5.7 Hemi Heavy Duty (HD) vs Overhead Cam Engine #3279366
12/31/24 05:03 PM
12/31/24 05:03 PM
Southern Missouri
Wailin D Offline OP
Wailin D  Offline OP
Southern Missouri
It looks like they are bringing back the 5.7 Hemi. This would be an excellent opportunity to make some upgrades that I am calling the 5.7 Hemi Heavy Duty. Most of the upgrades can be done with existing Mopar parts. This would make a bullet proof 5.7 Hemi. See what you think below.
There are rumors that Mopar is working on an overhead cam V8. The advantage of an overhead cam engine is that you can control the cam timing of the intake and exhaust separately with individual cams. Something I learned from Reignited Cycle and Automotive YouTube site is that this can be done without having separate cams for the intake and exhaust (https://www.youtube.com/watch?v=j58EQTTYe08). In the 2008 Dodge Viper they put two cams within a single cam that enabled them to control the intake and exhaust separately with a cam within the block. Personally, this seemed to be a much better approach that keeps the identity of the Hemi rather than an overhead cam engine.
The majority of these parts come from the Mopar parts bin.
6.2 Hemi stock forged crankshaft (same stroke as the 5.7 Hemi)
6.2 Hemi stock forged connecting rods
Forged pistons – 5.7 Hemi pistons are smaller than 6.2 pistons – vendors Mahle, Wiseco, Manley
6.2 Hemi oil pump or better yet the Melling 10452HV
6.2 or 6.4 Hemi Exhaust manifolds
Camshaft material upgrade – Cam within a cam controlling the intake and exhaust separately made of a billet core or other materials more durable than stock camshafts
Camshaft Lifters – Johnson Lifters
Re: 5.7 Hemi Heavy Duty (HD) vs Overhead Cam Engine [Re: Wailin D] #3279500
01/01/25 02:33 AM
01/01/25 02:33 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Its baffled me why Dodge/Ram left the cam in cam technology on the shelf and didn't incorporate it into the Hemi platform at some point, it would've been a nice upgrade circa 2015 when the 8 speed was main stream, the restyles that same year and the introduction of the hellcat. Yeah it would add expense but its cheaper than a DOHC monstrosity and keeps packaging reasonable
