CR12B early B-body fuel tank
[Re: moparts]
#3279533
01/01/25 09:19 AM
01/01/25 09:19 AM
Posts: 792 Midwest
fuseable
Midwest
CR12B early B-body fuel tank, has sump box welded in, sump box is about 1" below tank with 4" to 5" tall inside tank. Tank was coated inside and out by a company called Tank Renu. here is a link. https://www.gastankrenu.com/Also has Aeromotive fuel filter with -10 outlet, -8 return,-6 vent. Also, can use a stock pickup, I have a new one to go with it. to plug the hole where it goes. 400$ Prefer local pick up, will ship at buyer's expense, I think it would be pretty expensive though. Located in Kansas City area. Pm if interested.
Re: For Sale - Parts - B Body - 1st Quarter
[Re: moparts]
#3279563
01/01/25 10:29 AM
01/01/25 10:29 AM
Posts: 5,813 Detroit area
6PAX
Detroit area
70 RR/GTX short grill molding. $25
70 RR/GTX long bottom of grill molding. $50
Nice pair of B-body k-frame splash shields from a 70 GTX. $40
Used heater core from 1970 Charger. $20
New 68-70 B-body chrome door lock button ferrules. $15
Pair of front disk brake calipers part # KH84167. These were on my 70 Road Runner $50
1971 Road Runner/GTX passenger side headlight bezel. $30
71 B/E-body ignition light harness complete with delay harness. $100
71-74 B-body rally dash wiper switch #3488766. $25
1973-74 Charger quarter panel end caps #3615808 & 09. $30 for the pair.
2 reproduction 1968-70 B-body front armrests. $40
Speedometer cable from a 70 Road Runner. $30
Pair of 780/781 torsion bars for 66-71 B-bodies and 70-71 E-bodies. Media blasted and primed. $150
Hood latch panel with hood spring from a 1970 Road Runner. $50
70 Road Runner driveshaft. 51.5" c. to c. on u-joints. $150 (local pick-up only)
2 Heater box fresh air vent cables from a 70 Road Runner. $25 for the pair
Wire harness plastic cover that goes behind driver kick panel. $10
70 B-body voltage regulator mounting bracket. $15
68-70 B-body both sides lower windshield moldings. $40 for the pair
70 B-body automatic column to big block 727 trans. linkage. Nice set. $200
1970 Plymouth B-body 4 piece headlight bezel outer long screw set. $5
1970 Sport Satellite/Coronet non-rally dash woodgrain radio bezel. Nice condition. $65
1970 A/B-body steering column Ignition key light and harness. $65
1970 Satellite/Road Runner/GTX driver side rear bumper reverse light assembly. Very nice $40
70 B-body black rear seat belt clip holders. $25
Deluxe black three spoke steering wheel from a 69 model. It has some cracks. Has a nice center horn pad with Dodge emblem and horn contact. $125
Two frame strut rod shields. Both same side part #4434. $5 each.
Miscellaneous 1965 Satellite parts lot. Included are one blower switch and bezel (no knob), one wiper switch with bezel and knob, two door jamb dome light switches and two chrome knobs that I am not sure what they are for. $25 for the lot.
A/B 68-70 black seat belt guide for where the seat belt goes through the bench seat. I only have one. $10
Two 1966 (maybe 65 as well) full circle three spoke steering wheel horn rings. Both have minor pitting. One has some abrasions on a couple of the spokes. They are part number 2643689. $25 for the pair.
Throttle cable from a 1971 Charger with a 440 (I believe it will fit 70-71 B and 70-up E with 383-440 4bbl). $30
New 1970 B-body rally dash with knob style radio woodgrain decal kit. $85
Driver side deluxe chrome remote mirror. Pretty nice chrome but glass is loose. $50
1 Set of new 1969 reproduction side marker lenses. Year One pt. #BN812. $80
New B-body quarter window roller kit less the two pivoting rollers. $30
1 Pair torsion bar adjusting bolts and nuts. $20
New 1970 B-body knob style woodgrain radio bezel decal. $18
Three spoke black steering wheel with full horn ring and Dodge horn button. The wheel is in pretty good shape. It doesn't have any cracks, just typical scuffs/scratches so it could use a polishing. The horn ring has some light pitting but looks decent. $250
2 1967 B-body headlight buckets. $20 for the pair
1967 4bbl intake manifold #2806178. Date 2-13-67. Sandblasted and primed. $100
1967 Plymouth B-body black steering column lower dash cover. Has hairline crack. $10
8 3/4 rearend pinion snubber, $25
1967 B-body ignition switch light. $25
1970 Plymouth B-body owner's manual package with inserts. Mint condition. $80
1970 Belvedere/Satellite/Road Runner/GTX sales brochure. $40
1970 Plymouth Rapid Transit System brochure. $20
1970 "Plymouth Makes It" brochure. $20
1970 Dodge Scat Pack brochure. $20
1970 Dodge dealer sales brochure. $20
Chilton's 1965-72 Belvedere/Satellite/Road Runner/GTX repair manual. Good condition. $30
440 Six Pack key ring that looks like a 440 Six Pack air cleaner lid. $20
1970 GTX Muscle cars trading card #94 featuring a red GTX. $3
1970 Road Runner (purple) Road Warriors trading card. $3
Prices do not include shipping.
gt340 at yahoo.com
[Re: moparts]
#3279980
01/02/25 01:46 PM
01/02/25 01:46 PM
Posts: 13 Sidney Illinois
tgt51
Sidney Illinois
71 Road Runner hood with callouts. Solid with only light surface rust on under side. $400.00 plus shipping from 61877 or will bring to Indy Cylinder head in March if paid for.
E-mail: tgt51@hotmail.com
[Re: moparts]
#3280111
01/02/25 11:02 PM
01/02/25 11:02 PM
Posts: 1,591 CT
mrrandyj
CT
Rear trailer tie down brackets for most A, B, or E body vehicles (doesn’t fit the 7 ¼ rear axle). These piggyback onto the bottom of the stock shock plate mounting nuts and then 4 more nuts hold these tie down brackets on. You must have enough extra thread hanging down on the bottom of your U-bolts to fit the ¼” thick tie down bracket and another nut. No disassembly necessary, just slide the brackets over the extra thread on your U-bolts, install the included nuts, tighten them down and you’re done. Takes about 10 minutes to install. These eliminate all the hassles that come with using axle straps. Fits A, B, and E body cars with the standard shock plates like shown in the pictures. $60.00 per pair plus shipping. I also have these available for cars with CalTracs, same price. Made in the USA. Email mrrandyj@aol.com
Wood wheel
[Re: moparts]
#3280182
01/03/25 11:48 AM
01/03/25 11:48 AM
Posts: 4,082 ct.
moparlouie
ct.
64-67 OEM wood wheel in excellent original condition, No cracks, real nice chrome, the horn wire is there but not pictured, getting very hard to find in this shape. $550. Plus shipping. lafrancebiglou@aol.com
Have been a member for years!
