Assembly Line markings #3278640
12/28/24 10:32 AM
12/28/24 10:32 AM
Arizona
jrp16 Offline OP
jrp16  Offline OP
Arizona
I apologize if this question has been asked/answered, but does anyone have information on the location of the assembly markings (and colors used) on the 73 Charger SE?
Thank you,
Re: Assembly Line markings [Re: jrp16] #3278758
12/29/24 12:36 AM
12/29/24 12:36 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Isn't there a big Mopar junkyard in AZ? That would seem to be a good place to browse.
I would pay close attention to these areas:
1. Cowl, especially near the master cylinder.
2. Rear springs, above the front eye. You may find two different pastel colored latex stripes.
3. Differential casting, axle housing tubes, center rear part of axle housing.
4. K-frame bottom side, especially near the idler arm bracket.
5. Transmission and drive shaft, especially at U-joints.
6. Steering gear box.
7. Cooling fan clutch.
8. Anti-sway bar.
9. Center link, other front end parts, especially lower control arms.
10. Torsion bars.
Re: Assembly Line markings [Re: kentj340] #3278768
12/29/24 03:53 AM
12/29/24 03:53 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
My feeling about the markings on most of those components listed is not that they are "inspection" marking for defects or that they are okay or put on correctly but that they are the "correct" per the fender tag or the broadcast or aka build sheet. When you have for instance several stacks or assembly line bins of torsion bars and you just need to slide them in place to ready them for the next assembly line procedure that worked just needs to know what color identifier torsion bars to pick without looking at the ends of each torsion bark for the cast in numbers. The same goes for most of the items like on your list. Example here with the torsion bars just hanging. Where is the inspector and what did they inspect when they put the (ID) paint on them? I have somewhere a much higher resolution image more clearly showing the torsion bar specification paint markings not yet in the final assembled assembly position. Not all markings are for final assembly inspection, but some are for assembly line ID so line workers are helped to ID the component more quickly and to not have to read the part numbers or spec.
Re: Assembly Line markings [Re: kentj340] #3278778
12/29/24 08:56 AM
12/29/24 08:56 AM
Arizona
jrp16 Offline OP
jrp16  Offline OP
Arizona
Thank you for the information... Looks like I will be taking a trip to the Phoenix area.
Re: Assembly Line markings [Re: A12] #3278779
12/29/24 08:58 AM
12/29/24 08:58 AM
Arizona
jrp16 Offline OP
jrp16  Offline OP
Arizona
Interesting... Makes sense to me. Thank you for your input.
Re: Assembly Line markings [Re: jrp16] #3278801
12/29/24 10:39 AM
12/29/24 10:39 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup, as A12 indicates, there isn't the time on a moving assy line to sort through a bin & check part #s.
So it's logical that some parts would have a color code.
Color codes were typical across the industry (GM, Ford, Chrysler) for items like springs, driveshafts, etc.
Re-work for wrong parts kills production efficiency.
That includes sub-assemblies, like engine & trans, where a valve cover often has a 3 or 5 to tell an assembler whether the engine gets a 4-speed or AT attached.
Re: Assembly Line markings [Re: topside] #3278826
12/29/24 01:01 PM
12/29/24 01:01 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
I see that this subject has been on Graveyard carz. And they put the factory inspection markings on. There has to be some factory literature on what color goes where. If you are looking for100% factory correct that's where to look. Might want to check this out.
Re: Assembly Line markings [Re: Moparite] #3278855
12/29/24 03:05 PM
12/29/24 03:05 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd rather rely on guys like Mike Mancini than GYC - GYC takes some liberties with their restorations, and appear to apply markings based on what "should" be, as opposed to what the car really got.
That's maybe splitting hairs, but if one wants it 100% "correct", the markings that specific car had are the truest, right ?
That said, some markings would seem reliable, as far as parts selection (t-bars, diffs, springs, driveshafts, etc).
Others, like suspension inspections or fluid fills, also seem fairly reliable, at least within that car's assembly plant procedures...or maybe the color a particular inspector used ?
Obviously they can't always be determined due to decay, or prior events, like someone painting over the original markings.
Re: Assembly Line markings [Re: topside] #3278953
12/29/24 11:14 PM
12/29/24 11:14 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Yea, Mike Mancini and GYC are a distance apart in quality and correctness. Mancini is in an other (upper) league.
Spring Fling 37 May 3 & 4, 2025 at Woodley Park, Van Nuys CA
600+ Mopars, 200+ swap, midway, Friday Malibu cruise,
Re: Assembly Line markings [Re: jrp16] #3278998
12/30/24 09:33 AM
12/30/24 09:33 AM
Benton, IL.
DaveRS23 Offline
Master of nothing...
DaveRS23  Offline
Benton, IL.
Some markings were for part ID and some were for confirmation of assembly. The part ID markings were obviously consistent while the assembly markings varied. This is a complicated subject. Given all the variables, without evidence of the particular markings that your car came with, it will be impossible to get them all 'perfect' again.
I have not seen any information on the '73 models, but there is information available on the earlier models. That should help some by giving you some insight into how Mopar did things. And some markings would probably even be the same. In fact, depending on what your intentions for the car are, you could just use the earlier model information to 'mark' your car and no one (except you) would be the wiser on any differences. shruggy
Master, again and still
Re: Assembly Line markings [Re: jrp16] #3279053
12/30/24 12:33 PM
12/30/24 12:33 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I like to carefully check a car as it is obtained. All marks and details become important. No two are identical.
I'll add to check inside trunk lid, and the jack assembly, individual components, 3 sp wiper, hd alternators, and even some fasteners receive a daub of inspection paint.
Other times it's a grease smear (behind headlights sitting in their cradle.
info at mmc might assist as you investigate. Colors and application won't be identical. Intentional swipes do not look correct.
https://www.mmcdetroit.com/ICCA/References/Inspection_Marks/Inspection_marks_1_23_2003-1.html
Re: Assembly Line markings [Re: srt] #3279079
12/30/24 01:18 PM
12/30/24 01:18 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Dave also has a '71-74 B-body Inspection book available for purchase.
LINK
Re: Assembly Line markings [Re: sixpakdodge] #3279087
12/30/24 01:46 PM
12/30/24 01:46 PM
Benton, IL.
DaveRS23 Offline
DaveRS23  Offline
Benton, IL.
Just to be clear; that is David Wise. Not me.
But my '71 GTX did get O.E. Certed Silver at the 01 'Nats. Missed Gold by less than a point. 2132 (94.75%) out of 2250. 95% for Gold.
Re: Assembly Line markings [Re: DaveRS23] #3279252
12/31/24 12:23 AM
12/31/24 12:23 AM
Arizona
jrp16 Offline OP
jrp16  Offline OP
Arizona
Thank you!
Re: Assembly Line markings [Re: srt] #3279254
12/31/24 12:32 AM
12/31/24 12:32 AM
Arizona
jrp16 Offline OP
jrp16  Offline OP
Arizona
Thank you... very informative.
Re: Assembly Line markings [Re: sixpakdodge] #3279255
12/31/24 12:34 AM
12/31/24 12:34 AM
Arizona
jrp16 Offline OP
jrp16  Offline OP
Arizona
Great... Thanks!
