For Sale - Race Parts - 1st Quarter #3279407
12/31/24 07:01 PM
12/31/24 07:01 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Autometer Level 1 External Digital Pro Shift Light [Re: moparts] #3279498
01/01/25 01:13 AM
01/01/25 01:13 AM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
(Sold pending funds)
AutoMeter Level 1 External Digital Pro Shift Light Part# ATM-5343
Works and looks excellent. Had a very small crack on mount base (not an issue, but see last photo), crack is repaired. Only selling due to digital dash has an internal shift light. Located in Arizona.
Comes with instructions. Retails for $185 at Summit or JEGS, etc.
https://www.summitracing.com/parts/atm-5343
$85 shipped in the U.S. Accept PayPal, check or money order.
PM me if you want it. Thanks Moparts!
"If you can still hear your fears - shift a gear."
Re: Autometer Level 1 External Digital Pro Shift Light [Re: EvilB1Dart] #3279504
01/01/25 01:52 AM
01/01/25 01:52 AM
Chesterfield Twp. Mi.
John Burdine Offline
Our universal leaf spring buckets allow you to lower the front spring eye height on your current leaf spring setup for lower ride height and adjustability. Aftermarket buckets are also designed to provide more strength and rigidity when welded in and gusseted to your cage with bars. A stronger front leaf spring mount will yield better 60ft times are the spring/Cal Trac/ Traction Device has a rigid push point with no flex.
Universal Design
Some Traction Devices May only Utilize 3 of 4 Holes Provided
Installation Requires Cutting Factory Sheetmetal
Installation Requires Part To Weld In
Bracing/Bars To Boxes Suggested For Strength – Better 60 Ft Times
Does Not Include Hardware
Innovative Racecraft
$200 shipped lower 48 states
John 586-222-2728 or pm
Re: Autometer Level 1 External Digital Pro Shift Light [Re: John Burdine] #3279505
01/01/25 01:54 AM
01/01/25 01:54 AM
Funkhouser shock mount kit for 3" axle tube diameter.
$175 shipped lower 48 states
Re: Autometer Level 1 External Digital Pro Shift Light [Re: John Burdine] #3279506
01/01/25 01:55 AM
01/01/25 01:55 AM
Richmond R&P 4.56 for Dana 60
P/N 69-0053-1
New in box
$300 shipped lower 48 states
Re: Autometer Level 1 External Digital Pro Shift Light [Re: John Burdine] #3279507
01/01/25 01:56 AM
01/01/25 01:56 AM
AAR Fiberglass newThis extra tall Hemi Scoop fits a 1966-67 B-Body, Mounting studs included, inside flange. Ready to sand, paint and install.
Size: 33″ across the front, 30 1/2″ across the back, 38″ long, 3 1/2″ tall in the front, 1″ tall in the back.
NEW $350 Local pick up only NO SHIPPING
John 586-222-2728
Re: Autometer Level 1 External Digital Pro Shift Light [Re: John Burdine] #3279508
01/01/25 02:00 AM
01/01/25 02:00 AM
Pair of Very clean Centerline Auto Drags. 15 x 10, 5 on 4 1/2 bp, 3 3/8 bs. some lite scotchbrite marks, but super clean, no pitting.
$500 local pick up or $50 per wheel shipped lower 48 states only.
Re: Autometer Level 1 External Digital Pro Shift Light [Re: John Burdine] #3279509
01/01/25 02:01 AM
01/01/25 02:01 AM
These Centerlines just came out of the original boxes. 1st time tires have ever been mounted, never bolted on a car yet. 15 x 8 1/2, 5 on 4 1/2 bolt pattern, 4 7/8 bs. couple very lite marks, but super clean. Hoosier 30 x 9 radial slicks, lots of tread. local pick up only. NO SHIPPING
$600
CR12B early B-body fuel tank, [Re: moparts] #3279534
01/01/25 09:21 AM
01/01/25 09:21 AM
Midwest
fuseable Offline
fuseable  Offline
Midwest
CR12B early B-body fuel tank, has sump box welded in, sump box is about 1" below tank with 4" to 5" tall inside tank. Tank was coated inside and out by a company called Tank Renu. here is a link.
https://www.gastankrenu.com/
Also has Aeromotive fuel filter with -10 outlet, -8 return,-6 vent. Also, can use a stock pickup, I have a new one to go with it. to plug the hole where it goes.
400$
Prefer local pick up, will ship at buyer's expense, I think it would be pretty expensive though.
Located in Kansas City area.
Pm if interested.
Used MSD 2-Step [Re: moparts] #3279553
01/01/25 10:01 AM
01/01/25 10:01 AM
Northwest, Ohio
360DOUG Offline
360DOUG  Offline
Northwest, Ohio
Used MSD 2-Step Part#8739. Asking $40.00 plus shipping. Located in Ohio 43612. PM if interested
2-step 2.jpg (477 downloads)
(Brand New) Aeromotive A1000 Electric Fuel Pump #11101 [Re: 360DOUG] #3279846
01/01/25 10:34 PM
01/01/25 10:34 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Brand new - box still sealed.
Aeromotive A1000 electric fuel pump.
Located in Arizona.
Accept PayPal, Check or Money Order for payment.
$412 PayPal - Goods & Services (3% fees)
$400 PayPal - Friends & Family (no fees).
$400 Check or Money Order.
Ships when funds clear.
Re: For Sale - Race Parts - 1st Quarter [Re: moparts] #3280072
01/02/25 08:15 PM
01/02/25 08:15 PM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
Autometer Sport Comp II tachometer and gauges. Included are a 3690 tachometer with shift light and 3692 volt, 3637 water temp and 3627 oil pressure gauges. The gauges are all electrical gauges. I bought these for a car I used to own but sold the car before ever using them. $450 for everything. Selling as a package only.
gt340 at yahoo.com
Autometer gauges.JPG (432 downloads)
Re: For Sale - Race Parts - 1st Quarter [Re: 6PAX] #3280073
01/02/25 08:19 PM
01/02/25 08:19 PM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
Howard's solid flat tappet cam for Mopar big blocks, part number CL722322-08. See links below for specifications. I bought this cam for my engine with the intention of taking the car to the track when the car was finished being restored along with the engine being built but I have changed my mind about racing the car and decided to go with a milder hydraulic cam instead. I had this cam installed in my engine on the engine stand but it never was run and is essentially new. $375 + shipping. I also have a new set of Comp Cams 973-16 inner valve springs I was going to use with this cam and Edelbrock RPM heads that I am asking $40 for.
https://www.summitracing.com/parts/HRS-CL722322-08
https://www.summitracing.com/parts/cca-973-16
gt340 at yahoo.com
Howard's Cam.JPG (428 downloads)
Howard's Cam4.JPG (428 downloads)
Comp Inner Springs2.JPG (428 downloads)
Re: For Sale - Race Parts - 1st Quarter [Re: 6PAX] #3280076
01/02/25 08:27 PM
01/02/25 08:27 PM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
Never used Cheetah Shifter 70001B with cover. I was planning on converting my Dart from a 4-speed to an automatic and bought this shifter to use. I have decided however to leave the car a 4-speed so I have no need for the shifter. I took it out of the box and set it with the cover over it on the hump in my car to see what it would look like but that's the only time it's been out of the box other than for the pictures. $500 including the cover.
gt340 at yahoo.com
Re: For Sale - Race Parts - 1st Quarter [Re: moparts] #3280115
01/02/25 11:08 PM
01/02/25 11:08 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
Rear trailer tie down brackets for most A, B, or E body vehicles (doesn’t fit the 7 ¼ rear axle). These piggyback onto the bottom of the stock shock plate mounting nuts and then 4 more nuts hold these tie down brackets on. You must have enough extra thread hanging down on the bottom of your U-bolts to fit the ¼” thick tie down bracket and another nut. No disassembly necessary, just slide the brackets over the extra thread on your U-bolts, install the included nuts, tighten them down and you’re done. Takes about 10 minutes to install. These eliminate all the hassles that come with using axle straps. Fits A, B, and E body cars with the standard shock plates like shown in the pictures. $60.00 per pair plus shipping. I also have these available for cars with CalTracs, same price. Made in the USA.
Email mrrandyj@aol.com
Re: For Sale - Race Parts - 1st Quarter [Re: moparts] #3280241
01/03/25 02:41 PM
01/03/25 02:41 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Cleaning out the shelves and have some electronics for sale. All the stuff was installed in a car but none of it was ever used. All was working when removed. PM me here, text/call at 7 zero 7 9 8 zero 2 one 6 7
First part is an MSD 8970 3 stage retard. $275 obo
Next Biondo Mega 200 delay box $200 obo
Edelbrock 41900 nitrous controller $400 obo
Next is an NX Nitrous controller and MSD Window switch $300 oboi
Carter Competition Series Carb [Re: moparts] #3280342
01/03/25 11:43 PM
01/03/25 11:43 PM
Albert Lea, MN
GTX5877 Offline
GTX5877  Offline
Albert Lea, MN
Rebuilt Carter Competition Series 9625SA 625cfm AFB 4bbl carb with electric choke. Performance carb prior to the Edelbrock Performer. Date code A1.
$250 plus shipping
PM or call 5zero7-373-59zero7 days. No texts
1967 Dart GTS 426 Gen III Hemi
1968 Hemi Cuda 572 SS/AH Clone
1988 Chrysler LeBaron Coupe S/S
2003 Dodge Ram 1500 4dr SLT lowered
2012 Ram 1500 2wd Lowered
1970-1/2 Camaro Z-28
1974 VW Karman-Ghia
Catch Can for Vacuum Pump [Re: moparts] #3280634
01/05/25 11:08 AM
01/05/25 11:08 AM
Long Island, NY
ValiantRich Offline
ValiantRich  Offline
Long Island, NY
Moroso Breather Tank, catch can part # 85465, 1 qt., Round, Aluminum, Natural, Filtered Breather, Mounting Bracket, Petcock. New Never Used. $75 rich1981@optonline.net
catch can 2.jpg (124 downloads)
catch can.jpg (124 downloads)
GZ Motorsports vacuum pump [Re: ValiantRich] #3280638
01/05/25 11:30 AM
01/05/25 11:30 AM
Albert Lea, MN
GTX5877 Offline
GTX5877  Offline
Albert Lea, MN
Used GZ Motorsports vacuum pump with 12AN fittings and billet aluminum pulley. No history on it as it came with an engine purchase. Very clean and no apparent damage, just don't need. No brackets, was mounted on a motor plate.
New they're $650, will take $350 + shipping
PM or call 5zero7-373-59zero7 days. Sorry, no texts
Cross posted
1974 VW Karman-Ghia
360 Small Block Ductile Iron 4 Bolt Main Caps-New [Re: GTX5877] #3280646
01/05/25 11:55 AM
01/05/25 11:55 AM
CT
Rocket Offline
Rocket  Offline
CT
I have a couple sets of new ductile iron main caps available for main journals 1 through 4. These are Mopar Performance caps. The center 3 caps are 4 bolt main. These are the same caps that came standard on R3 4 bolt blocks. I have installed these caps on small blocks before by milling off the ends of the center caps to leave them 2 bolt. See pictures for the 3 modified center caps installed on a 340 stroker engine. These caps are more stout than the stock 360 or magnum engine caps and are an excellent upgrade for any high performance build. A line bore will be needed when installing new caps as well as some machining for the thrust bearing on the #3. You can use your stock engine #5 cap.
Price is $300 shipped per set in the lower 48 states. I will ship internationally for the additional cost.
Email procketrichard@hotmail.com for more information.
