RAISING CRANK CENTERLINE HEIGHT=WEIGHT TRANSFER? #327902
05/25/09 07:23 AM
05/25/09 07:23 AM
Ohio
Lil Wedge Offline OP
Ohio
I have a small block Dart with a motor plate and was wondering the effects of raising the engine 1-2 inches. It is currently at 13 inches. I need some weight transfer, and can't afford the lightweight brakes or wheels.
Re: RAISING CRANK CENTERLINE HEIGHT=WEIGHT TRANSFER? [Re: Lil Wedge] #327903
05/25/09 07:40 AM
05/25/09 07:40 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Raising the car both back and front helped mine.
I moved the shock mount up in the back 1.5" (ladder/coil) and about
the same up front with the torsion bars.
I was actually able to spin 14" x 32" slicks with a stock stroke
340, before. My engine simply didn't have enough power to plant
the tires and needed to get the car up to drive under it.
Softening the shock settings (ft. and rear) would be first option
but, you've probably tried that.
Re: RAISING CRANK CENTERLINE HEIGHT=WEIGHT TRANSFER? [Re: S/ST 3040] #327904
05/25/09 10:47 AM
05/25/09 10:47 AM
Ohio
Ohio
Getting ready to try that, Raising the body 1 hole in the rear seemed to help consistancy in the heat, slowed the 60' slightly, and in the fall , let it back down and the 60' would come right back. The Darts 111 in wheelbase doesn't help, would be much easier with 108 like the rest of the A bodies.
Re: RAISING CRANK CENTERLINE HEIGHT=WEIGHT TRANSFER? [Re: Lil Wedge] #327905
05/25/09 07:45 PM
05/25/09 07:45 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Do it, but remember to re-set your pinion angle.
Boffin Emeritus
Re: RAISING CRANK CENTERLINE HEIGHT=WEIGHT TRANSFER? [Re: polyspheric] #327906
05/25/09 11:16 PM
05/25/09 11:16 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
My crank CL is 15 3/8". This is on my back half 4 link SB Duster,its nose heavy but works well.
Re: RAISING CRANK CENTERLINE HEIGHT=WEIGHT TRANSFER? [Re: Lil Wedge] #327907
05/26/09 12:18 AM
05/26/09 12:18 AM
AndyF Offline
AndyF  Offline
High and Mighty trick!
