Proforged LCA Install
#3279458
12/31/24 08:57 PM
12/31/24 08:57 PM
Posts: 586 Kentucky
clovis
Kentucky
Just looking for the procedure to install the Proforged poly LCA bushing.
'75 Plymouth Duster ‘65 Plymouth Belvedere
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Proforged LCA Install
[Re: Cab_Burge]
#3279522
01/01/25 08:17 AM
01/01/25 08:17 AM
Posts: 586 Kentucky
clovis
Kentucky
Sorry, here is the internet picture. This is for the ‘65 Belvedere, I’m putting disc brakes on it and just replacing bushing while I’m there. The lower control arm bushing were both wore where the pin was into the shell. I am using the stock pins. I will take some pictures in the shop this morning. With the overlay around the top of the shell just not sure of the sequence and what to push on. I can see where I could support the bottom of the inside bushing while I press the pin on but it still seems I have to put pressure on the material on top unless I press on the pin.
[Re: clovis]
#3279525
01/01/25 08:37 AM
01/01/25 08:37 AM
Posts: 44,097 Bend,OR USA
Cab_Burge
You may have to, probably will have to, cut the outer steel case out of the control arm to drive them out to install the new one. I ended up ordering OEM ones as the HP like your new ones I had several years back wouldn't press in tight enough to not spin in the lower control arm either way I tried to install them Try yours like they are first and go from there Please let us know how it goes
[Re: B1MAXX]
#3279585
01/01/25 11:15 AM
01/01/25 11:15 AM
Posts: 586 Kentucky
clovis
Kentucky
These have the shells so I have already removed the old shells. They seem to be a tight fit. The control arm measures 1.45, the old bushing is about 1.465, the Proforged is about 1.480 at the bottom and about 1.485 at the top.
[Re: clovis]
#3279668
01/01/25 12:55 PM
01/01/25 12:55 PM
Posts: 23,980 Here
jcc
No soup for you!!!
No soup for you!!!
Here
Have tried freezing them and then measuring to see if that might assist insertion?
I forbid my content here from being learned and used by artificial intelligence systems.
[Re: jcc]
#3279737
01/01/25 02:55 PM
01/01/25 02:55 PM
Posts: 586 Kentucky
clovis
Kentucky
I already have the old bushings off the pins, did it just like you described. So lube the shell, press in just lying something flat over the top of the bushing, then press the pin in? If so, do I need to support the bottom of the inner bushing while pressing in the pin?
Doug, I am actually following your setup you posted over on b bodies only. I am using the poly LCA and strut rod bushings then using the offset bushings in just forward mount on the upper control arm.
[Re: clovis]
#3279746
01/01/25 03:21 PM
01/01/25 03:21 PM
Posts: 3,324 West Coast, USA
jbc426
West Coast, USA
Good job on doing it yourself. I like synthetic disc brake grease for lubricating bushings of all sorts. It won't attack plastic or rubber and persists for a long time. Make sure you don't torque down the fasteners until you suspension is at the ride height you are going to have. Always re-check torque on suspension components after a few miles of use.
1970 Plymouth 'Cuda #'s 440-6(Stock drivetrain in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's & EFI. 1968 Plymouth Barracuda Convertible Paxton Boosted 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 3.91's (closest thing to an automatic 5 speed going)
[Re: clovis]
#3279751
01/01/25 03:39 PM
01/01/25 03:39 PM
Posts: 10,135 MI, usa
dvw
MI, usa
Doug, I am actually following your setup you posted over on b bodies only. I am using the poly LCA and strut rod bushings then using the offset bushings in just forward mount on the upper control arm. Press the bushing in the arm first. Then support the bottom of the bushing (correct sized socket works well) while pressing the stud in. I've had some bushings that didn't fit real snug on the shaft. It has never seemed to be an issue. Doug
[Re: dvw]
#3280308
01/03/25 07:37 PM
01/03/25 07:37 PM
Posts: 586 Kentucky
clovis
Kentucky
Just wanted to update for the next person. The proforged bushing have about .030 of interference fit so they are difficult to press in. They actually roll up material as you press them in. The pins installed without too much resistance. Anyway, they are done and back on the car.
[Re: BDW]
#3280313
01/03/25 08:15 PM
01/03/25 08:15 PM
Posts: 586 Kentucky
clovis
Kentucky
No, they went all the way in, I just pulled them out of the press to remove the material that was loading up so they would seat all the way in. Great idea on the sanding, in hind sight I wish I would have captured it with a bolt and nut and stuck it in my drill press and sanded down the sides.
