact Bud: Kramden426 at aol.com
Re: For Sale/ Wanted - Small Block Engine - 1st Quarter [Re: moparts] #3280429
01/04/25 01:39 PM
01/04/25 01:39 PM
Roseburg, OR
O
Oregon AAR Offline
Oregon AAR  Offline
O
Roseburg, OR
Looking for TA 340 engine # 297240. Any leads and/or info is much appreciated.
SCAT Forged 360 & 5.9 Magnum Stroker Rotating Assembly - 408 [Re: Oregon AAR] #3280686
01/05/25 02:10 PM
01/05/25 02:10 PM
CT
Rocket Offline
Rocket  Offline
CT
New SCAT and Diamond Forged Mopar 360 & 5.9 Magnum Stroker Rotating Assembly - 408”
I have a new SCAT forged rotating assembly for 360 & 5.9 Magnum Mopar engines. All parts are new high-quality parts. Final cubic inches will be 408”.
The assembly includes the following parts.
• SCAT forged 4.000” crankshaft part # 4-360-4000-6123
• SCAT forged H-beam connecting rods with APR 2000 bolts part # 2-360-6123-2124A
• Diamond Forged flattop 4.030” bore pistons (0.030” oversize) part # 51026
• Trend wrist pins - 0.984” part # TPD-G9842750155
• Diamond wrist pin locks
• Mahle file fit ring set with Moly ductile iron top rings part # MAH4035MS
• Speed Pro Tri metal Competition Series rod bearings part # 8-7125CH
• Clevite P-Series full groove main bearings part # MS-1266P
If you are looking for a 360 stroker with lower compression, I can substitute the pistons and connecting rods for new SRP 4.030” dished pistons part # 220156 (16.9 cc piston head volume) and new Eagle H-beam rods part # CRS6123C3D (360 stroker assembly only).
These rotating assemblies will need balancing.
The price for this complete kit with the Diamond flat top pistons and SCAT rods is $2,750 plus shipping cost.
The price for this complete kit with the SRP dished pistons and the Eagle H-beam rods is $2,600 plus shipping cost.
I can also meet in CT.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
SCAT Forged 340 Stroker Rotating Assembly – 414 ci” [Re: Rocket] #3280688
01/05/25 02:14 PM
01/05/25 02:14 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new SCAT forged rotating assembly for 340 Mopar engines. All parts are new high-quality parts. Final cubic inches will be 414”.
• SCAT forged 4.000” crankshaft part # 4-340-4000-6123
• Diamond Forged flattop 4.060” bore pistons (0.020” oversize) part # 51028
• Trend wrist pins part # TPD-G9842750155
• Perfect Circle file fit ring set with Moly ductile iron top rings part # 315-0036.065
• Clevite P-Series full groove main bearings part # MS-1344P
This rotating assembly will need balancing.
Price for this complete kit is $2,750 plus shipping cost.
Small Block Forged 4.060” Bore Pistons for 3.454” Stroke [Re: Rocket] #3280690
01/05/25 02:19 PM
01/05/25 02:19 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new set of 8 Mopar Performance pistons and wrist pins Mopar part# P4876973 for a 3.454” stroke crankshaft. Specs are 4.060” bore, 1/16, 1/16, 3/16 ring set, 0.984” wrist pin, flat top with ~ 5 cc eyebrows, listed by Mopar as 10.5 compression ratio. Compression height is ~ 1.72” per my measurement.
Price for the set is $480 shipped in the lower 48 states. I will ship internationally for the extra cost.
New BRC 4.030" Forged Pistons and pins for 3.79" Stoke Crank [Re: Rocket] #3280691
01/05/25 02:20 PM
01/05/25 02:20 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a set of New BRC 4.030" forged flat top pistons and pins for a 3.79" stroke small block crankshaft. Compression height is ~ 1.57" and the ring lands are 1/16, 1/16 and 3/16. Pins are 0.984”. Approximately 6cc valve reliefs.
These pistons can be used in aftermarket race blocks or stock 360/5.9 magnum engine blocks with 4.030” finished bores.
Price is $475 shipped in the lower 48 states. I will ship elsewhere for the added cost.
BRC 3.79 P1.JPG (506 downloads)
BRC 3.79 P2.JPG (508 downloads)
BRC 3.79 P3.JPG (507 downloads)
BRC 3.79 P4.JPG (510 downloads)
PRW 1.6 ratio roller rocker arm kit for Small Block [Re: Rocket] #3280693
01/05/25 02:23 PM
01/05/25 02:23 PM
CT
Rocket Offline
Rocket  Offline
CT
New PRW 1.6 ratio roller rocker arm kit containing all parts needed to install these rocker arms including steel bushed rocker arms, rocker arm shafts, spacers, shims, adjusters, steel shaft hold downs and hold down hardware. This kit is new in the box and is PRW part # 3231812.
Price is $495 shipped
PRW 1.6 Pic 4.jpg (507 downloads)
PRW 1.6 Pic 5.jpg (504 downloads)
PRW 1.6 Pic 6.jpg (506 downloads)
PRW 1.6 Pic 8.jpg (506 downloads)
W2 Mopar Performance Small Block Exhaust Roller Rockers [Re: Rocket] #3280697
01/05/25 02:28 PM
01/05/25 02:28 PM
CT
Rocket Offline
Rocket  Offline
CT
I have new Mopar Performance 1.5 ratio roller W2 exhaust rocker arms for the W2 & W5 Race heads using offset drilled blocks and shafts. I will sell individual rockers or sets of 2, 4,6 or 8 as needed. Individual rockers are $40 each plus shipping. A set of 8 is $280 shipped.
T&D rocker arm and shaft kit for W2 Econo cylinder heads [Re: Rocket] #3280701
01/05/25 02:32 PM
01/05/25 02:32 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new T&D rocker arm and shaft kit for W2 Econo cylinder heads that have the cast in pedestals. T&D part # 8100. Includes the rockers, shafts, spacers, hold downs and bolts. These are 1.5 rocker arm ratio.
Price is $1250 plus shipping.
Holley 750 CFM - 4160 - Vacuum Secondaries - New [Re: Rocket] #3280703
01/05/25 02:34 PM
01/05/25 02:34 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new Holley 750 vacuum secondaries Part # 0-3310S for sale. It has been sitting boxed on the shelf for a couple years. I am not going to use this so I am offering it up for sale. Below is the description from Holley.
“The 0-3310S is a shiny aluminum version of the classic 0-3310 - a hot rod staple for over four decades! Dual feed fuel inlets assure you get all the fuel you need while its vacuum secondaries and manual choke make it amazingly universal. The famed 0-3310 is one of ten inaugrual inductees into the Hot Rod Magazine Speed Parts Hall of Fame! Its well known performance calibration and 750 CFM airflow keep it on top still today. Don't trust your performance to just anyone, Holley is the only modular carburetor company that has been in business for over 100 years and has powered every NASCAR champion since the 60's.
Features:
- Vibratory polished for good looks
- Performance upgrade for stock to mildly modified vehicles
- Universal calibration for easy bolt-on performance
- Manual choke (cable actuated - hand controlled) for precise cold start control
- Vacuum secondaries for use on wide variety of vehicles. Compensate for all vehicle weights, gearing & transmissions to allow smooth opening of secondaries.
- Dual feed fuel inlets for constant high volume fuel delivery
- Compatible with GM, Chrysler, and Ford A/T kickdown linkage. Additional parts may be required.
- Power valve blow-out protection
- 100% wet-flow tested by Holley technicians to assure it arrives ready to run!”
Price is $390 shipped in the lower 48 states. I will ship to other destinations for any additional cost.
Holley 3310 Vac Pic 1.JPG (502 downloads)
Holley 3310 Vac Pic 2.JPG (503 downloads)
Holley 3310 Vac Pic 3.JPG (502 downloads)
Holley 3310 Vac Pic 5.JPG (500 downloads)
Six Pack Center Carb 4144-1 - reconditioned [Re: Rocket] #3280705
01/05/25 02:36 PM
01/05/25 02:36 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a Holley six pack center carb part # 4144-1 that was factory reconditioned by Holley. Has not been run since reconditioned.
$750 shipped in the lower 48 states. I will ship internationally for the added cost.
Email me at procketrichard@hotmail.com for more pictures or any questions.
Milodon Small Block Gear Drive - Used [Re: Rocket] #3280707
01/05/25 02:39 PM
01/05/25 02:39 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a nice used Milodon gear drive part # 13600 for small bock engines. This was used on my W2 headed 360 bracket motor. It provided rock solid ignition and cam timing. I was saving this for a future rebuild however I sold the car so this is no longer needed. All the gears and bearings are in great shape. Pictures do not show the mounting bolts but they will be included.
Description from Summit Racing is as follows:
“Milodon timing-gear drive assemblies are designed for all-out competition, but work equally well in any application. Their proven fixed idler gear system is capable of maintaining consistent cam timing without siphoning off power the way 4-gear types can. Timing changes are easy via Milodon's adjustable bolt pattern cam gears and hub assemblies. Made for strength and durability, these gear drives will last indefinitely. They are available in a flat-cover style, which uses a stock-type water pump, or an injected/blown style, which doesn't use a stock-type pump.”
Price is $325 shipped in the lower 48 states. I will ship internationally for the added cost if any.
MSD Digital 6AL ignition module part #6425 - New [Re: Rocket] #3280710
01/05/25 02:42 PM
01/05/25 02:42 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new MSD Digital 6AL ignition module part #6425 with built in rev limiter. It comes with all the original hardware still in the package and the harness.
Here is the description from Summit Racing.
“Advance with the digital power of your popular favorite--MSD 6AL ignitions. With less power draw and higher output, MSD moves you with "the fire to drive" in a digital powerhouse! Inside microprocessors, updated circuits and efficient components monitor and handle every firing and rev limit to produce more power while pulling less current. Don't worry; features that made their 6AL boxes your first choice remain but with improved output--more than135mJ of spark energy for every firing with 530+ volts to the coil! And, to go with the new power, a new look. These digital 6AL ignition controllers are sleek with a lower profile. Wiring is routed out one end through a sealed and locked connector and two rotary dials to set rpm limit are positioned right on top--easier installation, super easy access and a clean, neat appearance under the hood. Controllers are supplied with wiring harness and components you need for install plus, vibration mounts. Increased output and proven multiple-spark power--MSD digital 6AL ignition controllers are a definite win-win!.”
Price is $275 shipped in the lower 48 states. I will ship internationally for the added cost if any.
360 & 5.9 Magnum Ductile Iron Main Caps-New [Re: Rocket] #3280713
01/05/25 02:46 PM
01/05/25 02:46 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a couple sets of new ductile iron main caps available for main journals 1 through 4. These are Mopar Performance caps. The center 3 caps are 4 bolt main. These are the same caps that came standard on R3 4 bolt blocks. I have installed these caps on small blocks before by milling off the ends of the center caps to leave them 2 bolt. See pictures for the 3 modified center caps installed on a 340 stroker engine. These caps are more stout than the stock 360 or magnum engine caps and are an excellent upgrade for any high performance build. A line bore will be needed when installing new caps as well as some machining for the thrust bearing on the #3. You can use your stock engine #5 cap.
Price is $300 shipped per set in the lower 48 states. I will ship internationally for the additional cost.
Email procketrichard@hotmail.com for more information.
Page 1 of 3 1 2 3
