Autometer Level 1 External Digital Pro Shift Light
[Re: moparts]
#3279498
01/01/25 01:13 AM
01/01/25 01:13 AM
Posts: 6,422 Heaven
EvilB1Dart
Heaven
(SOLD) AutoMeter Level 1 External Digital Pro Shift Light Part# ATM-5343 Works and looks excellent. Had a very small crack on mount base (not an issue, but see last photo), crack is repaired. Only selling due to digital dash has an internal shift light. Located in Arizona. Comes with instructions. Retails for $185 at Summit or JEGS, etc. https://www.summitracing.com/parts/atm-5343$85 shipped in the U.S. Accept PayPal, check or money order. PM me if you want it. Thanks Moparts! ((SOLD)
"If you can still hear your fears - shift a gear."
CR12B early B-body fuel tank,
[Re: moparts]
#3279534
01/01/25 09:21 AM
01/01/25 09:21 AM
Posts: 792 Midwest
fuseable
Midwest
CR12B early B-body fuel tank, has sump box welded in, sump box is about 1" below tank with 4" to 5" tall inside tank. Tank was coated inside and out by a company called Tank Renu. here is a link. https://www.gastankrenu.com/Also has Aeromotive fuel filter with -10 outlet, -8 return,-6 vent. Also, can use a stock pickup, I have a new one to go with it. to plug the hole where it goes. 400$ Prefer local pick up, will ship at buyer's expense, I think it would be pretty expensive though. Located in Kansas City area. Pm if interested.
(Brand New) Aeromotive A1000 Electric Fuel Pump #11101
[Re: 360DOUG]
#3279846
01/01/25 10:34 PM
01/01/25 10:34 PM
Posts: 6,422 Heaven
EvilB1Dart
Heaven
Brand new - box still sealed.
Aeromotive A1000 electric fuel pump.
Located in Arizona.
Accept PayPal, Check or Money Order for payment. $412 PayPal - Goods & Services (3% fees) $400 PayPal - Friends & Family (no fees). $400 Check or Money Order.
Ships when funds clear.
Re: For Sale - Race Parts - 1st Quarter
[Re: 6PAX]
#3280073
01/02/25 08:19 PM
01/02/25 08:19 PM
Posts: 5,813 Detroit area
6PAX
Detroit area
Howard's solid flat tappet cam for Mopar big blocks, part number CL722322-08. See links below for specifications. I bought this cam for my engine with the intention of taking the car to the track when the car was finished being restored along with the engine being built but I have changed my mind about racing the car and decided to go with a milder hydraulic cam instead. I had this cam installed in my engine on the engine stand but it never was run and is essentially new. $375 + shipping. I also have a new set of Comp Cams 973-16 inner valve springs I was going to use with this cam and Edelbrock RPM heads that I am asking $40 for. https://www.summitracing.com/parts/HRS-CL722322-08https://www.summitracing.com/parts/cca-973-16gt340 at yahoo.com
[Re: moparts]
#3280115
01/02/25 11:08 PM
01/02/25 11:08 PM
Posts: 1,591 CT
mrrandyj
CT
Rear trailer tie down brackets for most A, B, or E body vehicles (doesn’t fit the 7 ¼ rear axle). These piggyback onto the bottom of the stock shock plate mounting nuts and then 4 more nuts hold these tie down brackets on. You must have enough extra thread hanging down on the bottom of your U-bolts to fit the ¼” thick tie down bracket and another nut. No disassembly necessary, just slide the brackets over the extra thread on your U-bolts, install the included nuts, tighten them down and you’re done. Takes about 10 minutes to install. These eliminate all the hassles that come with using axle straps. Fits A, B, and E body cars with the standard shock plates like shown in the pictures. $60.00 per pair plus shipping. I also have these available for cars with CalTracs, same price. Made in the USA. Email mrrandyj@aol.com
[Re: moparts]
#3280241
01/03/25 02:41 PM
01/03/25 02:41 PM
Posts: 19,658 Las Vegas
Al_Alguire
Las Vegas
Cleaning out the shelves and have some electronics for sale. All the stuff was installed in a car but none of it was ever used. All was working when removed. PM me here, text/call at 7 zero 7 9 8 zero 2 one 6 7 First part is an MSD 8970 3 stage retard. $275 obo Next Biondo Mega 200 delay box $200 obo Edelbrock 41900 nitrous controller $400 obo Next is an NX Nitrous controller and MSD Window switch $300 oboi
Carter Competition Series Carb
[Re: moparts]
#3280342
01/03/25 11:43 PM
01/03/25 11:43 PM
Posts: 161 Albert Lea, MN
GTX5877
Albert Lea, MN
Rebuilt Carter Competition Series 9625SA 625cfm AFB 4bbl carb with electric choke. Performance carb prior to the Edelbrock Performer. Date code A1.
$250 plus shipping
PM or call 5zero7-373-59zero7 days. No texts
1967 Dart GTS 426 Gen III Hemi 1968 Hemi Cuda 572 SS/AH Clone 1988 Chrysler LeBaron Coupe S/S 2003 Dodge Ram 1500 4dr SLT lowered 2012 Ram 1500 2wd Lowered 1970-1/2 Camaro Z-28 1974 VW Karman-Ghia
Catch Can for Vacuum Pump
[Re: moparts]
#3280634
01/05/25 11:08 AM
01/05/25 11:08 AM
Posts: 307 Long Island, NY
ValiantRich
Long Island, NY
Moroso Breather Tank, catch can part # 85465, 1 qt., Round, Aluminum, Natural, Filtered Breather, Mounting Bracket, Petcock. New Never Used. $75 rich1981@optonline.net
GZ Motorsports vacuum pump
[Re: ValiantRich]
#3280638
01/05/25 11:30 AM
01/05/25 11:30 AM
GTX5877
Albert Lea, MN
Used GZ Motorsports vacuum pump with 12AN fittings and billet aluminum pulley. No history on it as it came with an engine purchase. Very clean and no apparent damage, just don't need. No brackets, was mounted on a motor plate.
New they're $650, will take $350 + shipping
PM or call 5zero7-373-59zero7 days. Sorry, no texts
Cross posted
