Re: Assembly Line markings
[Re: jrp16]
#3278758
12/29/24 12:36 AM
12/29/24 12:36 AM
Posts: 1,669 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Isn't there a big Mopar junkyard in AZ? That would seem to be a good place to browse.
I would pay close attention to these areas:
1. Cowl, especially near the master cylinder. 2. Rear springs, above the front eye. You may find two different pastel colored latex stripes. 3. Differential casting, axle housing tubes, center rear part of axle housing. 4. K-frame bottom side, especially near the idler arm bracket. 5. Transmission and drive shaft, especially at U-joints. 6. Steering gear box. 7. Cooling fan clutch. 8. Anti-sway bar. 9. Center link, other front end parts, especially lower control arms. 10. Torsion bars.
[Re: jrp16]
#3278801
12/29/24 10:39 AM
12/29/24 10:39 AM
Posts: 22,003 A collage of whims
topside
A collage of whims
Yup, as A12 indicates, there isn't the time on a moving assy line to sort through a bin & check part #s. So it's logical that some parts would have a color code. Color codes were typical across the industry (GM, Ford, Chrysler) for items like springs, driveshafts, etc. Re-work for wrong parts kills production efficiency. That includes sub-assemblies, like engine & trans, where a valve cover often has a 3 or 5 to tell an assembler whether the engine gets a 4-speed or AT attached.
[Re: topside]
#3278826
12/29/24 01:01 PM
12/29/24 01:01 PM
Posts: 1,218 rust belt
Moparite
rust belt
I see that this subject has been on Graveyard carz. And they put the factory inspection markings on. There has to be some factory literature on what color goes where. If you are looking for100% factory correct that's where to look. Might want to check this out.
[Re: Moparite]
#3278855
12/29/24 03:05 PM
12/29/24 03:05 PM
topside
A collage of whims
I'd rather rely on guys like Mike Mancini than GYC - GYC takes some liberties with their restorations, and appear to apply markings based on what "should" be, as opposed to what the car really got. That's maybe splitting hairs, but if one wants it 100% "correct", the markings that specific car had are the truest, right ? That said, some markings would seem reliable, as far as parts selection (t-bars, diffs, springs, driveshafts, etc). Others, like suspension inspections or fluid fills, also seem fairly reliable, at least within that car's assembly plant procedures...or maybe the color a particular inspector used ? Obviously they can't always be determined due to decay, or prior events, like someone painting over the original markings.
[Re: topside]
#3278953
12/29/24 11:14 PM
12/29/24 11:14 PM
Posts: 27,616 So Cal
autoxcuda
So Cal
I'd rather rely on guys like Mike Mancini than GYC - GYC takes some liberties with their restorations, and appear to apply markings based on what "should" be, as opposed to what the car really got. That's maybe splitting hairs, but if one wants it 100% "correct", the markings that specific car had are the truest, right ? That said, some markings would seem reliable, as far as parts selection (t-bars, diffs, springs, driveshafts, etc). Others, like suspension inspections or fluid fills, also seem fairly reliable, at least within that car's assembly plant procedures...or maybe the color a particular inspector used ? Obviously they can't always be determined due to decay, or prior events, like someone painting over the original markings. Yea, Mike Mancini and GYC are a distance apart in quality and correctness. Mancini is in an other (upper) league.
[Re: jrp16]
#3278998
12/30/24 09:33 AM
12/30/24 09:33 AM
Posts: 13,322 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
Some markings were for part ID and some were for confirmation of assembly. The part ID markings were obviously consistent while the assembly markings varied. This is a complicated subject. Given all the variables, without evidence of the particular markings that your car came with, it will be impossible to get them all 'perfect' again. I have not seen any information on the '73 models, but there is information available on the earlier models. That should help some by giving you some insight into how Mopar did things. And some markings would probably even be the same. In fact, depending on what your intentions for the car are, you could just use the earlier model information to 'mark' your car and no one (except you) would be the wiser on any differences.
Master, again and still
[Re: sixpakdodge]
#3279087
12/30/24 01:46 PM
12/30/24 01:46 PM
DaveRS23
Benton, IL.
Just to be clear; that is David Wise. Not me.
But my '71 GTX did get O.E. Certed Silver at the 01 'Nats. Missed Gold by less than a point. 2132 (94.75%) out of 2250. 95% for Gold.
