Re: Steel braided brake line ??
[Re: Stanton]
#3280170
01/03/25 10:42 AM
01/03/25 10:42 AM
Posts: 3,022 A shed in England
Tig
A shed in England
Shouldn't be an issue, all my flexi's are -3 stainless braided hoses. I made them up myself, had no problems, just need the right fittings and hoses. Should be able to make out a rear one in the pic below. I think these are Speedflows stuff but it seems Earls, Goodrich etc all make the fittings
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Stanton]
#3280174
01/03/25 11:10 AM
01/03/25 11:10 AM
Posts: 3,324 West Coast, USA
jbc426
West Coast, USA
Doctor Diff once told me to only use DOT Approved brake lines. It's not hard to find them in the desired length with the fittings you want on-line.
1970 Plymouth 'Cuda #'s 440-6(Stock drivetrain in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's & EFI. 1968 Plymouth Barracuda Convertible Paxton Boosted 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 3.91's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#3280207
01/03/25 12:34 PM
01/03/25 12:34 PM
Posts: 9,190 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
It's not hard to find them in the desired length with the fittings you want on-line. Why do you think I'm asking here !?!? Pretty much exhausted the online search - wondering if anyone actually knows of a source.
[Re: Stanton]
#3280333
01/03/25 11:01 PM
01/03/25 11:01 PM
Posts: 12,801 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I need a flex brake line to pass through a crossmember. Bulkead fittings are out of the question. What I need is a:
stainless braided flex line with standard brake flare ends - either male or female.
Does such a thing exist ?? Not without using some sort of an adapter. -3 Teflon hose is AN and inverted flare is an SAE standard.
[Re: Stanton]
#3280417
01/04/25 11:50 AM
01/04/25 11:50 AM
jbc426
West Coast, USA
It's not hard to find them in the desired length with the fittings you want on-line. Why do you think I'm asking here !?!? Pretty much exhausted the online search - wondering if anyone actually knows of a source. Frustrating isn't it !?!? There are several, but good luck in your search.
[Re: jbc426]
#3280475
01/04/25 05:03 PM
01/04/25 05:03 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Fragola and Earls are two places that do oddball stuff no one else does.
Speedflow also does some nice, useful, stuff. Australian but sold here.
[Re: CMcAllister]
#3280537
01/04/25 07:50 PM
01/04/25 07:50 PM
Posts: 19,658 Las Vegas
Al_Alguire
Las Vegas
Fragola, Earls and Goodrich all make the line and fittings. Thousands of cars out there using the stuff out there
[Re: varunner]
#3280670
01/05/25 12:38 PM
01/05/25 12:38 PM
Al_Alguire
Las Vegas
Would be a brand I would avoid, chinas best.
[Re: Al_Alguire]
#3280722
01/05/25 02:07 PM
01/05/25 02:07 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Would be a brand I would avoid, chinas best. No-name Amazon/ebay trash is the absolute worst. I could tell some stories...
[Re: CMcAllister]
#3280729
01/05/25 02:25 PM
01/05/25 02:25 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Not without using some sort of an adapter. -3 Teflon hose is AN and inverted flare is an SAE standard. This is the conclusion I had come to but thought I'd ask on here just in case. I think I'll end up bending a short length of nickel/copper to pass through the frame with female flare connectors to join the lengths. Many thanks to all for the input.
[Re: Stanton]
#3280763
01/05/25 05:16 PM
01/05/25 05:16 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Not without using some sort of an adapter. -3 Teflon hose is AN and inverted flare is an SAE standard. This is the conclusion I had come to but thought I'd ask on here just in case. I think I'll end up bending a short length of nickel/copper to pass through the frame with female flare connectors to join the lengths. Many thanks to all for the input. They do these to use as a pass through in a frame rail. Something like that could be made fairly easily with NPT on the ends to use whatever adapter you needed. Or get steel 3/8-24 IF fittings and weld them in.. If that is what you are looking for.
