Re: Problem with spark / ballast resistor ??
[Re: Texican]
#3280465
01/04/25 04:45 PM
01/04/25 04:45 PM
Posts: 6,589 ohio
ruderunner
ohio
Sounds like your problem is upstream of the ballast. You should have battery voltage to the ballast when connected.
The ballast drops the voltage to something like 6 to 8 when the engine is running.
I'd be tracing the wire back to the ignition switch.
Angry white pureblood male
[Re: ruderunner]
#3280466
01/04/25 04:50 PM
01/04/25 04:50 PM
Posts: 12,798 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I've never seen one be anything but open or closed. Run or not. But maybe someone else has.
[Re: Texican]
#3280470
01/04/25 04:58 PM
01/04/25 04:58 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I'd be looking for heat damage at the firewall and ignition switch connectors.
[Re: Texican]
#3280472
01/04/25 05:00 PM
01/04/25 05:00 PM
Posts: 44,094 Bend,OR USA
Cab_Burge
If that is the old single piece Mopar dual ballast resistor that sounds correct as far as once it is warmed up, both sides are wire wound resistors one has more winding than the other hence the difference in ohms and voltage drop through the resistors. Wire wound resistors will change ohm readings and voltage loss when warmed up What problem are you having with the car?
[Re: Cab_Burge]
#3280504
01/04/25 06:06 PM
01/04/25 06:06 PM
Posts: 6,589 ohio
ruderunner
ohio
Except his description indicates the low voltage on the input side of the resistor.
[Re: Texican]
#3280548
01/04/25 08:14 PM
01/04/25 08:14 PM
Posts: 6,654 nowhere
Sniper
nowhere
That’s what is strange. The voltage to the ballast (blue/white - green/white) is 12v until I plug it in, then it drops. Not strange at all, it is perfectly normal. You are reading, with the ballast disconnected, what is called the open circuit voltage. As in with no load applied. Add a load, the ballast circuit, and your supply voltage drops again normal. In your case is should be darn near battery voltage at one end and something like 6-8v at the other. You have a source voltage issue, probably the bulkhead connector is dirty or the ignition switch.
