mopar stage iv and stage v heads #3280352
01/04/25 04:48 AM
01/04/25 04:48 AM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi ,
anyone using this heads and liking the results ?
dont need to hear all about your aluminum heads , just interested in what these can do.
thank you !
Re: mopar stage iv and stage v heads [Re: calrobb2000] #3280421
01/04/25 12:09 PM
01/04/25 12:09 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Unported, basically like stock heads.
Ported…….depends on how good the porting is.
Re: mopar stage iv and stage v heads [Re: fast68plymouth] #3280607
01/05/25 08:19 AM
01/05/25 08:19 AM
Cent, OH
Mopar.70 Offline
Mopar.70  Offline
Cent, OH
I'm running a set of stage 6's. Bought a complete motor here on moparts a 500" 440 based few years ago and they were on it. Was going to be a street/strip deal but traded cars and went full race. The porting was done by compuflow back in the day. Are 2.25 intake and can't remember the exhaust. My car is light, and cam is mild but running 6.40's at 106. My next motor is a full on Indy motor (Callies block and Indy 325 heads, 540) when it's time to pull this, they are working now but for reasons below I won't continue with them. For me these got me started back, and this was mainly a "budget" based in choice on running them. I think they can make some power, just depends on budget and what you want to do.
- valve pockets are deep and hold oil
- have to run spacers on an RB and then with that valley covers are not easy to come up with to seal off everything, bent the thin one that came with the motor when I added a vacuum pump, ended up using a SST one from Hughes to get things to work
- They are older and have been ran, heli-coils in at all the intake manifold holes and they have been redone and just a pain
- My engine guy couldn't find a replacement 2.25 3/8 stem intake valve so had to clean them up and re-use the old ones
- They are no longer supported
Re: mopar stage iv and stage v heads [Re: Mopar.70] #3280669
01/05/25 12:37 PM
01/05/25 12:37 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I had a Duster with stage V heads 20 years ago. PRetty basic stuff, 470" stroker, 12.5-1 smallish roller. Mine were ported dont recall any numbers from that. But thew car went 9.69 best at 3070lbs.
Re: mopar stage iv and stage v heads [Re: Al_Alguire] #3280739
01/05/25 03:15 PM
01/05/25 03:15 PM
Kansas
Thelma133 Offline
Thelma133  Offline
Kansas
If you are getting such a nice block, get a B-1 head
Re: mopar stage iv and stage v heads [Re: fast68plymouth] #3280795
01/05/25 08:58 PM
01/05/25 08:58 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Indeed.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: mopar stage iv and stage v heads [Re: BloFish] #3280826
01/06/25 01:02 AM
01/06/25 01:02 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
Don Little had a pair of Stage V BB Mopar heads for sale a couple of years back. He did one intake port and got around 290cfm out of it with the stock 2.08" intake valve. I guess he figured out the Edelbrock heads would be easier to build for NHRA SS. I think they are good for NHRA Stock and SS, probably too much work for other classes.
Floyd Lippencott IV
Re: mopar stage iv and stage v heads [Re: calrobb2000] #3280841
01/06/25 07:54 AM
01/06/25 07:54 AM
gregsdart Offline
gregsdart  Offline
An all out build using iron ported heads in a 3000 lb race car should be capable of hi 9s. It is all about how you want to get there. My prioritys
Max cube stroker
Set it up for 2.25 intake/1.81 standard location valve heads. This allows everything from factory 906 type heads to Indy 440,-1 heads in the future. And from an easy 500 hp to as much as 900 hp if you go nuts.
The nice thing about these heads is actually thier limitations. Put them on a 540 cube shortblock, use a converter that will flash about 5000, shift somewhere around 5600 to 5800 and you have a motor that is fairly easy on parts yet still have the capability of low tens high nines depending on weight . My first decent bracket motor 43 years ago used 906 ported heads, a hogged out tunnelram and two 800 carbs, no quench, 11/1 compression, yet still went 10.20 at 136 mph with traction issues. At the time i ran a 4.10 gear and 33 x 14 slicks.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: mopar stage iv and stage v heads [Re: gregsdart] #3280855
01/06/25 09:09 AM
01/06/25 09:09 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Way back in the Tech Archives there were 2 sets of Stage V's that were ported,
One set by Dwayne (Fast68Plymouth) and the other set (that were mine) was done by Chuck Millen at Muscle Motors.
Ported I believe they flowed as good (or slightly better) than the Edelbrock Performer RPM's that had only recently came out. This was maybe 2005 or 6?
both sets went ~260-ish at .400 and 280-285-ish at .500.
As a general rule, 260 @ .400 is a very good flow number for a standard port window High torque B Wedge motor. With the right cam and compression it's enough to get you safely/easily into the 550-ish HP potential. Which is good enough for a lot of non racer combos.
I put my set on a very strong running 508 RB in my 70 Charger R/T, and after a few years I sold that motor to another Moparts Member PHJ426 put a six pack on it and dropped it in his 72 Roadrunner. The motor certainly didn't lack for torque or Horsepower.
They added material to the port roofs and floors and IIRC they had a slightly improved short side radius, particularly on the exhausts.
If you dig into the Archives I'm pretty sure the thread is still there, there were a lot of good "nuggets" that applied to BB wedge porting in General. I would think a set of the Muscle Motors Stealth heads would be more economical now, but if I had a set available and wanted to look stock....
WIZE
In Car:
Re: mopar stage iv and stage v heads [Re: Streetwize] #3280858
01/06/25 09:24 AM
01/06/25 09:24 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Here you go...prolly everything you would ever want to know:
http://www.moparts.org/Tech/Archive/bb/55.html
Just noticed..this was back in 2003!!! 22 years ago!!
Glad to see a bunch of us old "Moparts geezers" are still here...and still friends too.
WIZE
In Car:
Re: mopar stage iv and stage v heads [Re: mr_340] #3280879
01/06/25 10:09 AM
01/06/25 10:09 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Good for a NON COMPETIVE F.A.S.T. build ...
Mainstream Media is the new Pravda
Re: mopar stage iv and stage v heads [Re: JohnRR] #3281682
01/09/25 05:59 PM
01/09/25 05:59 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
fast did the V's i have back in '03. i did end up going to a different piston/edelbrock head combo i like after a few years driving on them: strictly street driven car. flow numbers on the heads were as least as good as OOTB edelbrocks. i thought the V's may have made a smidgin' more power than my edelbrocks. truth is there are pro's and con's to either head and it just depends on what a person wants to do. i kept the V's thinking one of these days they'd be a nice 496 pump gas street head, but don't know if i'll ever do it. i think they can be used in F.A.S.T. racing. i haven't given up on iron but aluminum at times can be easier. there was no cost advantage for me to go to the edelbrocks vs the V's.
Re: mopar stage iv and stage v heads [Re: calrobb2000] #3281748
01/09/25 11:46 PM
01/09/25 11:46 PM
Those heads are really old designs down
If you want better heads buy the newer ones available now and never be sorrywork scope up twocents
Re: mopar stage iv and stage v heads [Re: lewtot184] #3281814
01/10/25 09:13 AM
01/10/25 09:13 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
They can be used for FAST , I know of one guy that is running a set. I've been kicking around finding a set but I need to get my junk going first and see what it does with the ported 906's Dwayne did for me before deciding to throw more money at my first round fodder ...
Re: mopar stage iv and stage v heads [Re: JohnRR] #3281859
01/10/25 11:58 AM
01/10/25 11:58 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
That's what I'd do. You can also compare flow charts to see if there is any meaningful difference.
Re: mopar stage iv and stage v heads [Re: lewtot184] #3281891
01/10/25 02:31 PM
01/10/25 02:31 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
If the 906s Dwayne did are pretty much maxed out, then the only thing I'd expect from Stage V heads would be improved durability over the long run
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: mopar stage iv and stage v heads [Re: JohnRR] #3281910
01/10/25 03:29 PM
01/10/25 03:29 PM
A727Tflite Offline
A727Tflite  Offline
I haven’t forgot you about selling mine. Hopefully in the next few weeks I’ll have an answer.
Re: mopar stage iv and stage v heads [Re: A727Tflite] #3282350
01/12/25 09:45 PM
01/12/25 09:45 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
No problem
Re: mopar stage iv and stage v heads [Re: Brad_Haak] #3282352
01/12/25 09:46 PM
01/12/25 09:46 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Mine are not maxed out.
Re: mopar stage iv and stage v heads [Re: JohnRR] #3282603
01/14/25 09:56 AM
01/14/25 09:56 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Neither set was Maxed out and they were both around 285-290 at .650-700. You can probably get as much or more peak out of a full tilt 915 or 906 but I would bet the better short side would mean the V's would have a better Average flow from say .450 to .650 which usually equates to more torque/VE and power. and both sets were substantially better than an OOTB Edelbrock and legal for FAST.
I'm not sure what the Quickest A12 6 pack car is running in FAST now but I know I wouldn't put thousands into porting a 1 off nearly 60 year old 906 if the V is FAST legal. Also, My Set had a 2.19 intake and with a lighter/skinnier stem valve there would certainly be a bit more flow to get out of narrowing the guide bosses further. Still there's only so much you can do with the Valve angles and the short turn with a BB wedge. But I would think a well worked V would ET better than a 906 that flows the same peak numbers. It might work well in a 72 400" Charger Ralley as opposed to a 71 383 block super bee... if a 72 is legal in Fast.
As we see the 72 and up Thermoquad can make mad power in the LA Duster. The Charger is definitely more Aerodynamic than a Plymouth so maybe the 72 Ralley TQ at about 517-528" Low deck with the Stage V's might be a contender.
It's been a Long while since I was involved "back in the day" but if the Carb rule is still intact, I would think a TQ low deck would beat and A12 69-1/2 at the same (or near same) weight.
I remember mentioning to Tom Cannon (When He ran the Red T/A challenger) that I thought a 71-72 340 TQ Duster or Demon would be the quickest LA combo that could be built...because of the Plastic Fantastic, some of the old-schoolers (who smoked) used to use TQ's as ASH trays, lol) could really move some air.....
Who was the Rod Shop guy that was the Stock eliminator champ in the Early 70's? Dave Boertman? He ran a 71 Charger 383 so the tricks to make them hook are out there. I know the 71-72's are lighter than the 73-74's.
Update: According to MyLife, Dave is still Alive and well at 84!!
WIZE
In Car:
