Solid roller lifter choice ? #3278058
12/24/24 08:10 PM
12/24/24 08:10 PM
Central NC
gch Offline OP
gch  Offline OP
Central NC
Have no experience with them at all. street solid roller cam,nothing pushing the envelope. Who is the preferred manufacturer and who to stay away from? 6500 max rpm if I have to put a number on it.
Re: Solid roller lifter choice ? [Re: gch] #3278086
12/24/24 11:28 PM
12/24/24 11:28 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
There is a big difference between price points and what you need as far as oiling requirements. For a street application most experts say you need to have full time pin oiling and there are some that say "I've run the regular $500 rollers on the street with no issues" I put a set of Howard's standard rollers in my 493 on a very mild Isky street roller for about 400-500 miles now with zero issues. I keep my idle about 1100 to keep oil slinging for added safety to keep the rollers lubed. My lash hasn't changed since I installed them so far so good.
Gus beer
64 Plymouth Savoy
Dana 60
