Page 1 of 3 1 2 3
727 trans explosion protection #3277943
12/24/24 12:31 PM
12/24/24 12:31 PM
Central NC
gch Offline OP
gch  Offline OP
Central NC
Getting a hot street motor together for my big block duster and I figured it wouldn't be a bad idea to protect my feet from a trans explosion. Blanket? shield ? What are you using and why?
This is a street car and will see the track with drag radials from time to time. Automatic on the column if linkage matters. Would love to have it on the floor but for the price of A body buckets I may just keep my bench seat.
Re: 727 trans explosion protection [Re: gch] #3277946
12/24/24 12:37 PM
12/24/24 12:37 PM
A727Tflite Offline
A727Tflite  Offline
Have the trans properly built, install an aftermarket billet front clutch drum, a bolt in over running clutch helps. A low band apply valve body offers a tad more help in preventing over run clutch roller spit back.
A shield or blanket is “suspenders on a belt” after doing the above.
And of course, drive the car correctly.
Re: 727 trans explosion protection [Re: A727Tflite] #3278059
12/24/24 08:18 PM
12/24/24 08:18 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
iagree
Next question.
Re: 727 trans explosion protection [Re: CMcAllister] #3278096
12/25/24 05:35 AM
12/25/24 05:35 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We use a shield as they have less chance of fouling stuff when installed, we have all the upgrades mentioned below plus steel planetaries, h/d i/p and o/p shafts etc. I've never seen one explode at the track but I have heard of a guy blowing one apart way back doing neutral drops or some other type of abuse. As has been mentioned, correct operation of the trans will help too.
Vid covers what needs to be done to minimize the risk.
https://www.youtube.com/watch?v=trUfoiS2Mew
Re: 727 trans explosion protection [Re: Tig] #3278116
12/25/24 09:04 AM
12/25/24 09:04 AM
Minn
SportF Offline
SportF  Offline
Minn
I've said this here many times before. NSS racer almost lost his foot when the tranny went and the shield did NOTHING. It disappeared in a cloud of dust and only some Kevlar fibers remained intact on the bell housing bolts. The gas pedal did more. Feel a shield, then feel a blanket. Tell me which feels like it could absorb a 2 pound fragment at speed. I find it hard to believe a shield passes certification. Good luck.
Re: 727 trans explosion protection [Re: SportF] #3278117
12/25/24 09:17 AM
12/25/24 09:17 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I totally agree I have seen several carbon fiber shields fail in keeping shrapnel out of the car. Spend the money and buy the right parts to be safe, and a blanket will keep the shrapnel out of the car.
Re: 727 trans explosion protection [Re: jwb123] #3278123
12/25/24 09:56 AM
12/25/24 09:56 AM
Central NC
gch Offline OP
gch  Offline OP
Central NC
Thanks for all the replies. I have my old 727 from my 73 Charger from 20 years ago that had a forward pattern manual valve body but no low band apply (which I did not like for street driving).My local trans builder retired as well.
Now to find someone trustworthy with 727 experience close to central NC. I have no problems doing it with the right parts the first time. If only there was a reputable place close by without shipping. Time to start checking around.
Thanks and Merry Christmas to all.
Re: 727 trans explosion protection [Re: gch] #3278139
12/25/24 10:48 AM
12/25/24 10:48 AM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
My friend and I raced the trans for years and never a problem, his was a 10.90 440 Dart and mine was a 426 Max. The biggest safety feature is that thing between your ears. On My later Duster race car I used the stock column shifter with the detent made to use the reverse VB. AFTER doing burnout, stop, put it back in first, put a little pressure to set the spragg. If any part of driveline breaks pull the trans and check spragg.
Re: 727 trans explosion protection [Re: cudaman1969] #3278165
12/25/24 12:31 PM
12/25/24 12:31 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A good drum is the most important. Along with correct driving habits mentioned. I’ve personally never broke a drum on any trans that I’ve built, Easily over 100 units. Found damaged low roller clutches. Even with low band apply. My racecar never hurt the factory roller clutch. It has broke two ultimate low rollers. Neither time did it show any issue. Only noticed when sheet metal spring parts were found in the pan during service. If you chose the HD (C6 Ford style) low roller make sure the sheet metal tabs clear the inner race. If they rub it will break them off. Also on the billet steel drum. I’ve switched to using 5.0 levers. Those drums are so heavy it takes all you can do to grip them on the 1-2 shift.
Doug
Re: 727 trans explosion protection [Re: gch] #3278187
12/25/24 02:29 PM
12/25/24 02:29 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
You can probably do it yourself. They are one of the easiest and most simple designs to work on with a minimum of special tools. I did my first one on the garage floor when I was 15 and it worked great in my cousin's AMX.
Gus beer
64 Plymouth Savoy
Dana 60
Re: 727 trans explosion protection [Re: fourgearsavoy] #3278196
12/25/24 03:30 PM
12/25/24 03:30 PM
Kansas
Thelma133 Offline
Thelma133  Offline
Kansas
Blanket. Shield available on the web never fit properly. I have 2 blankets, one has Kevlar. He’s not close, but pro trans did mine.
Re: 727 trans explosion protection [Re: cudaman1969] #3278247
12/25/24 11:08 PM
12/25/24 11:08 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
100 percent!!! I've been racing Hemi SS cars for over 50 years with no issue. I do use a blanket. There is more chance of blowing your foot off with a street car, than a race car. You overturn the sprag and blow them up by overunning it low gear. Mr hot shot blowing the tires off to impress the kids, put a set of meats on so it hooks and k=pow! NO low gear burnouts, no blowing the tires off it. I use low to leave the starting line, pull it on the trailer, and pull in the garage. If you break a driveshaft or rear, overrev it in low, crawl under it in check it. Use your head, do thing right and respect you equipment and you will have no issue.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: 727 trans explosion protection [Re: Steve1118] #3278253
12/26/24 01:32 AM
12/26/24 01:32 AM
I had a 8 3/4 rear end fail in low gear which ended up making the rear sprag fail on my 1968 or later drag race 727 whiney shruggy work
Re: 727 trans explosion protection [Re: Cab_Burge] #3278260
12/26/24 03:58 AM
12/26/24 03:58 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
thyis happen to me 10 years ago with parts and oil came inside.i had a shield.when it happens its at the line when you take off in 1st
Re: 727 trans explosion protection [Re: dart games] #3278265
12/26/24 06:58 AM
12/26/24 06:58 AM
Mo.
racerx Offline
racerx  Offline
Mo.
^^^Scary Sh!t there!!!^^^
Re: 727 trans explosion protection [Re: racerx] #3278324
12/26/24 02:50 PM
12/26/24 02:50 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I run a SFI bell and an SFI Shield.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 727 trans explosion protection [Re: 6PKRTSE] #3278349
12/26/24 06:45 PM
12/26/24 06:45 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Real easy to feel when spragg is rolled over. Put in first, if it feels like it in second-sluggish very weird, it’s gone. It’ll blow in first only, if it’s bad the thin sun gear driving shell-rear clutch drum will turn almost 3 times the engine rpm, and turns into a saw with those ‘teeth’. I’m now inclined to use a low band apply type VB but wondering if it applys in high gear too.
Re: 727 trans explosion protection [Re: cudaman1969] #3278359
12/26/24 07:16 PM
12/26/24 07:16 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Buddy of mine had a healthy small block, 904 combo in a Dart. Broke the 8 3/4 under power. Fixed the rear and was out driving the car around. Had a very slight vibration. Called me and said he was going to the track and whether I though it would be OK. I told him to take it out and bring it to me. He said it drives fine. I said bring it to me.
Half the springs were crushed and the rollers were loose in the thing. Half the rollers were functioning well enough to drive the car around. Would not have survived the first hit. No idea what valve body was in it other than it was a manual.
A failed roller clutch doesn't necessarily mean the car won't move. And in a 727 with a stock drum, it would be a ticking bomb.
Re: 727 trans explosion protection [Re: gch] #3278564
12/27/24 07:55 PM
12/27/24 07:55 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I'd switch to a th400 or powerglide before I'd run a blanket or shield again. Blanket is a nightmare with melted straps and acting like a sponge, and the shield is pricey. I'd do the above with a billet drum and proper VB on anything that's going to rev.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: 727 trans explosion protection [Re: A39Coronet] #3278581
12/27/24 11:03 PM
12/27/24 11:03 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My thoughts; A Turbo 400 can spit a drum as well. Just happens at the stripe instead of the starting line. TCI shield is less than $300. If nothing leaks there is nothing to absorb when using a blanket.
Doug
Page 1 of 3 1 2 3
