Re: 360 losing oil pressure when reved up.
[Re: dirt]
#327557
05/24/09 09:03 PM
05/24/09 09:03 PM
Posts: 228 northeast texas
strokin73cuda
northeast texas
had a couple stock engines when mains were bad would drop in oil pressure while under acceleration and gain it back when deccel. in same gear also if its an elec. gauge try adding it with mechanical and see what happens.
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
[Re: dirt]
#327566
06/08/09 07:20 PM
06/08/09 07:20 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
it has been blowing a big puff of smoke when i fire it up.
Points to valve seals and guide wear. but won't effect your oil pressure.
[Re: MoparforLife]
#327567
06/08/09 10:32 PM
06/08/09 10:32 PM
Posts: 2,537 God's Country Maryland
GODSCOUNTRY340
If it smokes on start up the valves seals are bad. They're so bad they've hardened, broken apart, fallen into your oil pan and are plugging the pick-up tube screen.
[Re: dirt]
#327569
03/26/14 02:47 PM
03/26/14 02:47 PM
Posts: 5,167 CT
GTX MATT
CT
Wow, an OP reviving a 5 year old thread ![](/ubbthreads/images/graemlins/laugh2.gif) Carefully remove the main caps, take lots of pictures and post them up here. Don't mix anything up or drop it yet. I'm assuming you don't have access to a bore mic and calipers to measure your clearances. You could use some plasti-gauge and see what the clearances are, although this isn't very accurate. You could measure, get new main bearings, re-measure, and they should at least be tighter. I'd put a new oil pump in it too.
[Re: GTX MATT]
#327571
03/26/14 10:59 PM
03/26/14 10:59 PM
Posts: 1,349 warfordsburg, PA
dirt
warfordsburg, PA
wow it has been 5 years ![](/ubbthreads/images/graemlins/eeek.gif) I pulled the motor out back when I had the oil pressure problem and dropped in a temporary motor, now the temporary motor is needing replaced. since it was worn out when I got it. but this 360 is a good motor and I didn't want to screw it up. I have owned it since it only had 30,000 miles on it. now I need to fix it and get it back in my truck. I don't have a bore mic, I do have a cheap set of digital calipers. I will pull the caps off and get pictures, I will mark the caps to make sure I get them back on the right place. probably tomorrow. thanks
[Re: dirt]
#327572
03/26/14 11:34 PM
03/26/14 11:34 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Old Quaker Sludge oil used to cause lots of that years ago. Gotta love the old paraffin based oils.
