A friend of mine just bought a 1977 360 motorhome motor.It has 44 thousand miles on it very clean inside of the motor and the antifreeze was like new.Like any other motorhome motor it sat for long time in between use.
Questions for you guys.
The motor has a 2 barrel carb.
Will this motor have a RV cam in it?
Anyone or anyway of finding out what lift cam it is?
Anyone use the exhaust manifolds. They are center dump.
What intake would you put back on this motor?
We are trying to do this on the cheap. The motor will go into a Duster.
