Aluminum Main caps for Big Block #3280438
01/04/25 01:13 PM
01/04/25 01:13 PM
MN
JERICOGTX Offline OP
MN
Who makes the best caps for a Big Block these days? Is BCR still selling them?
Thanks.
69 GTX 68 Road Runner
Re: Aluminum Main caps for Big Block [Re: JERICOGTX] #3280440
01/04/25 01:44 PM
01/04/25 01:44 PM
S.E. Michigan
TruPerformance Offline
S.E. Michigan
I bought a set from Jerry a couple years ago and was very happy with the quality. I think he is still making them.
https://www.bcrproducts.com/
I bought the girdle caps, in case I wanted to add the girdle in the future. He offers regular caps and girdle caps. So, the block is prepped for it, but I didn't go with the girdle since I was worried about the added clearance and sealing issues as well. But, if I was choosing new caps, I figured why not protect for it anyways. Next time I pull the motor to check things over I will see how the bearings look and it will tell me if I should add the girdle or not...just something to consider.
1963 Belvedere (mine)
1969 Roadrunner (wife's)
Re: Aluminum Main caps for Big Block [Re: JERICOGTX] #3280457
01/04/25 03:55 PM
01/04/25 03:55 PM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
Thanks.
Do they have a predictable lifespan, and need changing out like Alum Rods?
I forbid my content here from being learned and used by artificial intelligence systems.
Re: Aluminum Main caps for Big Block [Re: jcc] #3280490
01/04/25 05:17 PM
01/04/25 05:17 PM
MN
MN
Thanks.
Do they a predictable lifespan, and need changing out like Alum Rods?
Not that I know of. I ran them in my old 499, but when that engine let go, the caps got torn up from connecting rod pieces flying through the bottom end. I’m planning on building a 512ci street engine for my 69. It should be capable of making around 700hp on pump gas, but I want the block to have a chance to live.
Re: Aluminum Main caps for Big Block [Re: JERICOGTX] #3280491
01/04/25 05:19 PM
01/04/25 05:19 PM
tboomer Offline
tboomer  Offline
Jeff...Have you checked with Indy? That's where mine originated from in my 512.. wave
Re: Aluminum Main caps for Big Block [Re: JERICOGTX] #3280508
01/04/25 06:13 PM
01/04/25 06:13 PM
I've used two different brands,440 Source and the other that is no longer available. whiney
Both sets are still living in drag race motors with no known issues so far luck
Re: Aluminum Main caps for Big Block [Re: JERICOGTX] #3280541
01/04/25 07:57 PM
01/04/25 07:57 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Mine are from Best Machine. I know they're closed. I just don't know if they were in house product or supplied from a vendor. This will be season 11 on them.
Ok
Re: Aluminum Main caps for Big Block [Re: cudatom] #3280545
01/04/25 08:02 PM
01/04/25 08:02 PM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
I find it amazing how much life is reported on alum caps and alum rods are mostly the opposite.
Alum is known to hate stress, and is forgiving under load and why it is preferred as a main cap?
But flexing and being loaded is what eventually kills all alum, so I find this a bit odd.
I am not disputing it, I'm trying to explain it.
Re: Aluminum Main caps for Big Block [Re: jcc] #3280552
01/04/25 08:26 PM
01/04/25 08:26 PM
DracerX Offline
DracerX  Offline
Looking at it from a physics standpoint, the rods are exposed to compressive and tensile loads, where the main caps are mostly compression.
I'm sure there is some tensile loads in some outer locations of a main cap, but not the whole cross section as a rod when the piston reverses direction at TDC of the exhaust stroke for example.
Re: Aluminum Main caps for Big Block [Re: DracerX] #3280582
01/04/25 11:29 PM
01/04/25 11:29 PM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
I agree, stress reversal is a killer, but my thinking here is the loading point on a main cap is both compressive at the highest load point during rotation and has tension, all moving as it rotates, and the cap effectively resists opening up, meaning the load is not typical stress reversal, but it is constantly varying and moving at the same time.
So loading and unloading.
Make sense?
Re: Aluminum Main caps for Big Block [Re: JERICOGTX] #3280612
01/05/25 08:50 AM
01/05/25 08:50 AM
Minn
SportF Offline
SportF  Offline
Minn
Re: Aluminum Main caps for Big Block [Re: SportF] #3280623
01/05/25 10:13 AM
01/05/25 10:13 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I've heard of the old-style Indy caps cracking and IIRC 440Jim had a Best Machine cap crack... nothing lasts forever
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Aluminum Main caps for Big Block [Re: jcc] #3280698
01/05/25 01:29 PM
01/05/25 01:29 PM
DracerX Offline
DracerX  Offline
jcc, that does make sense. The load point is rotating across the face of the lower bearing from one end to the other. Not a symmetrical load into both main bolts. Kind of like a wave of stress from one end to the other in the cap.
Re: Aluminum Main caps for Big Block [Re: DracerX] #3280702
01/05/25 01:33 PM
01/05/25 01:33 PM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
We agree.
Re: Aluminum Main caps for Big Block [Re: jcc] #3280843
01/06/25 08:05 AM
01/06/25 08:05 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
What kills main caps is detonation - aluminum main caps can dampen some of it - hence the reason they became so popular. The best replacement main caps were the old Mopar Ductile Iron main caps and they are not available anymore - My choice as of late has been the aluminum main caps - my last set were from 440 source and they are still available - but it takes a competent machine shop to install them
Re: Aluminum Main caps for Big Block [Re: Brad_Haak] #3280846
01/06/25 08:13 AM
01/06/25 08:13 AM
gregsdart Offline
gregsdart  Offline
Good reason to make sure you get new parts made of the right aluminum. For a street motor build, the amount of stress cycles will be low, compared to a race motor, so my guess is life should be excellent .
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Aluminum Main caps for Big Block [Re: gregsdart] #3280862
01/06/25 09:38 AM
01/06/25 09:38 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
The BCR website infers that the original Indy-style caps are made of inferior material... which I'm stuck with for my backup block cuz that's what I could find when it was machined years ago. Mine's going together w/ a budget girdle to help reduce the "flagpole effect" that may be a contributing factor to them cracking.
Best Machine's were 7075 IIRC, which is "top of the line" for rockers, etc. The fact that 440JIm cracked one makes me wonder what the "ideal" aluminum grade would be for caps. BCR doesn't specify what they use.
Re: Aluminum Main caps for Big Block [Re: DoubleD] #3280870
01/06/25 09:57 AM
01/06/25 09:57 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
I scored 2 sets of those ... low deck ... years ago , one set I had put into one of my 383 blocks , the other set are still in the box waiting for me to put into something else .
Mainstream Media is the new Pravda
Re: Aluminum Main caps for Big Block [Re: Brad_Haak] #3280883
01/06/25 10:20 AM
01/06/25 10:20 AM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
7075 would be my first choice, 2024 would also be in the running, 6061, as nice and affordable as it is, is not up to the task IMO in any case.
With all the machining talent I see many here many exhibit, can't see why homemade is not an option. it's not as they are a real complicated item, just need to be precise.
Re: Aluminum Main caps for Big Block [Re: jcc] #3280909
01/06/25 11:26 AM
01/06/25 11:26 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I made my main caps out of 7075. No issues. Also made the main caps on my Dana 60 out of 7075 as well. Definitely, a stronger and better grade over 6061.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
