Re: Blower cam recommendations please
[Re: Dragula]
#3276669
12/17/24 02:16 PM
12/17/24 02:16 PM
Posts: 3,867 N.E. Ohio
6bblFLASH
N.E. Ohio
In my experience, yes that cam would work. Power band is probably fairly high. What gear/converter etc ...do you have in mind? I run a small Roots blower and it sees 7lbs.peak. My cam is 236/242@.050 .501 lift 110 c/l. Has gone 10.48 @3,600lbs 440in motor ,3.33 gears ratio. Shift at 5200/5300. Again my opinion, 110 C/L is the best compromise. I've tried 6 different cams,110..112..114... 110 gives best idle,cruise,response and ET. In my car. I know there is power left on the table with a "regular " cam. But the blower is going to rule the max power more than the cam. Wrong cam will just hurt lower RPM torque. and effect idle quality. Boosted stuff will run better under-camed. ,,,Max EFFICIENT blower speed is the ceiling..not the cam...
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: Dragula]
#3276680
12/17/24 02:56 PM
12/17/24 02:56 PM
6bblFLASH
N.E. Ohio
How fast/ET are you shooting for? Blower speed will factor in as well. I'd ask a cam shop...Comp etc..to ballpark what you are already thinking 🤔
[Re: 6bblFLASH]
#3276681
12/17/24 02:59 PM
12/17/24 02:59 PM
Posts: 12,524 Taxes & Virus's R-US, NY
Dragula
Shooting for 9.50 or quicker...
Car should be right around 3100 plus my 250.....With the big Hemi its 3204lbs...And that Callies block is like +300lbs..
[Re: Dragula]
#3276689
12/17/24 03:43 PM
12/17/24 03:43 PM
Posts: 14,554 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’ll throw in my .02…..
My impression of the TS blowers is they aren’t terribly efficient.
Putting one on a 500+ cube build with bigger heads and a long duration camshaft is going to require spinning the blower harder to make the desired boost.
For that combo I’d run a shorter cam(than the card in the pic).
[Re: fast68plymouth]
#3276710
12/17/24 05:34 PM
12/17/24 05:34 PM
6bblFLASH
N.E. Ohio
For that combo I’d run a shorter cam(than the card in the pic). That's been my experience too...don't overcam...
#3276713
12/17/24 06:08 PM
12/17/24 06:08 PM
Dragula
For that combo I’d run a shorter cam(than the card in the pic). Just for reference, that cam is currently in a +.030 440 I have, that is not stroked....
[Re: AndyF]
#3276763
12/17/24 09:15 PM
12/17/24 09:15 PM
Dragula
If you already have that cam then sure, it will work. If you are going to buy a new cam then I wouldn't buy that particular one. I don't think you need that much split with a blower since you'll have more cylinder pressure. So the 259/270 split is a bit much? Most of the cams I look up on Comps sight for the 440 have a pretty big split. I hate their web page though, I could not find any cams for boost. I am figuring for the street, somthing right around 260 or less would be nice. I will call one of their reps and see I guess. That is the current cam in my +.030 440 that I will probably put a roots blower on someday....It has the TF270 's on it. This engine I need a blower cam for has Indy EZ 325's upgraded to 2.19 valves. Figured they are probably pretty close as far as flow...
#3276868
12/18/24 11:13 AM
12/18/24 11:13 AM
Posts: 730 Lake Villa Il
INTMD8
Lake Villa Il
For that combo I’d run a shorter cam(than the card in the pic). Agree 100%
