Re: Hot Rod Drag Week 2025 Tracks Announced [Re: Blusmbl] #3277473
12/21/24 04:18 PM
12/21/24 04:18 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Originally Posted by Blusmbl
Originally Posted by Dragula
My plan is to run Hoosier Quick Time bias ply DOT 16.5x31 for the street ride cause they have lots of tread in case of rain. And then switch to 315 pro radial on 15x12 rims if money allows. Obviously with a big offset in the rims. The smaller 29 Dia radial will bring up my race rpm a little, so the mild gears I run should make them about right for racing with the smaller radials. The 16x31's are actually small for my car already...
Never had a set, but they say leaf spring cars run well with them, so maybe we learn somthing in switching.
I should clarify - you don't need to run radials, it just can't be a regular DOT tire. It can be a drag radial or a conventional bias ply DOT or track only slick, just no street tires so the tread doesn't screw up the track prep. QT Pros, ET Streets, ET Drags, etc are all okay, either bias or radial. There is a width restriction on many of the classes though.
I was crabing more about the size limitations...Us old car guys aren't use to the fact no one tubs a car anymore. Those old classes never had tire limits. I ran in a Gasser series for many years...And there is no way my Gasser even remotely fits their rules. So we go with the Cuda as its street legal, but still fully tubbed. I had to do some measuring, and the 315's will work with a major offset in the rims. Heck, with leafs, they might even work better...
Re: Hot Rod Drag Week 2025 Tracks Announced [Re: Bad340fish] #3277564
12/22/24 07:35 AM
12/22/24 07:35 AM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
Originally Posted by Bad340fish
Originally Posted by usp4u
I'm only coming up with about 500 miles for the drive portion. I thought they were closer to 1,000 ?
I am sure they will add some flair in there to add some distance.
MIR is between all the other tracks so adding flair should be easy.
DC, Baltimore traffic is fun.
