BB PERFORMER CNC PROGRAM #3276797
12/18/24 12:16 AM
12/18/24 12:16 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Anyone out there have a CNC porting program for the Edelbrock Performer BB head?
Re: BB PERFORMER CNC PROGRAM [Re: A/MP] #3276854
12/18/24 10:14 AM
12/18/24 10:14 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
KG Engines in Ohio has a program for them.
Re: BB PERFORMER CNC PROGRAM [Re: A/MP] #3276879
12/18/24 11:34 AM
12/18/24 11:34 AM
an8sec70cuda Offline
Modern Cylinder Head in Detroit has one. After hearing stories about the current shop management there, I wouldn't be sending my heads to them. twocents
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: BB PERFORMER CNC PROGRAM [Re: an8sec70cuda] #3276907
12/18/24 12:54 PM
12/18/24 12:54 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Yep, same here and that's where my heads were done.
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: BB PERFORMER CNC PROGRAM [Re: fast68plymouth] #3276984
12/18/24 08:02 PM
12/18/24 08:02 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
I made a few inquiries and KG seems to have in house issues too.
Re: BB PERFORMER CNC PROGRAM [Re: A/MP] #3277132
12/19/24 02:29 PM
12/19/24 02:29 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Looks like Hughes Engines has stopped doing in-house CNC porting with their scaling back on services
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: BB PERFORMER CNC PROGRAM [Re: A/MP] #3277217
12/20/24 07:45 AM
12/20/24 07:45 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Call BES , or Scott Brown
....BAD A$$ STREET CAR.....
Re: BB PERFORMER CNC PROGRAM [Re: A/MP] #3277688
12/22/24 08:43 PM
12/22/24 08:43 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Care to elaborate? Short staffed, quality issues, etc. What type of issues?
Re: BB PERFORMER CNC PROGRAM [Re: A/MP] #3277702
12/23/24 02:04 AM
12/23/24 02:04 AM
I wouldn't think of buying an Edelbrock or 440 Source head stock size intake port and then have it CNC when you can now buy the Trick Flow 270.
My last bracket stroker 400 block had a set of the Edelbrock victor type heads with the max wedge port sizes, Mark Sullens built E85 Dominator, that motor was 4.375 bore with a 4.320 stroke crank and between 14.93 to 15.04 to 1 compression racing on pump E85.
It ran well and would repeat between .001 to .003 from early mornings to late afternoons boogie up
Re: BB PERFORMER CNC PROGRAM [Re: parksr5] #3277828
12/23/24 07:51 PM
12/23/24 07:51 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
They did well enough on mine. I did some minor clean up around the guides afterwards but nothing to get worked up about.
If you already have the heads it's not a bad idea. If you're still shopping for heads look towards the TF stuff.
- Stu Harmon
Re: BB PERFORMER CNC PROGRAM [Re: Cab_Burge] #3278394
12/26/24 11:41 PM
12/26/24 11:41 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Performers are what I have on the shelf. As far as KG is concerned, machining tolerances between ports themselves.
Re: BB PERFORMER CNC PROGRAM [Re: A/MP] #3278496
12/27/24 02:19 PM
12/27/24 02:19 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
I watched a video of Mopar Joe dyno a 499/400 base engine with the RPM heads with a mild gasket match, old torker intake a HR and it made 680 + torque 650+ HP. The RPM heads can't be that bad. For that matter neither can the old Torker.
America First!
Re: BB PERFORMER CNC PROGRAM [Re: carnut68] #3278522
12/27/24 03:26 PM
12/27/24 03:26 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
600 hp with a short intake (to fit under stock hoods), pump gas and mild cam is pretty easy.
'63 Dodge 330
11.19 @ 121 mph
Re: BB PERFORMER CNC PROGRAM [Re: GY3] #3278525
12/27/24 03:41 PM
12/27/24 03:41 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
And those heads didn't need much work. And an old school supposedly "junk" intake. Wonder how much better a Holley SD would be? If I was the OP I would send the heads to Dwayne let him work a little magic.
America First!
Re: BB PERFORMER CNC PROGRAM [Re: carnut68] #3278818
12/29/24 12:26 PM
12/29/24 12:26 PM
Kansas
Thelma133 Offline
Thelma133  Offline
Kansas
Dwayne not doing heads anymore. That’s what he told me.
Re: BB PERFORMER CNC PROGRAM [Re: n20mstr] #3278940
12/29/24 09:31 PM
12/29/24 09:31 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I don’t have experience with Scott Brown’s product but thats who I would use. I have spoken to him before and he has what appears to be a pretty good program for a stock port window based on the numbers. For what it’s worth I spoke with him because Monte Smith said thats who he would use for a CNC port on an RPM head, but I wound up buying different heads.
Re: BB PERFORMER CNC PROGRAM [Re: GTX MATT] #3278943
12/29/24 09:57 PM
12/29/24 09:57 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I don't know who Scott Brown is farming out his head porting to now, but at one point he used Modern Cylinder Head.
Re: BB PERFORMER CNC PROGRAM [Re: A/MP] #3279114
12/30/24 03:59 PM
12/30/24 03:59 PM
SoCal
Brian Hafliger Offline
SoCal
We still hand port everything...immengines.com.
Brian Hafliger
Re: BB PERFORMER CNC PROGRAM [Re: an8sec70cuda] #3280205
01/03/25 12:32 PM
01/03/25 12:32 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Bob ripped me off for $4k. I had good luck with Jeff and he did a set of iron 559-M Hemi heads and a set of W2 heads for me. Bob is ruining the good reputation his brother established with MCH. I wouldn't send Bob any money in advance. Tell him to ship it COD and pay it when you get them and inspect them. Or pick them up in person and take all your inspection equipment with you. Bob is a bum.
Floyd Lippencott IV
